Disc won't burn...
poseytroy76
Disc won't burn...
Post by poseytroy76 »
Can anyone assist and tell me why my disc will not burn? If its a bad file, how can I tell which file is bad?
:std_log='C:\Users\posey\AppData\Roaming\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_mainlog.20200124.100457.770.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=7.0.0.69
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
08:54:51.857 Info Conversion cancelled after 00:28:59
08:25:51.974 Info [ ] Loop playback
08:25:51.970 Info [ ] Play titles one after the other
08:25:51.965 Info [ ] Don't create title menu for single video
08:25:51.961 Info [x] Return to title menu after titleset playback
08:25:51.957 Info [ ] Skip root menu initially
08:25:51.952 Info [ ] Auto-start playback
08:25:51.948 Info Template: Metallic (open style), contains 4 page(s)
08:25:51.948 Group Video DVD menu options
08:25:51.943 Info Video DVD format: NTSC (30 Fps)
08:25:51.939 Info Output target size : DVD-5 (4300 MB)
08:25:51.935 Info Number of core(s) used for encoding : 8
08:25:51.930 Info Number of core(s) used for decoding : 8
08:25:51.926 Info [ ] Use 2 pass encoding
08:25:51.922 Info [ ] Use best video quality settings
08:25:51.917 Info [ ] Use hardware decoding (if possible)
08:25:51.912 Info Max simultaneous conversions: 8
08:25:51.912 Group Advanced encoding options
08:25:49.419 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\EBD-AlexanderGarrett-HunterVance.mp4
08:25:49.144 Error AV LOADER: can't find protocol for "C:\Users\posey\Downloads\Video\Halloween_Special_-_Hunter_Blake_Calvin_Pratt_Logan.mp4"
^^^Repeated 2 Times in 4 millisecond(s)^^^
08:54:47.112 Error AV LOADER: can't find protocol for "C:\Users\posey\Downloads\Video\Rocky_Tate_-_Finding_His_Best_Self.mp4"
^^^Repeated 2 Times in 24 millisecond(s)^^^
08:25:48.986 Error AV LOADER: can't find protocol for "C:\Users\posey\Downloads\Video\Rocky_Tate_-_Finding_His_Best_Self.mp4"
08:54:50.912 Warning File encoding cancelled by user: VTS_18_1.VOB - step preparing titles
08:54:50.751 Error [muxer][dvd]: Pulldown failed on GOP at PTS 2666664, LBA 1985, with 3 frames
08:54:50.907 Group FFmpeg encoder Log
08:54:36.998 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[audio aac main audio 2 Ch. 48000Hz , 192 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 24.00Fps -> 29.97Fps, 690Kbps]
+-[video h264 1280x720 16:9 yuv420p, 24.00Fps, 2498Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_18_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\8TB-JimmyAndrews-JacobHansen.mp4
Video filters used:
- DeInterlace filter: VSO
08:54:36.975 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
08:54:36.942 Important Starting video encoding: [Memory load 52%] [Available virtual memory 2773 Mb.]
08:54:36.701 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\8TB-JimmyAndrews-JacobHansen.mp4
08:25:48.839 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\8TB-JimmyAndrews-JacobHansen.mp4
08:25:48.807 Group ******************** Titleset #18 - ~24 min. File: "8TB: Jimmy Andrews & Jacob Hansen" -> VTS_18_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:54:50.652 Warning File encoding cancelled by user: VTS_17_1.VOB - step preparing titles
08:52:55.802 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[audio aac main audio 2 Ch. 48000Hz , 128 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, 29.97Fps, 690Kbps]
+-[video h264 1920x1080 16:9 yuv420p, 30.00Fps, 4010Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_17_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\SS-CurtisCameron-RomanCapellini.mp4
Video filters used:
08:52:55.718 Info Chapters to generate: 4 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, )
08:52:55.700 Important Starting video encoding: [Memory load 51%] [Available virtual memory 2910 Mb.]
