Conversion Failed
ILoveVSO65
Conversion Failed
Post by ILoveVSO65 »
Ok, something must have changed. I never had any problems with convertxtodvd. Now for the past 3 days, I noticed when I try to convert series using 10 episodes it goes thru the process, and almost at the end, bingo convertxtodvd disappears. Can someone help? Again never had any problems before. I have win 10 64, i9 3.7, 64GB memory, 4tbssd drive. I have version 7.0.0.73. Thanks, anyone. Here is the log.
:crash_log='C:\Users\mmcrt\AppData\Roaming\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_crashlog.20210207.175354.332.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=7.0.0.73
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
18:46:10.198 Important Pausing task because memory is runnng low
18:45:28.235 Info "ROOT 1/1 (Global 1/3)" menu built successfully
18:43:40.264 Important Starting BD root menu encoding: [Memory load 21%] [Available virtual memory 738 Mb.]
18:43:40.259 Info Building ROOT, CHAPTERS, menus using template: Series (TV episodes)
18:43:39.784 Info DVD sectors written - video: 263816, audio: 32972, subtitle: 0
18:43:39.771 Info video #1 - Processed video frames: 66396 (66396 frames encoded, 0 frames dropped, 0 frames duplicated)
17:56:23.629 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[audio [eng] eac3 main audio 2 Ch. 48000Hz , 224 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 23.98Fps -> 29.97Fps, 1550Kbps]
+-[video hevc 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps ]
Output file: E:\ConvertXtoDvd\Law & OrderSeason 4 D2\VIDEO_TS\VTS_11_1.VOB (DVD NTSC)
Input file: D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x22 - Old Friends.mkv
Video filters used:
- DeInterlace filter: VSO
17:56:23.588 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:56:23.585 Important Starting video encoding: [Memory load 21%] [Available virtual memory 724 Mb.]
17:56:23.435 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x22 - Old Friends.mkv
17:55:34.693 Info Menu fit: Text size reduced from 13.00 to 13.00 in style "Captions in episode selection menu pages"
^^^Repeated 10 Times in 52 millisecond(s)^^^
17:55:34.687 Info Menu fit: Text size reduced from 18.00 to 13.00 in style "Captions in episode selection menu pages"
17:55:32.668 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x22 - Old Friends.mkv
17:55:32.667 Group ******************** Titleset #11 - ~46 min. File: "Law & Order - 4x22 - Old Friends" -> VTS_11_1.VOB - DVD NTSC ********************|GK_TITLESET|
17:57:54.805 Important Pausing task because memory is runnng low
17:57:53.249 Important Resuming paused task
17:57:40.175 Important Pausing task because memory is runnng low
17:57:38.420 Important Resuming paused task
17:57:25.437 Important Pausing task because memory is runnng low
17:57:23.721 Important Resuming paused task
17:57:11.212 Important Pausing task because memory is runnng low
17:57:09.621 Important Resuming paused task
17:56:56.909 Important Pausing task because memory is runnng low
17:56:55.146 Important Resuming paused task
17:56:41.567 Important Pausing task because memory is runnng low
17:56:19.719 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Output file: E:\ConvertXtoDvd\Law & OrderSeason 4 D2\VIDEO_TS\VTS_10_1.VOB (DVD NTSC)
Input file: D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x21 - Doubles.mkv
Video filters used:
17:56:19.707 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:56:19.704 Important Starting video encoding: [Memory load 21%] [Available virtual memory 983 Mb.]
17:56:19.586 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x21 - Doubles.mkv
17:55:32.501 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x21 - Doubles.mkv
17:55:32.500 Group ******************** Titleset #10 - ~46 min. File: "Law & Order - 4x21 - Doubles" -> VTS_10_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:46:10.190 Important Pausing task because memory is runnng low
18:45:17.492 Important Starting BD root menu encoding: [Memory load 21%] [Available virtual memory 821 Mb.]
