convertxtodvd 7
kitkat9918
convertxtodvd 7
Post by kitkat9918 »
how come there is no activation key for the software like the other ones had and will there be any keys to use for CONVERTXTODVD 7.0055
felicia
Re: convertxtodvd 7
Post by felicia »
I don't understand your question, there's still an unlock key system
kitkat9918
Re: convertxtodvd 7
i can't find the unlock key for convertxtodvd 7.0055 and the patch doesn't work on 7.0054 either plus i'm only seeing beta versions of these
Re: convertxtodvd 7
kitkat9918 wrote:i can't find the unlock key for convertxtodvd 7.0055 and the patch doesn't work on 7.0054 either plus i'm only seeing beta versions of these
What unlock key and patch are you writing about ? If you have the paid version of CXtoDVD 7.0.0.54 then key will still work for version 7.0.0.55
kitkat9918
Re: convertxtodvd 7
i don't have a paid version of convertxtodvd i downloaded it from a download site and the only ones they have are in beta testing with a patch or a crack to run it or their just trial ones
Re: convertxtodvd 7
kitkat9918 wrote:i don't have a paid version of convertxtodvd i downloaded it from a download site and the only ones they have are in beta testing with a patch or a crack to run it or their just trial ones
I hope you are joking, because you should know that such sites have pirated software which can get you into legal problems. Beside, patches and cracks can carry viruses which can harm your computer. You should also know that this is the official forum hosted by VSO.
Ch3vr0n
Re: convertxtodvd 7
Post by Ch3vr0n »
Buy CXD then come back. You've got balls asking for a "new crack" on the official product forums. Buy a license then come back. We can't and won't help you.
Desktop: Project Phoenix
