There is No Provided Resume Address
Schnooker
Post by Schnooker »
Hello.
My main PC died a few days ago, so I installed convertxtodvd 7 on an old HP 800 pc, and now the program keeps giving me the above error message in the burning dialog box.
I’ve tried with a few external burners, but the error persists, and the burning process hangs on 0%.
I’ve also tried saving the project and burning to ISO, and using external programs to burn.
I’ve also downgraded to a 2016 version, in the hope an older version may be kinder to the HP tower - but nothing works.
The external drives burn other files without fuss.
I can provide a log file tomorrow, but was wondering if there was a quick fix for this just now?
Many thanks.
Stephen
Re: There is No Provided Resume Address
Old system? Running what version Windows?
What version did you install?
Well, all these should be in log file so waiting for that.
Schnooker
Post by Schnooker »
Windows 10 Pro
Version 10.0.19043
HP EliteDesk 800 G1 DN
Convertxtodvd 7.0.0.69
:std_log='C:\Users\schno\AppData\Roaming\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_mainlog.20220130.142312.307.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=7.0.0.69
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
13:46:13.347 Info Total size 1005 Mb., Target size DVD5 4300 Mb., Occupation 23.39%
14:23:06.743 Info Disc name: "13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu"
13:46:13.779 Info Burned folder: "C:\Users\schno\OneDrive\Documents\ConvertXtoDVD\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu", Min. media size 1005 Mb.
13:46:13.345 Info Conversion completed in 00:03:56
13:46:12.553 Info "TITLE 1/1 (Global 1/1)" menu built successfully
13:45:55.100 Important Starting BD title menus encoding: [Memory load 62%] [Available virtual memory 3653 Mb.]
13:45:55.098 Info Building TITLE menu
13:42:16.372 Info [ ] Loop playback
13:42:16.371 Info [ ] Play titles one after the other
13:42:16.371 Info [ ] Don't create title menu for single video
13:42:16.370 Info [x] Return to title menu after titleset playback
13:42:16.369 Info [x] Skip root menu initially
13:42:16.369 Info [ ] Auto-start playback
13:42:16.368 Info Template: Metallic (open style), contains 4 page(s)
13:42:16.368 Group Video DVD menu options
13:42:16.368 Info Video DVD format: NTSC (30 Fps)
13:42:16.367 Info Output target size : DVD-5 (4300 MB)
13:42:16.367 Info Number of core(s) used for encoding : 4
13:42:16.366 Info Number of core(s) used for decoding : 4
13:42:16.366 Info [ ] Use 2 pass encoding
13:42:16.365 Info [ ] Use best video quality settings
13:42:16.365 Info [ ] Use hardware decoding (if possible)
13:42:16.364 Info Max simultaneous conversions: 4
13:42:16.364 Group Advanced encoding options
13:45:33.544 ------------ ****************************************File encoded successfully: VTS_04_1.VOB*****************************************
13:45:33.542 Info "ROOT 1/1 (Global 1/1)" menu built successfully
13:45:07.020 Important Starting BD root menu encoding: [Memory load 65%] [Available virtual memory 3551 Mb.]
13:45:07.015 Info Building ROOT menus using template: Metallic (open style)
13:45:06.970 Info DVD sectors written - video: 106663, audio: 3458, subtitle: 0
13:45:06.969 Info video #1 - Processed video frames: 7258 (7258 frames encoded, 0 frames dropped, 0 frames duplicated)
13:42:29.006 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[audio aac main audio 2 Ch. 44100Hz , 128 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 25.00Fps -> 29.97Fps, 9200Kbps]
+-[video h264 1280x720 16:9 yuv420p, 25.00Fps, 751Kbps ]
Output file: C:\Users\schno\OneDrive\Documents\ConvertXtoDVD\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu\VIDEO_TS\VTS_04_1.VOB (DVD NTSC)
Input file: D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\Air - André Rieu.mp4
Video filters used:
- DeInterlace filter: VSO
13:42:29.005 Important Starting video encoding: [Memory load 64%] [Available virtual memory 3553 Mb.]
13:42:28.848 Verbose FFmpeg Opening file D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\Air - André Rieu.mp4
13:42:16.360 Info Menu fit: Text size reduced from 27.00 to 21.00 in style "Captions in title menu pages"
13:42:16.311 Info Menu fit: Text size reduced from 36.00 to 28.00 in style "Title of title menu pages"
13:42:15.613 Verbose FFmpeg Opening file D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\Air - André Rieu.mp4
13:42:15.611 Group ******************** Titleset #4 - ~4 min. File: "Air - André Rieu" -> VTS_04_1.VOB - DVD NTSC ********************|GK_TITLESET|
13:45:54.631 ------------ ****************************************File encoded successfully: VTS_03_1.VOB*****************************************
13:45:54.629 Info "ROOT 1/1 (Global 1/1)" menu built successfully
13:45:41.120 Important Starting BD root menu encoding: [Memory load 64%] [Available virtual memory 3607 Mb.]
