Capture wma streaming audio via mms protocol
JibberJabber
Post by JibberJabber »
A Happy New Year to you all!
I see that Version2 has wma filetype listed under video. Shouldn't it rather be an option under audio? I could find great use for VSO Downloader if it could capture mms-delivered wma streaming audio.
Great product nonetheless, and all the best for your Pro endeavours!
JibJab
Benjamin
Re: Capture wma streaming audio via mms protocol
Post by Benjamin »
you are right, it will be updated in the next version.
Can you provide an example of mms-delivered wma streaming audio?
Have a healthy new year!
JibberJabber
Benjamin wrote:you are right, it will be updated in the next version.
Eh ... I may have had a brainfade re mms, Benjamin.
Nevertheless, the sort of thing I'm suggesting your downloader grabs is :arrow: :arrow: :arrow:
http://wm.bbc.co.uk/wms/radio4fmcoyopa/ ... y_1630.wma
Cheers!
JibJab
Benjamin
Post by Benjamin »
if you have the URL you can download it directly?
JibberJabber
Benjamin wrote:if you have the URL you can download it directly?
If you download it directly, you'll get a file of ... 97bytes, whereas if you open (play) the link, then the content is in fact 10.46megs.
The file seems to be sent via mms, with the url mms://wm.bbc.co.uk/wms/radio4fmcoyopa/radio_4_fm_-_wednesday_1630.wma?MSWMExt=.asf
Cheers!
JibJab
Benjamin
Post by Benjamin »
ok we will first implement the RTMP then check the RTSP
JibberJabber
Cheers Benjamin, and thanks for your time.
JibJab