18:45:17.485 Info Building ROOT, CHAPTERS, menus using template: Series (TV episodes)
18:45:17.311 Info DVD sectors written - video: 267967, audio: 33046, subtitle: 0
18:45:17.293 Info video #1 - Processed video frames: 66543 (66543 frames encoded, 0 frames dropped, 0 frames duplicated)
17:58:06.615 Important Resuming paused task
17:57:54.791 Important Pausing task because memory is runnng low
17:57:51.427 Important Resuming paused task
17:57:40.168 Important Pausing task because memory is runnng low
17:57:36.903 Important Resuming paused task
17:57:25.430 Important Pausing task because memory is runnng low
17:57:22.457 Important Resuming paused task
17:57:11.206 Important Pausing task because memory is runnng low
17:57:08.289 Important Resuming paused task
17:56:56.903 Important Pausing task because memory is runnng low
17:56:53.883 Important Resuming paused task
17:56:41.559 Important Pausing task because memory is runnng low
17:56:14.383 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Output file: E:\ConvertXtoDvd\Law & OrderSeason 4 D2\VIDEO_TS\VTS_09_1.VOB (DVD NTSC)
Input file: D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x20 - Nurture.mkv
Video filters used:
17:56:14.337 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:56:14.335 Important Starting video encoding: [Memory load 21%] [Available virtual memory 1266 Mb.]
17:56:14.221 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x20 - Nurture.mkv
17:55:32.337 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x20 - Nurture.mkv
17:55:32.336 Group ******************** Titleset #9 - ~46 min. File: "Law & Order - 4x20 - Nurture" -> VTS_09_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:46:10.183 Important Pausing task because memory is runnng low
18:45:41.157 Important Starting BD root menu encoding: [Memory load 22%] [Available virtual memory 636 Mb.]
18:45:41.152 Info Building ROOT, CHAPTERS, menus using template: Series (TV episodes)
18:45:40.970 Info DVD sectors written - video: 271609, audio: 33472, subtitle: 0
18:45:40.966 Info video #1 - Processed video frames: 67402 (67402 frames encoded, 0 frames dropped, 0 frames duplicated)
17:58:05.220 Important Resuming paused task
17:57:54.771 Important Pausing task because memory is runnng low
17:57:50.110 Important Resuming paused task
17:57:40.162 Important Pausing task because memory is runnng low
17:57:35.457 Important Resuming paused task
17:57:25.420 Important Pausing task because memory is runnng low
17:57:21.143 Important Resuming paused task
17:57:11.197 Important Pausing task because memory is runnng low
17:57:06.871 Important Resuming paused task
17:56:56.898 Important Pausing task because memory is runnng low
17:56:52.629 Important Resuming paused task
17:56:41.552 Important Pausing task because memory is runnng low
17:56:09.271 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Output file: E:\ConvertXtoDvd\Law & OrderSeason 4 D2\VIDEO_TS\VTS_08_1.VOB (DVD NTSC)
Input file: D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x19 - Sanctuary.mkv
Video filters used:
17:56:09.269 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:56:09.265 Important Starting video encoding: [Memory load 20%] [Available virtual memory 1546 Mb.]
17:56:09.165 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x19 - Sanctuary.mkv
17:55:32.171 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x19 - Sanctuary.mkv
17:55:32.170 Group ******************** Titleset #8 - ~46 min. File: "Law & Order - 4x19 - Sanctuary" -> VTS_08_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:46:10.175 Important Pausing task because memory is runnng low
18:45:07.132 Important Starting BD root menu encoding: [Memory load 22%] [Available virtual memory 554 Mb.]
18:45:07.129 Info Building ROOT, CHAPTERS, menus using template: Series (TV episodes)
18:45:06.921 Info DVD sectors written - video: 267855, audio: 33032, subtitle: 0
18:45:06.917 Info video #1 - Processed video frames: 66515 (66515 frames encoded, 0 frames dropped, 0 frames duplicated)
17:58:03.945 Important Resuming paused task
17:57:54.764 Important Pausing task because memory is runnng low
17:57:48.850 Important Resuming paused task
17:57:40.153 Important Pausing task because memory is runnng low
17:57:34.207 Important Resuming paused task
17:57:25.401 Important Pausing task because memory is runnng low
17:57:19.836 Important Resuming paused task
17:57:11.186 Important Pausing task because memory is runnng low
17:57:05.586 Important Resuming paused task
17:56:56.891 Important Pausing task because memory is runnng low
17:56:51.382 Important Resuming paused task
17:56:41.544 Important Pausing task because memory is runnng low
17:56:04.210 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Output file: E:\ConvertXtoDvd\Law & OrderSeason 4 D2\VIDEO_TS\VTS_07_1.VOB (DVD NTSC)
Input file: D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x18 - Wager.mkv
Video filters used:
17:56:04.207 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:56:04.203 Important Starting video encoding: [Memory load 20%] [Available virtual memory 1829 Mb.]
