converts but won't burn
wheelsgirl
Post by wheelsgirl »
very recently my program started acting up...will convert but not burn. log says driver status code 22 can any one help?
thanks!
Re: converts but won't burn
wheelsgirl wrote:very recently my program started acting up...will convert but not burn. log says driver status code 22 can any one help?
thanks!
Have a look here:
https://www.lifewire.com/how-to-fix-cod ... rs-2619234
There is also the possibility that your DVD burner stopped working.
It would help if you post the log file.
wheelsgirl
nothing shows wrong in device manager...
:std_log='C:\ProgramData\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_mainlog.20180127.191111.050.log'
:library=false
:app_name=ConvertXtoDVD.exe
:app_version=7.0.0.52
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=stopped
:group_indent=4
19:11:08.863 ------------ **********ConvertXtoDVD.exe:9256 Log session stop after 1 hour(s) 5 minute(s) 34 second(s) 453 millisecond(s)***********
19:11:04.296 Info Removed segment: Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8
18:36:36.251 Info Total size 3685 Mb., Target size DVD5 4300 Mb., Occupation 85.72%
19:11:02.261 Info Disc name: "Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8"
18:36:36.975 Info Burned folder: "C:\Users\Patty\Documents\ConvertXToDVD\New folder\Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8", Min. media size 3.6 GB.
18:36:36.231 Info Conversion completed in 00:27:42
18:08:53.373 Info [ ] Loop playback
18:08:53.371 Info [x] Play titles one after the other
18:08:53.369 Info [x] Don't create title menu for single video
18:08:53.367 Info [x] Return to title menu after titleset playback
18:08:53.365 Info [ ] Skip root menu initially
18:08:53.364 Info [ ] Auto-start playback
18:08:53.362 Info Template: Cinema - navigation with buttons (one main video), contains 4 page(s)
18:08:53.362 Group Video DVD menu options
18:08:53.360 Info Video DVD format: NTSC (30 Fps)
18:08:53.359 Info Output target size : DVD-5 (4300 MB)
18:08:53.357 Info Number of core(s) used for encoding : 4
18:08:53.355 Info Number of core(s) used for decoding : 4
18:08:53.353 Info [ ] Use 2 pass encoding
18:08:53.352 Info [ ] Use best video quality settings
18:08:53.350 Info [ ] Use hardware decoding (if possible)
18:08:53.348 Info Max simultaneous conversions: 4
18:08:53.348 Group Advanced encoding options
18:36:35.267 ------------ ****************************************File encoded successfully: VTS_01_1.VOB*****************************************
18:36:35.262 Info "CHAPTERS 5/5 (Global 6/6)" menu built successfully
18:36:26.256 Warning [muxer][dvd]: subtitle #0 overlap of 24743 mS at 3.00 seconds
^^^Repeated 2 Times in 2 millisecond(s)^^^
18:36:22.481 Info "CHAPTERS 4/5 (Global 5/6)" menu built successfully
18:36:09.090 Warning [muxer][dvd]: subtitle #0 overlap of 24743 mS at 3.00 seconds
18:36:02.755 Info "CHAPTERS 3/5 (Global 4/6)" menu built successfully
18:35:50.699 Warning [muxer][dvd]: subtitle #0 overlap of 24743 mS at 3.00 seconds
18:35:46.093 Info "CHAPTERS 2/5 (Global 3/6)" menu built successfully
18:35:34.882 Warning [muxer][dvd]: subtitle #0 overlap of 24743 mS at 3.00 seconds
18:35:29.900 Info "CHAPTERS 1/5 (Global 2/6)" menu built successfully
18:35:18.979 Warning [muxer][dvd]: subtitle #0 overlap of 24743 mS at 3.00 seconds
18:35:13.774 Info "ROOT 1/1 (Global 1/6)" menu built successfully
18:35:04.621 Info Building ROOT, CHAPTERS, menus using template: Cinema - navigation with buttons (one main video)
18:35:04.148 Info DVD sectors written - video: 1750603, audio: 99938, subtitle: 0
18:35:04.145 Info video #1 - Processed video frames: 251531 (251531 frames encoded, 0 frames dropped, 0 frames duplicated)
18:08:53.875 Error [decoder][ac3]: frame sync error
18:08:53.860 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[audio ac3 main audio 2 Ch. 48000Hz , 256 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, 29.97Fps, 3730Kbps]
+-[video mpeg4 720x288 5:2 yuv420p, 29.97Fps, 1553Kbps ]
Output file: C:\Users\Patty\Documents\ConvertXToDVD\New folder\Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Input file: F:\dap downloads\Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8\Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8.avi
Video filters used:
- DeInterlace filter: VSO
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 70, bottom: 70, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
18:08:53.857 Info Chapters to generate: 28 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, 1h40m00s, 1h45m00s, 1h50m00s, 1h55m00s, 2h00m00s, 2h05m00s, 2h10m00s, 2h15m00s, )
18:08:53.848 Error [decoder][ac3]: frame sync error
18:08:53.099 Info Added in conversion queue list...
