Keyboard keys & Command Line Arguments
Viscouse
Post by Viscouse »
Hi. Just trying this out. Subject pretty much says it all.
Are there any Keyboard shortcuts? I know space = pause, but that's it.
Also, are there any Command Line Arguments?
Thanks!
felicia
Re: Keyboard keys & Command Line Arguments
Post by felicia »
Here are the shortcuts supported by VMP, feel free to make any suggestion.
General:
- Ctrl-L: Show/Hide playlist.
- Space: Pause/Play.
- Esc: Leave full screen.
- Arrow up: Increase volume.
- Arrow down: Decrease volume.
- Arrow right: Seek forward.
- Arrow left: Seek backward.
When in playlists panel:
- Ctrl-S -> Save current files as a playlist (not for DVDs or BDs)
- Delete -> Delete selected item from playlist (not for DVDs or BDs)
- Enter -> Play selected item
Media keys next, previous, pause are also supported.
No particular comand lines are supported, just play argument.
Hope it helps.
Viscouse
Post by Viscouse »
Thanks!
andresuppsala
Post by andresuppsala »
Is there a keyboard shortcut for toggling full screen?
felicia
Post by felicia »
Ctrl-F will be implemented in the next version as a full screen shortcut, otherwise a double-click will do it.
Best regards,
Felicià