13:45:41.119 Info Building ROOT menus using template: Metallic (open style)
13:45:41.108 Info DVD sectors written - video: 130562, audio: 4100, subtitle: 0
13:45:41.107 Info video #1 - Processed video frames: 8606 (8606 frames encoded, 0 frames dropped, 0 frames duplicated)
13:42:24.657 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[audio [eng] aac main audio 2 Ch. 44100Hz , 128 Kbps]
+-[video h264 1280x720 16:9 yuv420p, 25.00Fps, 536Kbps ]
Output file: C:\Users\schno\OneDrive\Documents\ConvertXtoDVD\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu\VIDEO_TS\VTS_03_1.VOB (DVD NTSC)
Input file: D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\Ah, fors’e` lui che l’anima - André Rieu.mp4
Video filters used:
13:42:24.648 Important Starting video encoding: [Memory load 63%] [Available virtual memory 3596 Mb.]
13:42:24.575 Verbose FFmpeg Opening file D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\Ah, fors’e` lui che l’anima - André Rieu.mp4
13:42:15.472 Verbose FFmpeg Opening file D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\Ah, fors’e` lui che l’anima - André Rieu.mp4
13:42:15.471 Group ******************** Titleset #3 - ~5 min. File: "Ah, fors’e` lui che l’anima - André Rieu" -> VTS_03_1.VOB - DVD NTSC ********************|GK_TITLESET|
13:45:51.046 ------------ ****************************************File encoded successfully: VTS_02_1.VOB*****************************************
13:45:51.044 Info "ROOT 1/1 (Global 1/1)" menu built successfully
13:45:33.012 Important Starting BD root menu encoding: [Memory load 64%] [Available virtual memory 3575 Mb.]
13:45:33.011 Info Building ROOT menus using template: Metallic (open style)
13:45:32.998 Info DVD sectors written - video: 147638, audio: 3791, subtitle: 0
13:45:32.996 Info video #1 - Processed video frames: 7943 (7958 frames encoded, 0 frames dropped, 15 frames duplicated)
13:42:20.506 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[video h264 1280x720 16:9 yuv420p, 25.00Fps, 723Kbps ]
Output file: C:\Users\schno\OneDrive\Documents\ConvertXtoDVD\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu\VIDEO_TS\VTS_02_1.VOB (DVD NTSC)
Input file: D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\A Little Nightmusic - André Rieu.mp4
Video filters used:
13:42:20.505 Important Starting video encoding: [Memory load 62%] [Available virtual memory 3638 Mb.]
13:42:20.455 Verbose FFmpeg Opening file D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\A Little Nightmusic - André Rieu.mp4
13:42:15.334 Verbose FFmpeg Opening file D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\A Little Nightmusic - André Rieu.mp4
13:42:15.333 Group ******************** Titleset #2 - ~5 min. File: "A Little Nightmusic - André Rieu" -> VTS_02_1.VOB - DVD NTSC ********************|GK_TITLESET|
13:45:14.947 ------------ ****************************************File encoded successfully: VTS_01_1.VOB*****************************************
13:45:14.945 Info "ROOT 1/1 (Global 1/1)" menu built successfully
13:44:42.631 Important Starting BD root menu encoding: [Memory load 65%] [Available virtual memory 3563 Mb.]
13:44:42.629 Info Building ROOT menus using template: Metallic (open style)
13:44:42.558 Info DVD sectors written - video: 95589, audio: 3054, subtitle: 0
13:44:42.557 Info video #1 - Processed video frames: 6410 (6410 frames encoded, 0 frames dropped, 0 frames duplicated)
13:42:16.427 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1280x720 16:9 yuv420p, 25.00Fps, 619Kbps ]
Output file: C:\Users\schno\OneDrive\Documents\ConvertXtoDVD\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Input file: D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu.mp4
Video filters used:
13:42:16.426 Important Starting video encoding: [Memory load 61%] [Available virtual memory 3680 Mb.]
