New ConvertXtoVideo 2.0.0.61 BETA version
Cronm
Re: New ConvertXtoVideo 2.0.0.58 BETA version
Post by Cronm »
More info on close bug
jramos95
Re: New ConvertXtoVideo 2.0.0.59 BETA version
Post by jramos95 »
How can I merge a subtitule into a DVD .VOB file?
Dirkmaster
Post by Dirkmaster »
Version 59b has fixed the problem! I am SO happy! This program is so much faster than MakeBR, and gives me much more control.
Thank you!
@ Cronm can you tell us if you reproduce with the new beta 2.0.0.59?
dosibo51
Re: New ConvertXtoVideo 2.0.0.60 BETA version
Post by dosibo51 »
when you press MINIMIZE button the program GUI is away - background task is still there. Just started the program 3 times and pressed MINIMIZE. See screen shot.
Test with 2.0.0.60 beta (never tried before with this tool).
At first I've thought it crashed - not easy to find because the process is called "All In One Video Converter" (no VSO in the name)? ;)
Cronm
Post by Cronm »
Claire wrote:@ Cronm can you tell us if you reproduce with the new beta 2.0.0.59?
Looks like it's solved
wtin
2.0061b sends back to redownload
Post by wtin »
After installed, it says the 2.0061 is not legitimate and there are two choices to choose from. One is to download and the other is to refuse (cancel).
Downloading it gets the same version. Cancelling it closes the program down.
So I went back to 2.0060, when I tried to enter the serial number, it says, "this key is used on too many computers."
I have never given any VSO software away. I am one of those users that when Windows runs funny, I just wipe the hard drive clean and reinstall all programs. I didn't know the activation counts go down when the key is entered.
Help!!!!
felicia
Post by felicia »
dosibo51 wrote:Hi,
We've noticed that in the last version when the program is minimized it goes to task bar, this should be fixed in the nex build.
Re: 2.0061b sends back to redownload
wtin wrote:After installed, it says the 2.0061 is not legitimate and there are two choices to choose from. One is to download and the other is to refuse (cancel).
Help!!!!
Try again you should no longer be blocked. Should you ever be blocked in the future again just contact VSO Directly.
ira
Re: New ConvertXtoVideo 2.0.0.61 BETA version
Post by ira »
Claire,
If you are thinking that re-downloading NOW resolved the "Not Legit" copy with the continual request to update - it did not and by inspection today's d/l is EXACTLY the same as when I and others reported that problem a few days ago. Not a serious issue though.
Ira
wtin
2.0060 menu item names reverted to file name
Post by wtin »
Created a DVD, (or blu ray)
Import three files.
"File number 1 the beginning.mp4"
"File number 2 the middle.mp4"
"File number 3 the end.mp4"
Name the first one "The beginning"
Name the second one "The Middle"
and the 3rd
Burn to disk.
Play disk.
Menu shows ("simple menu')
1 File number 1 the beginning.mp4
2 File number 2 the middle.mp4
3 File number 3 the end.mp4
the bug you had should be fixed in 2.0.0.61
http://forums.vso-software.fr/convertxt ... 18977.html
wtin
2.0.0.61
Post by wtin »
But 2.0061b won't run. It wants to redownload itself.
ira
Post by ira »
When I close the popup that says update, the program runs ... but would like it fixed, too.
Ira
Cherryman
Post by Cherryman »
ira wrote:When I close the popup that says update, the program runs ... but would like it fixed, too.
The problem with the updating message is bad lately - times it goes, then again not. Better omit
Btw:
Why were skins deleted? Always had the skin "Subway"
You can omit for reasons of the download-size skins, but optionally as a download offer ;)
Cherryman
new beta and new beta thread here
http://forums.vso-software.fr/convertxt ... 19582.html
@Cherryman, Yes some themes were removed, we might have a solution coming soon on getting back to looking like subway theme
