VSO Media Player Bugs + Ideas
sprattspride
Post by sprattspride »
I love your new VMP :D , think its great. with just a small download and so easy to use player and - you have give every user what they want - dont even know it running on my computer when using it, it uses little CPU and ram = MAGIC! ( unlike lots of other media player you have to install codecs to play each file format.)
Once all the bugs are fixed your going to have the best Media Player on the internet. :D
1. VSO Media Player freezes playing movie files some times.
2. When select a lot of songs to play with using my right click button on my mouse. it opens all the songs in the own media play and plays them all at the same time. could you please add a play in play list in the right click menu please. so i just have to right click on the group of song and click on play as play list.
3.I dont see any were to turn the sound up or down now in the new version :(
__________________________________________________________________________________________________________________________________
IDEAS
1. add a update button and have a auto check for updates on start up ( the same way ConvertXtoDVD checks for updates on start up )
2.i would like to see a repeat on the skin( so i could repeat a song or play list)
3. could you have different icons for each of the different media files ( EXSAMPLE: The KMPlayer
when is has a media file of a mp3 , could you put mp3 on the icon. and have a icon for every file format to the player can play.
4. Could you add a golden member skin just for golden members?
Thanks again for a great Media Player. once it is ready i would like you to put it on download.com i think you would get lots of people downloading it.
Thank You :D
felicia
Re: VSO Media Player Bugs + Ideas
Post by felicia »
Thx for the feedback.
BUGS
1. Witch files caused this problem, or were they random.
2. Ok, will work on it.
3. Right down corner if you click on the speaker icon you'll have a track bar to modify sound, or you can use the mouse wheel over the speaker icon. If either of this methods fails please contact me.
IDEAS
1. Button already present under "?/Check for update", updates check is done on every start up.
2. Will be added in a later version.
3. Not a priority but it will be done.
4. Will consult on this matter.
Thanx again for your feedback, please feel free to contact us if you have any other suggestions.
sprattspride
1.They are just random.but check AVI files first
got yes rest thanks. Keep up the great work guys :D
igorruckert
Post by igorruckert »
I have translated the program to Brazilian Portuguese, how can I send you the language file??
you can send it to annelise(at)vsosoftware.fr
thanks very much!
lightlyprinted
Post by lightlyprinted »
When I play this MKV the video is sluggish and audio is out of sync (with cuda and without cuda doesn't matter):
PM me if you want this video.
2011-07-05 19:31:25 Info Stream ID #3 - subtitle (dvdsub) 0x0 [eng] started at 0:00:07
2011-07-05 19:31:18 Info Stream ID #0 - Video (h264_cuda) 720x480 - 3/2 (1.50) - YUV420P [eng] started at 0:00:00
2011-07-05 19:31:17 Info Stream ID #2 - Audio (aac) 48000 kHz - 6 Cx [jpn] started at 0:00:00
2011-07-05 19:31:17 Info Playing file: 'C:\Movies\Ergo Proxy\cd1 done\01Ergo Proxy-Awakening.mkv'
2011-07-05 19:31:17 Info Stream ID #1 - Audio (aac) 48000 kHz - 6 Cx [eng] started at 0:00:00
2011-07-05 19:31:16 Info AV LOADER: File "01Ergo Proxy-Awakening.mkv" probed format is Matroska/WebM file format
2011-07-05 19:31:03 Info Program started
2011-07-05 19:31:03 Info Supported instruction set: sse4
2011-07-05 19:31:03 Info Maximum number of threads detected: 4 - parallelize up to 4
2011-07-05 19:31:03 Info Tuning Performances for AMD Phenom(tm) 9600 Quad-Core Processor with 4 core(s) CPU
2011-07-05 19:31:03 Info Available Memory : 14990 Mb.
2011-07-05 19:31:03 Info Total Memory : 16380 Mb.
2011-07-05 19:31:03 Info Available extended Virtual Memory : 0 Mb.
2011-07-05 19:31:03 Info Available Virtual Memory : 1853 Mb.
2011-07-05 19:31:03 Info Total Virtual Memory : 2047 Mb.
2011-07-05 19:31:03 Info Memory Load : 14%
2011-07-05 19:31:03 Info Available Physical Memory : 6976 Mb.
2011-07-05 19:31:03 Info Total Physical Memory : 8191 Mb.
2011-07-05 19:31:03 Info System default language : English (United States)
2011-07-05 19:31:03 Info User default language : English (United States)
2011-07-05 19:31:03 Info Version : 0.1.1.189
2011-07-05 19:31:03 Info ExeName : C:\Program Files (x86)\VSO\VSO Media Player\VMP.exe
2011-07-05 19:31:03 Info OS : Microsoft Windows 7 Professional (Build 7600)
Last edited by lightlyprinted on Wed Jul 06, 2011 5:04 pm, edited 2 times in total.
Thanks for posting a link to the file, but I cannot access it.
By PM, I have sent you instructions to upload the file to us. I hope you do not mind doing this to help.
New version has no problems with that file, quality is good and audio in sync.
thanks JJ for you feedback.
@ lightlyprinted I know we have been exchanging by PM, but I am posting this here in case other people still have a problem like you.
I suggest trying this new version pre public version:
http://oasis.vso-software.fr/Beta/VSOMe ... .211_b.exe
You will notice the interface appears oddly different - but it should give less playback problems.
Let us know how your test goes, and thanks again for your feedback.