17:56:04.100 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x18 - Wager.mkv
17:55:32.005 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x18 - Wager.mkv
17:55:32.003 Group ******************** Titleset #7 - ~46 min. File: "Law & Order - 4x18 - Wager" -> VTS_07_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:46:10.167 Important Pausing task because memory is runnng low
18:45:16.415 Important Starting BD root menu encoding: [Memory load 22%] [Available virtual memory 621 Mb.]
18:45:16.404 Info Building ROOT, CHAPTERS, menus using template: Series (TV episodes)
18:45:16.233 Info DVD sectors written - video: 272603, audio: 33620, subtitle: 0
18:45:16.226 Info video #1 - Processed video frames: 67700 (67700 frames encoded, 0 frames dropped, 0 frames duplicated)
17:58:02.274 Important Resuming paused task
17:57:54.758 Important Pausing task because memory is runnng low
17:57:47.587 Important Resuming paused task
17:57:40.146 Important Pausing task because memory is runnng low
17:57:32.892 Important Resuming paused task
17:57:25.394 Important Pausing task because memory is runnng low
17:57:18.578 Important Resuming paused task
17:57:11.180 Important Pausing task because memory is runnng low
17:57:04.310 Important Resuming paused task
17:56:56.885 Important Pausing task because memory is runnng low
17:56:50.137 Important Resuming paused task
17:56:41.537 Important Pausing task because memory is runnng low
17:55:59.265 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Output file: E:\ConvertXtoDvd\Law & OrderSeason 4 D2\VIDEO_TS\VTS_06_1.VOB (DVD NTSC)
Input file: D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x17 - Mayhem.mkv
Video filters used:
17:55:59.263 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:55:59.250 Important Starting video encoding: [Memory load 19%] [Available virtual memory 2111 Mb.]
17:55:59.165 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x17 - Mayhem.mkv
17:55:31.839 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x17 - Mayhem.mkv
17:55:31.837 Group ******************** Titleset #6 - ~47 min. File: "Law & Order - 4x17 - Mayhem" -> VTS_06_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:46:10.160 Important Pausing task because memory is runnng low
18:46:01.032 Info "ROOT 1/1 (Global 1/3)" menu built successfully
18:44:54.033 Important Starting BD root menu encoding: [Memory load 21%] [Available virtual memory 718 Mb.]
18:44:54.030 Info Building ROOT, CHAPTERS, menus using template: Series (TV episodes)
18:44:53.885 Info DVD sectors written - video: 270903, audio: 33401, subtitle: 0
18:44:53.881 Info video #1 - Processed video frames: 67260 (67260 frames encoded, 0 frames dropped, 0 frames duplicated)
17:58:00.946 Important Resuming paused task
17:57:54.752 Important Pausing task because memory is runnng low
17:57:46.326 Important Resuming paused task
17:57:40.136 Important Pausing task because memory is runnng low
17:57:31.563 Important Resuming paused task
17:57:25.387 Important Pausing task because memory is runnng low
17:57:17.319 Important Resuming paused task
17:57:11.174 Important Pausing task because memory is runnng low
17:57:03.053 Important Resuming paused task
17:56:56.878 Important Pausing task because memory is runnng low
17:56:48.900 Important Resuming paused task
17:56:41.527 Important Pausing task because memory is runnng low
17:55:54.344 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Output file: E:\ConvertXtoDvd\Law & OrderSeason 4 D2\VIDEO_TS\VTS_05_1.VOB (DVD NTSC)
Input file: D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x16 - Big Bang.mkv
Video filters used:
17:55:54.343 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:55:54.341 Important Starting video encoding: [Memory load 19%] [Available virtual memory 2372 Mb.]
17:55:54.259 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x16 - Big Bang.mkv
17:55:31.674 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x16 - Big Bang.mkv
17:55:31.672 Group ******************** Titleset #5 - ~46 min. File: "Law & Order - 4x16 - Big Bang" -> VTS_05_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:46:05.360 Info "ROOT 1/1 (Global 1/3)" menu built successfully
18:44:47.105 Important Starting BD root menu encoding: [Memory load 22%] [Available virtual memory 524 Mb.]