08:52:54.538 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\SS-CurtisCameron-RomanCapellini.mp4
08:25:48.698 Warning Stream 3, none not found in C:\Users\posey\Downloads\Video\SS-CurtisCameron-RomanCapellini.mp4
08:25:48.671 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\SS-CurtisCameron-RomanCapellini.mp4
08:25:48.656 Group ******************** Titleset #17 - ~19 min. File: "SS: Curtis Cameron & Roman Capellini " -> VTS_17_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:54:50.433 Warning File encoding cancelled by user: VTS_16_1.VOB - step preparing titles
08:50:11.660 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 448000 bps]
+-[audio aac main audio 1 Ch. 44100Hz , 80 Kbps]
+-[video h264 1280x720 16:9 yuv420p, 15.00Fps, 2508Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_16_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\CBP-JakeMitchells-MichaelAllens.mp4
Video filters used:
08:50:11.620 Info Chapters to generate: 4 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, )
08:50:11.588 Important Starting video encoding: [Memory load 51%] [Available virtual memory 2914 Mb.]
08:50:11.016 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\CBP-JakeMitchells-MichaelAllens.mp4
08:25:48.435 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\CBP-JakeMitchells-MichaelAllens.mp4
08:25:48.340 Group ******************** Titleset #16 - ~16 min. File: "CBP: Jake Mitchells & Michael Allens" -> VTS_16_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:54:49.752 Warning File encoding cancelled by user: VTS_15_1.VOB - step preparing titles
08:45:53.099 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[audio aac main audio 2 Ch. 44100Hz , 128 Kbps]
+-[video h264 1280x720 16:9 yuv420p, 30.00Fps, 1281Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_15_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\FitnessFreak_bareback_fucks_Quin_Quire.mp4
Video filters used:
08:45:53.084 Info Chapters to generate: 7 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, )
08:45:53.073 Important Starting video encoding: [Memory load 51%] [Available virtual memory 2858 Mb.]
08:45:52.455 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\FitnessFreak_bareback_fucks_Quin_Quire.mp4
08:25:47.963 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\FitnessFreak_bareback_fucks_Quin_Quire.mp4
08:25:47.846 Group ******************** Titleset #15 - ~33 min. File: "FitnessFreak Barebacks Quin Quire" -> VTS_15_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:54:49.530 Warning File encoding cancelled by user: VTS_14_1.VOB - step preparing titles
08:54:48.827 Error [muxer][dvd]: Pulldown failed on GOP at PTS 102654552, LBA 65810, with 11 frames
08:54:49.486 Group FFmpeg encoder Log
08:44:25.863 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[audio aac main audio 2 Ch. 44100Hz , 192 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 23.98Fps -> 29.97Fps, 690Kbps]
+-[video h264 1280x720 16:9 yuv420p, 23.98Fps, 3155Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_14_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\HH-VincentOReilly-DaltonRiley.mp4
Video filters used:
08:44:25.854 Info Chapters to generate: 7 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, )
08:44:25.829 Important Starting video encoding: [Memory load 52%] [Available virtual memory 2763 Mb.]
08:44:25.605 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\HH-VincentOReilly-DaltonRiley.mp4
08:25:47.569 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\HH-VincentOReilly-DaltonRiley.mp4
08:25:47.485 Group ******************** Titleset #14 - ~32 min. File: "HH: Vincent OReilly & Dalton Riley" -> VTS_14_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:54:48.785 Warning File encoding cancelled by user: VTS_13_1.VOB - step preparing titles
08:42:40.342 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[audio [eng] aac main audio 2 Ch. 48000Hz , 128 Kbps]
+-[video [eng] h264 1920x1080 16:9 yuv420p, 30.00Fps, 3888Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_13_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\SS-BjornNykvist-AlexMorgan.mp4
Video filters used:
08:42:40.327 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
08:42:40.314 Important Starting video encoding: [Memory load 51%] [Available virtual memory 2919 Mb.]
08:42:39.909 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\SS-BjornNykvist-AlexMorgan.mp4
08:25:47.298 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\SS-BjornNykvist-AlexMorgan.mp4
08:25:47.206 Group ******************** Titleset #13 - ~21 min. File: "SS: Bjorn Nykvist & Alex Morgan" -> VTS_13_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:54:36.083 ------------ ****************************************File encoded successfully: VTS_12_1.VOB*****************************************
08:54:35.996 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
08:53:36.136 Info "ROOT 1/1 (Global 1/2)" menu built successfully
08:52:58.603 Important Starting BD root menu encoding: [Memory load 51%] [Available virtual memory 2913 Mb.]
08:52:58.597 Info Building ROOT & CHAPTERS, menus using template: Metallic (open style)
08:52:58.534 Info DVD sectors written - video: 55418, audio: 14974, subtitle: 0
08:52:58.529 Info video #1 - Processed video frames: 30149 (30150 frames encoded, 0 frames dropped, 1 frames duplicated)
08:41:47.189 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1280x720 16:9 yuv420p, 23.98Fps, 2455Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_12_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\FS-JoshMoore-DevinFranco.mp4
Video filters used:
08:41:47.167 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
08:41:47.142 Important Starting video encoding: [Memory load 52%] [Available virtual memory 2733 Mb.]
08:41:46.900 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\FS-JoshMoore-DevinFranco.mp4
08:25:47.068 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\FS-JoshMoore-DevinFranco.mp4
08:25:47.050 Group ******************** Titleset #12 - ~20 min. File: "FS: Josh Moore & Devin Franco" -> VTS_12_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:54:48.647 Warning File encoding cancelled by user: VTS_11_1.VOB - step preparing titles
08:37:03.563 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[video [eng] h264 1920x1080 16:9 yuv420p, 30.00Fps, 4989Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_11_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\BMR-SilverSteele-MattRyder.mp4
Video filters used:
08:37:03.544 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
08:37:03.537 Important Starting video encoding: [Memory load 51%] [Available virtual memory 2864 Mb.]
08:37:03.291 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\BMR-SilverSteele-MattRyder.mp4
08:25:46.893 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\BMR-SilverSteele-MattRyder.mp4
08:25:46.876 Group ******************** Titleset #11 - ~22 min. File: "BMR: Silver Steele & Matt Ryder" -> VTS_11_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:52:53.459 ------------ ****************************************File encoded successfully: VTS_10_1.VOB*****************************************
08:52:53.432 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
08:51:59.284 Info "ROOT 1/1 (Global 1/2)" menu built successfully
08:51:27.214 Important Starting BD root menu encoding: [Memory load 51%] [Available virtual memory 2942 Mb.]
08:51:27.195 Info Building ROOT & CHAPTERS, menus using template: Metallic (open style)
08:51:27.022 Info DVD sectors written - video: 61362, audio: 16700, subtitle: 0
08:51:27.009 Info video #1 - Processed video frames: 42025 (42027 frames encoded, 0 frames dropped, 2 frames duplicated)
08:36:26.388 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1280x720 16:9 yuv420p, 29.97Fps, 2498Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_10_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\8TB-AlanDavis-HunterGraham.mp4
Video filters used:
08:36:26.378 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
08:36:26.353 Important Starting video encoding: [Memory load 52%] [Available virtual memory 2824 Mb.]
08:36:26.135 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\8TB-AlanDavis-HunterGraham.mp4
08:25:46.699 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\8TB-AlanDavis-HunterGraham.mp4
08:25:46.615 Group ******************** Titleset #10 - ~23 min. File: "8TB: Alan Davis & Hunter Graham" -> VTS_10_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:50:10.267 ------------ ****************************************File encoded successfully: VTS_09_1.VOB*****************************************
08:50:10.223 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
08:48:32.183 Info "ROOT 1/1 (Global 1/2)" menu built successfully
08:47:43.069 Important Starting BD root menu encoding: [Memory load 51%] [Available virtual memory 2937 Mb.]
08:47:43.062 Info Building ROOT & CHAPTERS, menus using template: Metallic (open style)
08:47:42.979 Info DVD sectors written - video: 43650, audio: 11855, subtitle: 0
08:47:42.969 Info video #1 - Processed video frames: 29836 (29838 frames encoded, 0 frames dropped, 2 frames duplicated)
08:33:33.550 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[audio aac main audio 2 Ch. 44100Hz , 160 Kbps]
+-[video h264 1920x1080 16:9 yuv420p, 29.97Fps, 6142Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_09_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\PHX-EdwardFox-RyanTorres.mp4
Video filters used:
08:33:33.544 Info Chapters to generate: 4 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, )
08:33:33.535 Important Starting video encoding: [Memory load 52%] [Available virtual memory 2896 Mb.]
08:33:33.255 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\PHX-EdwardFox-RyanTorres.mp4
08:25:46.432 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\PHX-EdwardFox-RyanTorres.mp4
08:25:46.299 Group ******************** Titleset #9 - ~16 min. File: "PHX: Edward Fox & Ryan Torres" -> VTS_09_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:37:02.776 ------------ ****************************************File encoded successfully: VTS_08_1.VOB*****************************************
08:37:02.761 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
08:36:17.407 Info "ROOT 1/1 (Global 1/2)" menu built successfully
08:35:33.289 Important Starting BD root menu encoding: [Memory load 52%] [Available virtual memory 2892 Mb.]
08:35:33.255 Info Building ROOT & CHAPTERS, menus using template: Metallic (open style)
08:35:33.015 Info DVD sectors written - video: 55780, audio: 15147, subtitle: 0
08:35:32.972 Info video #1 - Processed video frames: 30532 (30533 frames encoded, 0 frames dropped, 1 frames duplicated)
08:26:27.360 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1280x720 16:9 yuv420p, 24.00Fps, 1331Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_08_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\BCH Brad 1st Time Fucking Man.mp4
Video filters used:
08:26:27.313 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
08:26:27.298 Important Starting video encoding: [Memory load 54%] [Available virtual memory 2938 Mb.]
08:26:27.006 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\BCH Brad 1st Time Fucking Man.mp4
08:25:46.055 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\BCH Brad 1st Time Fucking Man.mp4
08:25:45.934 Group ******************** Titleset #8 - ~21 min. File: "BCH: Brad 1st Time Fuckin Man" -> VTS_08_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:45:52.176 ------------ ****************************************File encoded successfully: VTS_07_1.VOB*****************************************
08:45:52.170 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
08:44:19.169 Info "ROOT 1/1 (Global 1/2)" menu built successfully
08:43:37.796 Important Starting BD root menu encoding: [Memory load 52%] [Available virtual memory 2841 Mb.]
08:43:37.777 Info Building ROOT & CHAPTERS, menus using template: Metallic (open style)
08:43:37.645 Info DVD sectors written - video: 71570, audio: 19492, subtitle: 0
08:43:37.637 Info video #1 - Processed video frames: 49109 (49062 frames encoded, 48 frames dropped, 1 frames duplicated)
08:26:22.109 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[audio [eng] aac main audio 2 Ch. 44100Hz , 128 Kbps]
+-[video [eng] h264 1280x720 16:9 yuv420p, 30.00Fps, 2906Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_07_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\CB-CarterDane-ShaneCook.mp4
Video filters used:
08:26:22.088 Info Chapters to generate: 6 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, )
08:26:22.075 Important Starting video encoding: [Memory load 53%] [Available virtual memory 2996 Mb.]
08:26:21.724 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\CB-CarterDane-ShaneCook.mp4
08:25:45.806 Warning Stream 3, none not found in C:\Users\posey\Downloads\Video\CB-CarterDane-ShaneCook.mp4
08:25:45.378 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\CB-CarterDane-ShaneCook.mp4
08:25:45.159 Group ******************** Titleset #7 - ~27 min. File: "CB: Carter Dane & Shane Cook" -> VTS_07_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:44:25.389 ------------ ****************************************File encoded successfully: VTS_06_1.VOB*****************************************
08:44:25.371 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
08:43:20.272 Info "ROOT 1/1 (Global 1/2)" menu built successfully
08:42:52.000 Important Starting BD root menu encoding: [Memory load 52%] [Available virtual memory 2916 Mb.]