13:42:16.380 Verbose FFmpeg Opening file D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu.mp4
13:42:15.294 Info Menu fit: Text size reduced from 36.00 to 28.00 in style "Title of root menu pages"
13:42:15.114 Verbose FFmpeg Opening file D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu.mp4
13:42:15.112 Group ******************** Titleset #1 - ~4 min. File: "13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
13:42:15.108 Info Encoding options: Very short Project (Automatic)
13:42:15.107 Info Target size: 4300 Mb.
13:42:15.107 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
13:42:15.106 Important 4 simultaneous conversions allowed
13:42:15.105 Info Don't log FFMpeg log events
13:42:15.105 ------------ ***************************************************Burn settings end****************************************************
13:42:15.104 Info No default writer set
13:42:15.104 Info [ ] Delete vsomsl files after burn complete
13:42:15.104 Info [ ] Delete output folder after burn complete
13:42:15.103 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
13:42:15.103 Info SAO setting: Automatic
13:42:15.103 Info [x] Burn result to disk / as ISO file in working folder
13:42:15.102 ------------ **************************************************Burn settings begin***************************************************
13:42:15.102 Group Encoding session started at 1:42:15 PM: 4 titleset(s) to encode -> Completed in 00:03:56|GK_CONVERT_SESSION|
13:42:04.570 Important Loaded with result [File ]
13:42:04.041 Info Loading: "D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\Air - André Rieu.mp4 - File" 4/4
13:42:04.041 Info Loading: "D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\Ah, fors’e` lui che l’anima - André Rieu.mp4 - File" 3/4
13:42:04.040 Info Loading: "D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\A Little Nightmusic - André Rieu.mp4 - File" 2/4
13:42:04.040 Info Loading: "D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu.mp4 - File" 1/4
13:42:03.850 Info Sources filtered, found 4 protocols
13:42:03.682 Info Added protocol D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\Air - André Rieu.mp4, candidate 4/4
13:42:03.681 Info Added protocol D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\Ah, fors’e` lui che l’anima - André Rieu.mp4, candidate 3/4
13:42:03.681 Info Added protocol D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\A Little Nightmusic - André Rieu.mp4, candidate 2/4
13:42:03.680 Info Added protocol D:\Wondershare UniConverter 13\Downloaded\The Best Of André Rieu (HD)\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu.mp4, candidate 1/4
13:42:03.458 Info Found 4 candidates
13:42:03.068 Info Filtering sources
13:42:03.068 Group Loading file(s)
13:41:54.964 Info Personnal resources size (C:\Users\schno\OneDrive\Documents\ConvertXtoDVD_Resources\): 0MB, 0 file(s)
13:41:54.761 Info Monotonizer size (C:\ProgramData\vso\vsomsl): 0MB, 34 file(s)
13:41:54.558 Info Thumb cache size (C:\ProgramData\VSO\vsothumbs): 55MB, 50 file(s)
13:41:54.346 Info Logs and templates size (C:\ProgramData\VSO\ConvertXtoDVD\7\): 74MB, 666 file(s)
13:41:54.132 Group Folder data
13:41:54.120 Info Menu templates loaded: 20
13:41:53.239 Info License status: active customer license
13:41:53.238 Info License type: commercial (online activated)
13:41:53.238 Info Computer ID: 5114573
13:41:53.238 Group License
13:41:49.095 Info Loading templates from: "C:\Users\schno\OneDrive\Documents\ConvertXtoDVD_Resources\Templates\"
13:41:49.094 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\7\Templates\"
13:41:49.093 ------------ **************************ConvertXtoDvd.exe:1296 Log session start 2022-01-30 at 13:41:48.349***************************
14:11:41.877 Info Writable disc non removable disc inserted. Ready to write
^^^Repeated 2 Times in 1 second(s) 996 millisecond(s)^^^
14:11:39.814 Info New ISO path selected : C:\Users\schno\OneDrive\Documents\ConvertXtoDVD\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu.iso
^^^Repeated 2 Times in 2 second(s) 57 millisecond(s)^^^
14:11:31.765 Info Writable disc non removable disc inserted. Ready to write
14:11:29.758 Info New ISO path selected : C:\Users\schno\OneDrive\Documents\ConvertXtoDVD\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu.iso
13:46:15.813 Info Writable disc non removable disc inserted. Ready to write
^^^Repeated 2 Times in 2 second(s) 22 millisecond(s)^^^
13:46:13.793 Info New ISO path selected : C:\Users\schno\OneDrive\Documents\ConvertXtoDVD\13 Year Old Girl Playing Il Silenzio (The Silence) - André Rieu.iso
^^^Repeated 2 Times in 2 second(s) 14 millisecond(s)^^^
13:41:49.090 Info 1 writer(s) found.
13:41:49.065 Group Burn engine events
