New ConvertXtoVideo 2.0.0.61 BETA version
Re: New ConvertXtoVideo 2.0.0.39 BETA version
ConvertXtoVideo 2.0.0.39 BETA file is corrupt, see attached error message from win10 64
sorry for this problem. The file has been uploaded again and works now.
Ch3vr0n
Re: New ConvertXtoVideo 2.0.0.46 BETA version
Post by Ch3vr0n »
OMG, i love this new GPU.
Project: Merge 4 MP4 files of approx 200-250MB into 1 file
CXV 2.0.0.46 + Strix GTX 1080A > MP4 + AAC = 8-900+FPS! (using NVEnc) Peak FPS of 931, total time. Unknown (wish that was shown on the information screen) I'm guessing no more than 3min
CUDA mode fails though!!!
@Claire
small feature request. Could on the conversion finished dialogue, be shown how long total conversion took (or offer the user a setting to do so)
Desktop: Project Phoenix
wtin
2.0046 DVD creation
Post by wtin »
[attachment=1]20046 screen 1.jpg[/attachment]
MP4 files (downloaded with Audials 2017 from Netflix. In this case, four episodes, almost an hour each.
DVD template.
Standard (classic, simple) menu.
Intel i7 with 32 G of RAM. GTX 780. Windows 10 64 bit.
Convert X to Video 2.0046 beta.
Successful conversion, but the files are not complete (only "video" folder was created, no "audio" was created.)
Screen shot of files created. I usually use DVDShrink to assemble these files. But these are not valid.
Thank you.
Wtin
wtin
DVD creation 2.0.0.47
Post by wtin »
2.0047 still does not create complete DVD files that can be assembled (with DVDshrink). Please see previous message.
DVD structure has audio_ts folder only for music; it is not used with video files.
Ch3vr0n
Re: New ConvertXtoVideo 2.0.0.47 BETA version
Post by Ch3vr0n »
That folder is part of the DVD standard, it's just uncommon nowadays to see it on a disc and never really took off
wtin
2.0047 DVD creation
Post by wtin »
[attachment=0]Complete DVD files.jpg[/attachment]I realize that (about the audio folder / directory).
See above - this is a file listing of a complete, playable DVD.
(Edited) sorry, uploaded the same one. Just uploaded the correct one - this shows complete listing of files under video folder of a playable DVD.
dosibo51
Post by dosibo51 »
Very strange.
With Blu-ray converter 4.0.0.47 I've remuxed a BR into a MKV (h264 codec) - finally has 27.3 GB.
I then used ConvertXtoVideo and tried to remux the MKV into M2TS (remux video, audio, subtitle). Was finished in 12 min .. finally has 2 GB and only audio + subtitle but no video.
Original MKV:
Code: Select all
General
Unique ID                                : 231264057398855164971243021428280578778 (0xADFBD65AA2CB91417268E01FBF44D2DA)
Complete name                            : x.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 27.4 GiB
Duration                                 : 1 h 56 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 33.6 Mb/s
Writing application                      : Lavf56.30.100
Writing library                          : Lavf56.30.100 / Lavf56.30.100
LABEL                                    : Chapter 12
Language                                 : eng
TCHAPTER                                 : 258936672
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate mode                            : Variable
Maximum bit rate                         : 34.0 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 48.000 FPS
Original frame rate                      : 24.000 FPS
Standard                                 : NTSC
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Title                                    : h264 1920x1080 16/9
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Track/Position                           : 0
Audio #1
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Bit rate mode                            : Constant
Bit rate                                 : 224 kb/s
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 spf)
Bit depth                                : 16 bits
Compression mode                         : Lossy
Delay relative to video                  : -125 ms
Stream size                              : 187 MiB (1%)
Title                                    : ac3 48000Hz 2Ch.
Language                                 : German
Default                                  : Yes
Forced                                   : No
Track/Position                           : 1
Audio #2
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : MA / Core
Mode                                     : 16
Codec ID                                 : A_DTS
Bit rate mode                            : Variable / Constant
Bit rate                                 : Unknown / 1 509 kb/s
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Frame rate                               : 93.750 FPS (512 spf)
Bit depth                                : 16 bits
Compression mode                         : Lossless / Lossy
Title                                    : dts 48000Hz 6Ch.