18:08:53.092 Info Menu fit: Text size reduced from 36.00 to 27.00 in style "Title of root menu pages"
18:08:52.450 Group ******************** Titleset #1 - ~139 min. File: "Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:08:52.419 Info Encoding options: Medium Project (Automatic)
18:08:52.415 Info Target size: 4.2 GB.
18:08:52.400 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
18:08:52.398 Important 4 simultaneous conversions allowed
18:08:52.397 Info Log FFMpeg warnings and errors
18:08:52.396 ------------ ***************************************************Burn settings end****************************************************
18:08:52.394 Info Default speed selected: 4x
18:08:52.393 Info [ ] Delete vsomsl files after burn complete
18:08:52.392 Info [ ] Delete output folder after burn complete
18:08:52.391 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
18:08:52.390 Info SAO setting: Automatic
18:08:52.389 Info [x] Burn result to disk / as ISO file in working folder
18:08:52.388 ------------ **************************************************Burn settings begin***************************************************
18:08:52.388 Group Encoding session started at 6:08:52 PM: 1 titleset(s) to encode -> Completed in 00:27:42|GK_CONVERT_SESSION|
18:08:48.220 Info #1 mpeg4 720x288 5:2 yuv420p, 29.97Fps, 1553Kbps
18:08:48.219 Group Video streams
18:08:48.219 Info #2 ac3 main audio 2 Ch. 48000Hz , 256 Kbps - Unspecified
18:08:48.219 Group Audio streams
18:08:48.219 Group Added file: F:\dap downloads\Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8\Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8.avi
18:08:48.181 Error [decoder][ac3]: frame sync error
18:08:47.730 Verbose FFmpeg Opening file F:\dap downloads\Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8\Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8.avi
18:08:47.728 Group File loading events
18:05:41.130 Info Menu templates loaded: 21
18:05:39.307 Info Command line: 0 parameter(s)
Param #00: "C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDVD.exe"
18:05:39.306 Info Total Physical Memory : 5982 Mb.
Available Physical Memory : 2513 Mb.
Memory Load : 57%
Available Virtual Memory : 3664 Mb.
Total Memory : 6942 Mb.
Available Memory : 2933 Mb.
18:05:39.306 Info Processor Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz with 16/8 core(s) CPU
18:05:39.298 Info User OS: Windows 10 Home, Microsoft Windows 10 Home Edition (Build 16299)
file name : C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDVD.exe
file version : 7.0.0.52
18:05:39.005 Info License status: active customer license
18:05:39.005 Info License type: commercial (online activated)
18:05:39.004 Info Computer ID: 167078
18:05:39.004 Group License
18:05:31.542 Info Loading templates from: "C:\Users\Patty\Documents\ConvertXtoDVD_Resources\Templates\"
18:05:31.541 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\7\Templates\"
18:05:31.540 ------------ **************************ConvertXtoDVD.exe:9256 Log session start 2018-01-27 at 18:05:29.843***************************
18:41:50.294 Error WRITE FAILED: near beginning at sector 32
18:41:46.745 Error An error occured in burning process. Drive status code: 22.
18:41:45.951 Error Unhandled error.
18:41:45.933 Info Sense at LBA 32 (32) - 05 30 05 [ILLEGAL REQUEST, cannot write medium, Incompatible format]
18:37:41.237 Info Write started 1887712 sectors to write
18:37:41.225 Info Init DVD-R DAO Success
18:37:36.143 Info Write speed set at x4.0 (5540 kB/s) CAV
18:37:36.092 Info Available write speed: x8.0 (11080 kB/s) CAV *, x4.0 (5540 kB/s) CAV
18:37:36.076 Info Media ID: CMC MAG. AM3
18:37:35.826 Info Scanned files #10, folder #2 - total size 3864924160 b. (3.6 GB.)
18:37:35.814 Info Inserted media type : dvd-r
18:37:35.787 Info Volume ID: Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8
18:37:35.774 Info Folder: C:\Users\Patty\Documents\ConvertXToDVD\New folder\Mollys.Game.2017.DVDScr.XVID.AC3.HQ.Hive-CM8\
18:37:35.762 Info Write started
18:37:34.036 Info DVD Video burn process started
18:37:19.631 Info Writable disc dvd-r inserted. Ready to write
18:37:09.481 Info Parsing disc ...
18:36:37.023 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
18:36:37.016 Info Drive has USB physical interface
18:36:37.015 Info New Drive selected : [G] HL-DT-ST DVDRAM GP60NB50 1.00 (USB)
18:05:31.537 Info 2 writer(s) found.
18:05:30.317 Group Burn engine events
"18:05:31.537 Info 2 writer(s) found"
Does this happen on both writers ?
Check if you have the correct writer selected.
I also have 2 writers. I use Nero for burning. Some times for some unknown reason the software picks the wrong writer which gives a no media error. This happens very rarely.
You should also update to the latest version which is 7.0.0.56
http://download.vso-software.fr/archive ... 0.0.56.exe
reddwarf4ever
Post by reddwarf4ever »
I never burn with convertxtodvd, I use BurnAware free.....
Good luck
joyescape
Post by joyescape »
I've using Nero Burning ROM for quite some time now
Try better media, you have one of the worst one:
