What to do when disk is protected?
If your VSO product says your disk is protected, then you need to install a decrypting tool that will remove the protection.
Here are some decrypting tools:
- DVD43 free too for DVDs
- AnyDVD HD by SlySoft (Recommended)
- Passkey for Blu-ray by DVDFab
How these tools work:
When the decrypter is running, it works as a background process, making the disk readable so that software or you can access the contents directly. Without a tool like this the contents of the disk cannot be seen.
***Make sure legally you are allowed to use these software products in your country in order to make your own personal copy.
(As a French company we are not allowed to create software that removes the protection from disks or other digital content).
Once AnyDVD is installed, launch AnyDVD so that in the bottom right hand corner of your computer you see a little icon in the shape of the head of a fox.
If the icon is not in color that means AnyDVD is not running actively. TO have it run, right click and select "Enable AnyDVD"
If your Blu-ray Converter is already open and the drive already selected where you have inserted your disk, press the refresh button and select the drive again.
Now the Blu-ray Converter will be able to access and read the contents of the disk for converting.
To see if AnyDVD has removed the protection of the disk, go to Computer and right click on your drive where the Blu-ray disk is inserted, and select "Open"
If you see a folder with the name "AACS" then the protection has not been removed. Close and reopen AnyDVD to try and refresh it so that it detects and scans the disk again (make sure you are using the latest version of AnyDVD)
If you see a folder named "ANY!" that means the protection has been removed and you will be able to convert the contents of the disk or read with a video player such as VLC (free).
vze2mp9g
Re: What to do when disk is protected?
Post by vze2mp9g »
I strongly agree with Claire, Slysoft's AnyDVD HD will solve all your copy protection problems. They have very good forums to answer all your questions. I've been using it for four years now and have NEVER had a problem! :D
Blade Runner
Post by Blade Runner »
SlySoft's servers are no longer online as of Feb 24, 2016. Anyone use Passkey from DVDFab?
dosibo51
Post by dosibo51 »
reddwarf4ever
Post by reddwarf4ever »
100% recommend AnyDVD, it’s so easy, sits in the background and automatically removes the protection
Good luck
dgmckenzie
Post by dgmckenzie »
Well.
I did use AnyDVD (HD) and paid annually and then upgraded to lifetime. But they 'closed down' and reopended as redfox. So I would have had to pay all over again.
I moved to DVDFab passkey which worked like AnyDVD used to. They were giving it away at one point.
Another is MakeMKV, it rips DVDs for free. then use VSO from there.
