Unexpected behaviour
reddwarf4ever
Post by reddwarf4ever »
I created a project of 20 episodes, with a custom font, the ‘ moon’ template ( which I think is best for just about all my projects ) the background audio track was longer than I normally use.....4 minutes.....so I had to increase the video duration to 4 mins 10 seconds to avoid the video duration less than audio duration errro.
However although the project converted ok, I could not select any page except for the first one, it actually crashed VLC media player on my PC each time I clicked on a different page.....tried lots of ideas, nothing worked, then reduced the audio to 1 minute and the video duration to 1 min 10 seconds and everything works perfectly.
Is this a bug / program limitation that I wasn’t aware of ? Is there a max Audio / video duration which if exceeded messes up page selection ? And can it be fixed ?
Best wishes
Re: Unexpected behaviour
Hi there,
Audio on menu has not been working out well for users lately.
We'll check it out as soon as possible.
I'm adding this to the bug: https://bugs.vso-software.fr/view.php?id=13783
Cheers,
