FILE on Project
rirussvso
FILE on Project
Post by rirussvso » Sat Mar 16, 2019 3:49 pm
I´m using ConvertX ver 7.0064 and I was wondering how to view or know where the video file used on project´s NAME and LOCATION of a saved project after it is loaded.
Thanks for the help
Re: FILE on Project
Post by JJ » Sun Mar 17, 2019 5:34 am
What do you mean?
File name and location is the same, original file stays where you loaded it from.
Conversion result is where you define in the settings.