08:42:51.983 Info Building ROOT & CHAPTERS, menus using template: Metallic (open style)
08:42:51.731 Info DVD sectors written - video: 58641, audio: 16032, subtitle: 0
08:42:51.694 Info video #1 - Processed video frames: 40354 (40354 frames encoded, 19746 frames dropped, 19746 frames duplicated)
08:26:16.929 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[video h264 1280x720 16:9 yuv420p, 29.97Fps, 3598Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_06_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\OF Kit Cohen BB Thyle Knoxx.mp4
Video filters used:
08:26:16.907 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
08:26:16.898 Important Starting video encoding: [Memory load 53%] [Available virtual memory 3037 Mb.]
08:26:16.601 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\OF Kit Cohen BB Thyle Knoxx.mp4
08:25:44.372 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\OF Kit Cohen BB Thyle Knoxx.mp4
08:25:44.204 Group ******************** Titleset #6 - ~22 min. File: "OF Kit Cohen BB Thyle Knoxx" -> VTS_06_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:33:32.519 ------------ ****************************************File encoded successfully: VTS_05_1.VOB*****************************************
08:33:32.498 Info "ROOT 1/1 (Global 1/1)" menu built successfully
08:32:56.365 Important Starting BD root menu encoding: [Memory load 52%] [Available virtual memory 2944 Mb.]
08:32:56.260 Info Building ROOT menus using template: Metallic (open style)
08:32:56.159 Info DVD sectors written - video: 17194, audio: 4582, subtitle: 0
08:32:56.116 Info video #1 - Processed video frames: 11546 (11536 frames encoded, 11 frames dropped, 1 frames duplicated)
08:26:12.087 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 1280x720 16:9 yuv420p, 30.00Fps, 14042Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_05_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\OF Julian Jaxon Santa Hat.mp4
Video filters used:
08:26:12.079 Important Starting video encoding: [Memory load 52%] [Available virtual memory 3080 Mb.]
08:26:11.640 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\OF Julian Jaxon Santa Hat.mp4
08:25:44.022 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\OF Julian Jaxon Santa Hat.mp4
08:25:43.925 Group ******************** Titleset #5 - ~6 min. File: "OF Julian Jaxon Santa Hat" -> VTS_05_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:36:25.831 ------------ ****************************************File encoded successfully: VTS_04_1.VOB*****************************************
08:36:25.812 Info "ROOT 1/1 (Global 1/1)" menu built successfully
08:35:37.139 Important Starting BD root menu encoding: [Memory load 52%] [Available virtual memory 2943 Mb.]
08:35:37.125 Info Building ROOT menus using template: Metallic (open style)
08:35:37.060 Info DVD sectors written - video: 33231, audio: 9028, subtitle: 0
08:35:37.042 Info video #1 - Processed video frames: 22722 (22725 frames encoded, 0 frames dropped, 3 frames duplicated)
08:26:06.660 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[audio [eng] aac main audio 2 Ch. 48000Hz , 224 Kbps]
+-[video h264 1920x1080 16:9 yuv420p, 29.97Fps, 4008Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_04_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\SWB-JavierSantiniBallsAreBack.mp4
Video filters used:
08:26:06.652 Important Starting video encoding: [Memory load 51%] [Available virtual memory 3155 Mb.]
08:26:06.574 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\SWB-JavierSantiniBallsAreBack.mp4
08:25:43.698 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\SWB-JavierSantiniBallsAreBack.mp4
08:25:43.623 Group ******************** Titleset #4 - ~12 min. File: "SWB: Javier Santini Balls" -> VTS_04_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:54:46.695 ------------ ****************************************File encoded successfully: VTS_03_1.VOB*****************************************
08:54:46.656 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
08:53:09.095 Info "ROOT 1/1 (Global 1/2)" menu built successfully
08:52:08.184 Important Starting BD root menu encoding: [Memory load 52%] [Available virtual memory 2909 Mb.]