18:44:47.102 Info Building ROOT, CHAPTERS, menus using template: Series (TV episodes)
18:44:46.873 Info DVD sectors written - video: 268250, audio: 33230, subtitle: 0
18:44:46.871 Info video #1 - Processed video frames: 66914 (66914 frames encoded, 0 frames dropped, 0 frames duplicated)
17:57:59.702 Important Resuming paused task
17:57:54.745 Important Pausing task because memory is runnng low
17:57:45.079 Important Resuming paused task
17:57:40.116 Important Pausing task because memory is runnng low
17:57:30.316 Important Resuming paused task
17:57:25.380 Important Pausing task because memory is runnng low
17:57:16.087 Important Resuming paused task
17:57:11.161 Important Pausing task because memory is runnng low
17:57:01.815 Important Resuming paused task
17:56:56.872 Important Pausing task because memory is runnng low
17:56:47.643 Important Resuming paused task
17:56:41.519 Important Pausing task because memory is runnng low
17:55:49.454 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Output file: E:\ConvertXtoDvd\Law & OrderSeason 4 D2\VIDEO_TS\VTS_04_1.VOB (DVD NTSC)
Input file: D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x15 - Kids.mkv
Video filters used:
17:55:49.452 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:55:49.451 Important Starting video encoding: [Memory load 19%] [Available virtual memory 2634 Mb.]
17:55:49.367 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x15 - Kids.mkv
17:55:31.507 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x15 - Kids.mkv
17:55:31.505 Group ******************** Titleset #4 - ~46 min. File: "Law & Order - 4x15 - Kids" -> VTS_04_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:46:10.148 Important Pausing task because memory is runnng low
18:44:31.245 Info "ROOT 1/1 (Global 1/3)" menu built successfully
18:42:20.038 Important Starting BD root menu encoding: [Memory load 21%] [Available virtual memory 774 Mb.]
18:42:20.035 Info Building ROOT, CHAPTERS, menus using template: Series (TV episodes)
18:42:19.643 Info DVD sectors written - video: 271252, audio: 33564, subtitle: 0
18:42:19.640 Info video #1 - Processed video frames: 67587 (67587 frames encoded, 0 frames dropped, 0 frames duplicated)
17:57:58.468 Important Resuming paused task
17:57:54.731 Important Pausing task because memory is runnng low
17:57:43.838 Important Resuming paused task
17:57:40.109 Important Pausing task because memory is runnng low
17:57:29.091 Important Resuming paused task
17:57:25.350 Important Pausing task because memory is runnng low
17:57:14.861 Important Resuming paused task
17:57:11.138 Important Pausing task because memory is runnng low
17:57:00.566 Important Resuming paused task
17:56:56.866 Important Pausing task because memory is runnng low
17:56:46.422 Important Resuming paused task
17:56:41.513 Important Pausing task because memory is runnng low
17:55:44.573 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Output file: E:\ConvertXtoDvd\Law & OrderSeason 4 D2\VIDEO_TS\VTS_03_1.VOB (DVD NTSC)
Input file: D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x14 - Censure.mkv
Video filters used:
17:55:44.572 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:55:44.570 Important Starting video encoding: [Memory load 18%] [Available virtual memory 2903 Mb.]
17:55:44.491 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x14 - Censure.mkv
17:55:31.342 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x14 - Censure.mkv
17:55:31.340 Group ******************** Titleset #3 - ~46 min. File: "Law & Order - 4x14 - Censure" -> VTS_03_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:46:10.140 Important Pausing task because memory is runnng low
18:44:51.637 Info "ROOT 1/1 (Global 1/3)" menu built successfully
18:43:01.213 Important Starting BD root menu encoding: [Memory load 21%] [Available virtual memory 942 Mb.]
18:43:01.131 Info Building ROOT, CHAPTERS, menus using template: Series (TV episodes)
18:43:00.340 Info DVD sectors written - video: 272379, audio: 33697, subtitle: 0
18:43:00.338 Info video #1 - Processed video frames: 67855 (67855 frames encoded, 0 frames dropped, 0 frames duplicated)
17:57:57.246 Important Resuming paused task
17:57:54.724 Important Pausing task because memory is runnng low
17:57:42.616 Important Resuming paused task
17:57:40.102 Important Pausing task because memory is runnng low
17:57:27.872 Important Resuming paused task
17:57:25.307 Important Pausing task because memory is runnng low
17:57:13.640 Important Resuming paused task
17:57:11.128 Important Pausing task because memory is runnng low
17:56:59.348 Important Resuming paused task
17:56:56.860 Important Pausing task because memory is runnng low
17:56:45.201 Important Resuming paused task
17:56:41.506 Important Pausing task because memory is runnng low
17:55:39.691 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Output file: E:\ConvertXtoDvd\Law & OrderSeason 4 D2\VIDEO_TS\VTS_02_1.VOB (DVD NTSC)
Input file: D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x13 - Breeder.mkv
Video filters used:
17:55:39.690 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:55:39.689 Important Starting video encoding: [Memory load 18%] [Available virtual memory 3162 Mb.]
17:55:39.629 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x13 - Breeder.mkv
17:55:31.177 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x13 - Breeder.mkv
17:55:31.175 Group ******************** Titleset #2 - ~47 min. File: "Law & Order - 4x13 - Breeder" -> VTS_02_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:46:10.081 Important Pausing task because memory is runnng low
18:45:49.170 Info "CHAPTERS 1/2 (Global 2/3)" menu built successfully
18:43:04.250 Info "ROOT 1/1 (Global 1/3)" menu built successfully
18:40:53.827 Important Starting BD root menu encoding: [Memory load 22%] [Available virtual memory 604 Mb.]
18:40:53.822 Info Building ROOT, CHAPTERS, menus using template: Series (TV episodes)
18:40:53.536 Info DVD sectors written - video: 266307, audio: 33309, subtitle: 0
18:40:53.534 Info video #1 - Processed video frames: 67073 (67073 frames encoded, 0 frames dropped, 0 frames duplicated)
17:57:56.028 Important Resuming paused task
17:57:54.682 Important Pausing task because memory is runnng low
17:57:41.396 Important Resuming paused task
17:57:39.999 Important Pausing task because memory is runnng low
17:57:26.651 Important Resuming paused task
17:57:25.244 Important Pausing task because memory is runnng low
17:57:12.420 Important Resuming paused task
17:57:11.085 Important Pausing task because memory is runnng low
17:56:58.126 Important Resuming paused task
17:56:56.814 Important Pausing task because memory is runnng low
17:56:43.981 Important Resuming paused task
17:56:41.468 Important Pausing task because memory is runnng low
17:55:34.836 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Output file: E:\ConvertXtoDvd\Law & OrderSeason 4 D2\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Input file: D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x12 - Snatched.mkv
Video filters used:
17:55:34.835 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:55:34.834 Important Starting video encoding: [Memory load 18%] [Available virtual memory 3437 Mb.]
17:55:34.774 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x12 - Snatched.mkv
17:55:31.004 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x12 - Snatched.mkv
17:55:31.002 Group ******************** Titleset #1 - ~46 min. File: "Law & Order - 4x12 - Snatched" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
17:55:30.995 Info Encoding options: Long Project (Automatic)
17:55:30.994 Info Target size: 7700 Mb.
