FORMATTING HARD DISK
Muthu
Post by Muthu »
Hi: Bought ConvertXtoDVD 7.0.0.69 last week. The software went up
to 7.0.0.73 beta.
My burner is not detected by the software most of the time.
I want to format my hard disk and bring my pc to its factory settings.
Will this action pose any problem in reinstalling 7.0.0.69 with the key?
Thanks for any reply.
Muthu
Re: FORMATTING HARD DISK
It shouldn't be a problem.
See here should you run into problems. Although, as I said you shouldn't.
