Feature request Episode limitation
reddwarf4ever
Post by reddwarf4ever »
I have a series, where one of the series has 108 episodes, never seen this before, the episodes are very small, but never realised there is a 99 episode limitation. Had to burn to two disks as a result.....could this be increased to 199 maybe....
Re: Feature request Episode limitation
Hi there,
Please check the post from Jacques on this thread, you got all the info you need!
viewtopic.php?f=53&t=20693&p=103635#p103635
Cheers,
reddwarf4ever
So it’s a DVD limitation....so nothing can be done
Combine those; 3 episodes to one title, each episode will be a chapter in title. You end up with 36 titles.
reddwarf4ever
Complicated as each episode has a start and end sequence.....which needs editing out each time of the middle episode.....so easier use two disks
reddwarf4ever
Would be handy if you had an option for the OP to mark the post as Solved or Closed etc......helps when looking through posts, if closed or solved, then can be safely ignored, as help not needed
Very good idea!
I've added it: https://bugs.vso-software.fr/view.php?id=13836
