Blu-ray converter 2.1.1.35, beta version available!
julien
Re: Blu-ray converter 2.1.0.5, beta version available!
Post by julien »
There is a Mistake in the new Version, if you convert a DVD, you don´t have any Menu Chance for the DVD menu template. It is empty ???
I hope for a new Version quickly.
Julien
BenieUK
Post by BenieUK »
Cant use until CUDA re-added as its far too slow... will there be a CUDA version released soon? thank you.
Dogbert
Post by Dogbert »
I have emailed cedric for a new key for version 2 but I haven't received a response. Is there someone else that I can contact?
you should have received your keys now. The fastest way to get a response from VSO is to use the contact form on our website.
Dogbert
Post by Dogbert »
Claire, Thank you for sending me the keys. I don't find a contact form on your website. Do you have a link to the form?
Thank you.
here is the contact page, it is under the tab "support"
http://www.vso-software.fr/contactform.php
Dogbert
Post by Dogbert »
Which option on the contact page do I need to click on to get to the form?
General Inquiry or Technical support
BenieUK
Re: Blu-ray converter 2.1.0.7, beta version available!
Post by BenieUK »
CUDA still not working with my new 670 card, does work with v1. just error with v2.
How do you know CUDA is not working with your graphic card?
Are you able to check the option (not grayed out)?
If you can check it, you think the performances are the same by enabling or disabling this option?
BenieUK
Post by BenieUK »
When i enable cuda the profile nolonger works, program just error on start of conversion. without cuda is fine but slow. im using v1 with cuda and is ok. thank you.
Can you try with an AVI CUDA profile?
I've just fixed a problem with mkv CUDA profiles...
BenieUK
Post by BenieUK »
It seems AVI is the only CUDA profiles that work... MP4, MKV etc just error on start... even my custom MKV profiles fail.
another bug is the program does not keep the size i have selected (no video limit) on program restart, it always reverts to dvd5 size.
thank you
All CUDA profiles will works on next version, I will take a look on your output size issue today...
Thanks!
0xdeadbeef
Re: Blu-ray converter 2.1.1.0, beta version available!
Post by 0xdeadbeef »
Is two pass supposed to work for BD->DVD conversions in 2.1.1.0? I tried it yesterday and the main movie seems to have been converted ok, but then it got stuck in the menu creation. The progress bar just froze with like 27 minutes left although the 4x1GB VOBs were already created. And as there is no progress any more, the estimated times just increases. I canceled after like 30 minutes in which the progress bar didn't move one pixel.
[EDIT]
On a 2nd thought, this also seems to happen with single pass. Even the menu creation seems to be more or less finished, but then the process gets stuck. And all that happens then is the estimated time left increasing...
Do you have more than one title in your project? (have you checked some bonuses, or are you trying to convert a series Blu-ray type)
When more than one title is converted, a title menu is automatically created, and maybe the problem is here...
Which DVD menu template is selected?
I will try to reproduce/fix your problem today.
Thanks!
0xdeadbeef
It was just the main movie and the default template (black mirror/video).
are you using any hardware decoders or encoders?
so far we cannot reproduce
0xdeadbeef
Yep, Cuda for decoding and encoding, Nvidia card with pretty new drivers.
Movie was "Battleship" if this is of interest.