17:55:30.991 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
17:55:30.990 Important 16 simultaneous conversions allowed
17:55:30.988 Info Don't log FFMpeg log events
17:55:30.987 ------------ ***************************************************Burn settings end****************************************************
17:55:30.986 Info No default writer set
17:55:30.985 Info [ ] Delete vsomsl files after burn complete
17:55:30.984 Info [ ] Delete output folder after burn complete
17:55:30.983 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
17:55:30.982 Info SAO setting: Automatic
17:55:30.981 Info [x] Burn result to disk / as ISO file in working folder
17:55:30.980 ------------ **************************************************Burn settings begin***************************************************
17:55:30.980 Group Encoding session started at 5:55:30 PM: 11 titleset(s) to encode|GK_CONVERT_SESSION|
17:55:24.093 Info User requested cancellation
17:55:25.271 Info Conversion cancelled after 00:00:12
17:55:12.819 Info [ ] Loop playback
17:55:12.818 Info [ ] Play titles one after the other
17:55:12.817 Info [ ] Don't create title menu for single video
17:55:12.816 Info [x] Return to title menu after titleset playback
17:55:12.815 Info [x] Skip root menu initially
17:55:12.814 Info [ ] Auto-start playback
17:55:12.814 Info Template: Series (TV episodes), contains 6 page(s)
17:55:12.814 Group Video DVD menu options
17:55:12.813 Info Video DVD format: NTSC (30 Fps)
17:55:12.812 Info Output target size : DVD-9 (7700 MB)
17:55:12.811 Info Number of core(s) used for encoding : 16
17:55:12.810 Info Number of core(s) used for decoding : 16
17:55:12.810 Info [ ] Use 2 pass encoding
17:55:12.809 Info [ ] Use best video quality settings
17:55:12.808 Info [x] Use hardware decoding (if possible)
17:55:12.807 Info Max simultaneous conversions: 16
17:55:12.807 Group Advanced encoding options
17:55:12.752 Info Menu fit: Text size reduced from 13.00 to 13.00 in style "Captions in episode selection menu pages"
^^^Repeated 10 Times in 49 millisecond(s)^^^
17:55:12.746 Info Menu fit: Text size reduced from 18.00 to 13.00 in style "Captions in episode selection menu pages"
17:55:10.721 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x22 - Old Friends.mkv
17:55:10.555 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x21 - Doubles.mkv
17:55:10.382 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x20 - Nurture.mkv
17:55:10.215 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x19 - Sanctuary.mkv
17:55:10.043 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x18 - Wager.mkv
17:55:09.875 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x17 - Mayhem.mkv
17:55:09.706 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x16 - Big Bang.mkv
17:55:09.532 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x15 - Kids.mkv
17:55:24.764 Warning File encoding cancelled by user: VTS_03_1.VOB - step preparing titles
17:55:24.585 Error [muxer][dvd]: Pulldown failed on GOP at PTS 606606, LBA 301, with 6 frames
17:55:24.763 Group FFmpeg encoder Log
17:55:22.607 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Video filters used:
17:55:22.606 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:55:22.605 Important Starting video encoding: [Memory load 18%] [Available virtual memory 2898 Mb.]
17:55:22.544 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x14 - Censure.mkv
17:55:09.365 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x14 - Censure.mkv
17:55:09.364 Group ******************** Titleset #3 - ~46 min. File: "Law & Order - 4x14 - Censure" -> VTS_03_1.VOB - DVD NTSC ********************|GK_TITLESET|
17:55:24.532 Warning File encoding cancelled by user: VTS_02_1.VOB - step preparing titles
17:55:24.337 Error [muxer][dvd]: Pulldown failed on GOP at PTS 2033031, LBA 2691, with 2 frames
17:55:24.531 Group FFmpeg encoder Log
17:55:17.745 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Video filters used:
17:55:17.745 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:55:17.743 Important Starting video encoding: [Memory load 18%] [Available virtual memory 3163 Mb.]
17:55:17.687 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x13 - Breeder.mkv
17:55:09.198 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x13 - Breeder.mkv
17:55:09.197 Group ******************** Titleset #2 - ~47 min. File: "Law & Order - 4x13 - Breeder" -> VTS_02_1.VOB - DVD NTSC ********************|GK_TITLESET|
17:55:24.295 Warning File encoding cancelled by user: VTS_01_1.VOB - step preparing titles
17:55:12.874 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Video filters used:
17:55:12.873 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
17:55:12.872 Important Starting video encoding: [Memory load 18%] [Available virtual memory 3442 Mb.]
17:55:12.825 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x12 - Snatched.mkv
17:55:09.026 Verbose FFmpeg Opening file D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x12 - Snatched.mkv
17:55:09.024 Group ******************** Titleset #1 - ~46 min. File: "Law & Order - 4x12 - Snatched" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
17:55:09.017 Info Encoding options: Long Project (Automatic)
17:55:09.017 Info Target size: 7700 Mb.
