Convert audio CDs to DVD
LloydJ
Post by LloydJ » Thu Feb 23, 2012 6:59 pm
Is it possible to take several Audio CDs and burn to a DVD? For instance - an audio book with mutiple CDs
Re: Convert audio CDs to DVD
Post by JJ » Thu Feb 23, 2012 9:22 pm
Yes, it is possible but not easy.
First create video with very simple background, preferably just black or static image on each track. Cut your video to match your audio.
For example - create video that has static image of album cover, check length from album.
Rip your audio CD to wav or any preferred format (mp3 is lossy, so avoid if quality is important).
Open ConvertXtoDVD, add premade video track, then add your audio tracks to video.
This allows you to make 99 separate tracks, with 99 chapters on each track. (main menu is one track so 98*99 is real total)
There is no audio CD that has 99 audio tracks, so those chapters are enough.
Make first track, don't burn, check conversion size. Add second track, check again total conversion size. Keep adding tracks until you reach your DVD size limit. Burn to DVD.