08:52:08.174 Info Building ROOT & CHAPTERS, menus using template: Metallic (open style)
08:52:07.917 Info DVD sectors written - video: 52614, audio: 14303, subtitle: 0
08:52:07.909 Info video #1 - Processed video frames: 36000 (36001 frames encoded, 0 frames dropped, 1 frames duplicated)
08:26:01.899 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[audio [eng] aac main audio 2 Ch. 48000Hz , 112 Kbps]
+-[video h264 1920x1080 16:9 yuv420p, 29.97Fps, 4040Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_03_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\GB Dev Tyler & Lindo.mp4
Video filters used:
08:26:01.889 Info Chapters to generate: 4 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, )
08:26:01.884 Important Starting video encoding: [Memory load 51%] [Available virtual memory 3239 Mb.]
08:26:01.703 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\GB Dev Tyler & Lindo.mp4
08:25:43.478 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\GB Dev Tyler & Lindo.mp4
08:25:43.464 Group ******************** Titleset #3 - ~20 min. File: "GB: Dev Tyler & Lindo" -> VTS_03_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:42:39.166 ------------ ****************************************File encoded successfully: VTS_02_1.VOB*****************************************
08:42:39.126 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
08:40:21.394 Info "ROOT 1/1 (Global 1/2)" menu built successfully
08:39:32.312 Important Starting BD root menu encoding: [Memory load 51%] [Available virtual memory 2934 Mb.]
08:39:32.248 Info Building ROOT & CHAPTERS, menus using template: Metallic (open style)
08:39:31.943 Info DVD sectors written - video: 55902, audio: 15146, subtitle: 0
08:39:31.918 Info video #1 - Processed video frames: 31799 (31801 frames encoded, 0 frames dropped, 2 frames duplicated)
08:25:56.969 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[audio [eng] aac main audio 2 Ch. 48000Hz , 160 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 25.00Fps -> 29.97Fps, 690Kbps]
+-[video h264 1920x1080 16:9 yuv420p, 25.00Fps, 3970Kbps ]
Output file: C:\Users\posey\OneDrive\Documents\ConvertXtoDVD\WH Pavel Rakos\VIDEO_TS\VTS_02_1.VOB (DVD NTSC)
Input file: C:\Users\posey\Downloads\Video\WH-VovaBuchnev-EROTICSOLO.mp4
Video filters used:
08:25:56.965 Info Chapters to generate: 5 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, )
08:25:56.960 Important Starting video encoding: [Memory load 50%] [Available virtual memory 3327 Mb.]
08:25:56.863 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\WH-VovaBuchnev-EROTICSOLO.mp4
08:25:43.189 Verbose FFmpeg Opening file C:\Users\posey\Downloads\Video\WH-VovaBuchnev-EROTICSOLO.mp4
08:25:43.112 Group ******************** Titleset #2 - ~21 min. File: "WH: Vova Buchnev" -> VTS_02_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:41:46.667 ------------ ****************************************File encoded successfully: VTS_01_1.VOB*****************************************
08:41:46.626 Info "CHAPTERS 1/1 (Global 2/2)" menu built successfully
08:39:51.170 Info "ROOT 1/1 (Global 1/2)" menu built successfully
08:39:10.634 Important Starting BD root menu encoding: [Memory load 51%] [Available virtual memory 2912 Mb.]
08:39:10.616 Info Building ROOT & CHAPTERS, menus using template: Metallic (open style)
08:39:10.375 Info DVD sectors written - video: 55583, audio: 15049, subtitle: 0
08:39:10.318 Info video #1 - Processed video frames: 31595 (31597 frames encoded, 0 frames dropped, 2 frames duplicated)
08:39:10.260 Error [muxer][dvd]: Pulldown failed on GOP at PTS 113742000, LBA 73260, with 1 frames
08:39:10.311 Group FFmpeg encoder Log
08:25:52.079 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
Re: Disc won't burn...
Hi there,
Is it only happening with one movie?
Could you please try with:
-another file
-another disk
-another burner (external or different machine)
You could also try a clean/fresh install of our last version:
Tell me how it goes!