Language                                 : German
Default                                  : Yes
Forced                                   : No
Track/Position                           : 2
Text
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Title                                    : hdmv_pgs_subtitle 1920x1080
Language                                 : German
Default                                  : Yes
Forced                                   : No
Track/Position                           : 3
Menu
00:00:00.000                             : :Chapter 1
00:08:54.375                             : :Chapter 2
00:21:28.166                             : :Chapter 3
00:29:33.250                             : :Chapter 4
00:37:46.375                             : :Chapter 5
00:48:02.916                             : :Chapter 6
00:59:05.666                             : :Chapter 7
01:08:06.250                             : :Chapter 8
01:18:06.125                             : :Chapter 9
01:28:41.958                             : :Chapter 10
01:38:54.375                             : :Chapter 11
01:51:05.875                             : :Chapter 12
and after the 1:1 remux it only contains audio - no video: WHY?
Code: Select all
General
Complete name                            : x.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 2.03 GiB
Duration                                 : 9 h 11 min
Overall bit rate mode                    : Constant
Overall bit rate                         : 527 kb/s
Maximum Overall bit rate                 : 48.0 Mb/s
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : AC-3
Codec ID                                 : 129
Duration                                 : 1 h 51 min
Bit rate                                 : 224 kb/s
Bit depth                                : 16 bits
Stream size                              : 178 MiB (9%)
Language                                 : German
Audio #2
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : 134
Bit depth                                : 16 bits
Language                                 : German
Text
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Language                                 : German
What's wrong?
Roshi
Re: New ConvertXtoVideo 2.0.0.48 BETA version
Post by Roshi »
When updated ConvertXtoDVD today I got this message near the end of the installation. It appeared the first pop-up, clicked OK, appeared the second pop-up, clicked OK again, showed the pcouffin.sys dialog, then both pop-ups showed again and then the installation ended normally. The same also happened in ConverXtoVideo installation...
Installation problem fixed, please re-download…
Thank you for your report!
wtin
2.0.0.48 advanced editing windows
Post by wtin »
1. Start a new project. In this case, a blu ray.
2. Imported 10 MP4 files (720p).
3. They are supposed to be pan and scan, but the files are stretched like a letter box, so I clicked on [advanced editing] on the first file (first episode).
4. Fit method - choose [user defined], checked Symmetric values, and changed it to 140. Now the screen appears correctly (with black bars on both sides).
5. Clicked on drop down menu, choose [Save changes, and apply to whole project menu]. Another window pops up, choose [video setting], click OK.
The rest of the episode did not change.
wtin
2.0.0.48 DVD creation
Post by wtin »
[attachment=0]20046 screen 2.jpg[/attachment]Problem with 2.0048 still exists (from 2.0047). The \video folder are missing files that complete a valid DVD disk. Only VOB files created.
Dirkmaster
Post by Dirkmaster »
The latest beta (48) creates DVDs with no audio, even though source files have audio. If I click on the eng, I get Access violation at address 0147021A in module 'vsoVideoConverter.exe." Read of address 00000000.
Echuir
Re: New ConvertXtoVideo 2.0.0.50 BETA version
Post by Echuir »
The latest beta (50) when parsing chapters for extraction skips some of the chapters. I know it is not a read error because the DVD reads and plays with no problem.
Echuir wrote:The latest beta (50) when parsing chapters for extraction skips some of the chapters. I know it is not a read error because the DVD reads and plays with no problem.
what is the name of the DVD?
Echuir
Re: New ConvertXtoVideo 2.0.0.52 BETA version
Post by Echuir »
Fullmetal Alchemist Vols. 4,5,6.
I have temporarily ripped the whole sequence and use a video editor to crop out the episodes but this is not something I want to have to do often.
I was able to get other DVD's to work so it may just be something with these disks.
Re: New ConvertXtoVideo 2.0.0.53 BETA version
new beta posted
Cherryman
Post by Cherryman »
Claire wrote:new beta posted
Fine, but why must i renew my license in 2.0.0.53? :shock:
if yours is expired. did you enter your email . go the help/ enter key