17:55:09.014 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
17:55:09.014 Important 16 simultaneous conversions allowed
17:55:09.011 Info Don't log FFMpeg log events
17:55:09.011 ------------ ***************************************************Burn settings end****************************************************
17:55:09.010 Info No default writer set
17:55:09.009 Info [ ] Delete vsomsl files after burn complete
17:55:09.009 Info [ ] Delete output folder after burn complete
17:55:09.008 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
17:55:09.007 Info SAO setting: Automatic
17:55:09.007 Info [x] Burn result to disk / as ISO file in working folder
17:55:09.006 ------------ **************************************************Burn settings begin***************************************************
17:55:09.006 Group Encoding session started at 5:55:09 PM: 11 titleset(s) to encode -> Cancelled after 00:00:12|GK_CONVERT_SESSION|
17:54:44.716 Important Loaded with result [File ]
17:54:44.187 Info Loading: "D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x22 - Old Friends.mkv - File" 11/11
17:54:44.187 Info Loading: "D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x21 - Doubles.mkv - File" 10/11
17:54:44.186 Info Loading: "D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x20 - Nurture.mkv - File" 9/11
17:54:44.185 Info Loading: "D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x19 - Sanctuary.mkv - File" 8/11
17:54:44.185 Info Loading: "D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x18 - Wager.mkv - File" 7/11
17:54:44.184 Info Loading: "D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x17 - Mayhem.mkv - File" 6/11
17:54:44.184 Info Loading: "D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x16 - Big Bang.mkv - File" 5/11
17:54:44.183 Info Loading: "D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x15 - Kids.mkv - File" 4/11
17:54:44.182 Info Loading: "D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x14 - Censure.mkv - File" 3/11
17:54:44.182 Info Loading: "D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x13 - Breeder.mkv - File" 2/11
17:54:44.181 Info Loading: "D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x12 - Snatched.mkv - File" 1/11
17:54:43.942 Info Sources filtered, found 11 protocols
17:54:43.798 Info Added protocol D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x22 - Old Friends.mkv, candidate 11/11
17:54:43.797 Info Added protocol D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x21 - Doubles.mkv, candidate 10/11
17:54:43.797 Info Added protocol D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x20 - Nurture.mkv, candidate 9/11
17:54:43.796 Info Added protocol D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x19 - Sanctuary.mkv, candidate 8/11
17:54:43.795 Info Added protocol D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x18 - Wager.mkv, candidate 7/11
17:54:43.795 Info Added protocol D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x17 - Mayhem.mkv, candidate 6/11
17:54:43.794 Info Added protocol D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x16 - Big Bang.mkv, candidate 5/11
17:54:43.794 Info Added protocol D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x15 - Kids.mkv, candidate 4/11
17:54:43.793 Info Added protocol D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x14 - Censure.mkv, candidate 3/11
17:54:43.792 Info Added protocol D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x13 - Breeder.mkv, candidate 2/11
17:54:43.792 Info Added protocol D:\Law & Order (1990) Season 4 S04 (1080p AMZN WEB-DL x265 HEVC 10bit EAC3 2.0 ImE)\Law & Order - 4x12 - Snatched.mkv, candidate 1/11
17:54:43.558 Info Found 11 candidates
17:54:43.183 Info Filtering sources
17:54:43.183 Group Loading file(s)
17:54:02.348 Info Personnal resources size (E:\New My Documents\ConvertXtoDVD_Resources\): 0MB, 0 file(s)
17:54:02.126 Info Monotonizer size (C:\ProgramData\vso\vsomsl): 0MB, 1 file(s)
17:54:01.910 Info Thumb cache size (C:\ProgramData\VSO\vsothumbs): 71MB, 128 file(s)
17:54:01.699 Info Logs and templates size (C:\ProgramData\VSO\ConvertXtoDVD\7\): 74MB, 663 file(s)
17:54:01.479 Group Folder data
17:54:01.472 Info Menu templates loaded: 20
17:54:00.639 Info License status: active customer license
17:54:00.639 Info License type: commercial (online activated)
17:54:00.638 Info Computer ID: 4499631
17:54:00.638 Group License
17:53:54.390 Info Loading templates from: "E:\New My Documents\ConvertXtoDVD_Resources\Templates\"
17:53:54.389 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\7\Templates\"
17:53:54.386 ------------ **************************ConvertXtoDvd.exe:36616 Log session start 2021-02-07 at 17:53:53.836**************************
17:53:54.382 Info 1 writer(s) found.
17:53:54.333 Group Burn engine events
Re: Conversion Failed
Try to uninstall. Restart your PC, then do a clean installation selecting the 3 options while installing.
Try to convert a different movie file and see how it goes.