0xdeadbeef
Forgot to mention that I have two crash logs, but they don't seem to contain any relevant information:
Code: Select all
2012-08-28 01:43:36	----        	*** File encoded successfully: VTS_01_1.VOB - Battleship - Hauptfilm - DVD ***
2012-08-28 00:57:46	Info        	Hardware decoding: H.264 variable-length decoder, no film grain technology using adapter #0 - NVIDIA GeForce GTX 570 , vendor 0x10DE (NVIDIA), device 0x1086, revision 161, converting h264 to yuv420p
2012-08-28 00:11:12	Info        	Hardware decoding: H.264 variable-length decoder, no film grain technology using adapter #0 - NVIDIA GeForce GTX 570 , vendor 0x10DE (NVIDIA), device 0x1086, revision 161, converting h264 to yuv420p
2012-08-28 00:11:12	----        	*****************************************************************************
2012-08-28 00:11:12	Info        	scale#0(width=720, height=576, interpolation='lanczos', padding_method='automatic', crop_left=0, crop_top=0, crop_right=0, crop_bottom=0, pad_left=0, pad_top=0, pad_right=0, pad_bottom=0, pad_color=0)
2012-08-28 00:11:12	Info        	equalizer#0(contrast=1, brightness=0, saturation=1, gamma=1, gamma_weight=1, red_gamma=1, green_gamma=1, blue_gamma=1)
2012-08-28 00:11:12	Info        	rotate#0(rotation=ROTATE_NONE)
2012-08-28 00:11:12	Info        	deinterlace#0(mode=DEINTERLACE_FFMEG)
2012-08-28 00:11:12	Info        	╔═> [subtitle #5 - dvd_subtitle subtitle, x  [deu]]
2012-08-28 00:11:12	Info        	╚══ [subtitle #5 - hdmv_pgs_subtitle subtitle [Deutsch]]
2012-08-28 00:11:12	Info        	╔═> [subtitle #4 - dvd_subtitle subtitle, x  [deu]]
2012-08-28 00:11:12	Info        	╚══ [subtitle #4 - hdmv_pgs_subtitle subtitle [Deutsch]]
2012-08-28 00:11:12	Info        	╔═> [subtitle #3 - dvd_subtitle subtitle, x  [eng]]
2012-08-28 00:11:12	Info        	╚══ [subtitle #3 - hdmv_pgs_subtitle subtitle [English]]
2012-08-28 00:11:12	Info        	╔═> [audio #2 - ac3 audio, 48000Hz, 6 Ch., 448 Kbps [deu]]
2012-08-28 00:11:12	Info        	╚══ [audio #2 - dts main audio, 48000 kHz, 5.1 Ch., 768 kbps [Deutsch]]
2012-08-28 00:11:12	Info        	╔═> [video #1 - mpeg2video video, 720x576, yuv420p, 0]
2012-08-28 00:11:12	Info        	╚══ [video #1 - h264 video, 1920x1080, YUV420P, 1,00]
2012-08-28 00:11:12	Info        	Info Logical file: Battleship - Hauptfilm
2012-08-28 00:11:12	Info        	Limit filesize to DVD5 (4.7GB)
2012-08-28 00:11:12	----        	************* Battleship - Hauptfilm -> VTS_01_1.VOB - PAL 16/9 *************
2012-08-28 00:11:12	Info        	DVD info Format PAL
2012-08-28 00:09:46	Info        	Video structure loaded successfully from:I:\Blu-Ray\BATTLESHIP_G51\BDMV\index.bdmv
2012-08-28 00:09:32	Info        	 No disc in drive.
2012-08-28 00:09:32	Info        	9 Menüvorlagen geladen.
2012-08-28 00:09:31	Info        	Available Memory : 9826 Mb.
2012-08-28 00:09:31	Info        	Total Memory : 12282 Mb.
2012-08-28 00:09:31	Info        	Available extended Virtual Memory : 0 Mb.
2012-08-28 00:09:31	Info        	Available Virtual Memory : 1811 Mb.
2012-08-28 00:09:31	Info        	Total Virtual Memory : 2047 Mb.
2012-08-28 00:09:31	Info        	Memory Load  : 37%
2012-08-28 00:09:31	Info        	Available Physical Memory : 3859 Mb.
2012-08-28 00:09:31	Info        	Total Physical Memory : 6142 Mb.
2012-08-28 00:09:31	Info        	System default language : Deutsch (Deutschland)
2012-08-28 00:09:31	Info        	User default language   : Deutsch (Deutschland)
2012-08-28 00:09:31	Info        	Version : 2.1.1.0
2012-08-28 00:09:31	Info        	ExeName : C:\video\Blu-ray Converter Ultimate 2\BlurayConverterUltimate.exe
2012-08-28 00:09:31	Info        	OS : Microsoft Windows 7 Professional (Build 7601: Service Pack 1)
2012-08-28 00:09:31	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-08-28 00:09:31	Info        	 Drive has Serial ATA physical interface
2012-08-28 00:09:31	Info        	 New Drive selected : 0:2:0 - HL-DT-ST BDDVDRW GGC-H20L 1.03 [F] (Ide)
2012-08-28 00:09:31	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2012-08-28 00:09:31	Info        	 New Drive selected : 0:4:0 - HL-DT-ST BD-RE  BH10LS30 1.01 [H] (Ide)
2012-08-28 00:09:31	Info        	 New Drive selected : 0:3:0 - LITE-ON DVDRW LH-20A1S 9L09 [G] (Ide)
2012-08-28 00:09:30	Info        	 Using Advanced SPTI interface
2012-08-28 00:09:30	----        	******************** Log session start 2012-08-28 00:09:30.649 PID 7876 ********************
