problem on creating a disv
wellandman
Post by wellandman »
let me explain first
i have 6 video files and have renamed this to part 1 part 2 part 3 in the original folder
when i import the 6 files from that folder
the menu now says downloaded from wwe.fromhere.etc on each one - and not part 1 part 2 etc
i don't think an older version did this
how can i auto correct this in the settings
Re: problem on creating a disv
Let me see if I understand you correctly:
So you had six movie files inside a folder and before importing them to ConvertXtoDVD, you have renamed each as part 1 to part 6 ?
wellandman
yes that ia right but convert x remames to downloaded.from.here.dotcom etc instead of part1 part 2 etc where convertx6 did not
felicia
Post by felicia »
In the General settings uncheck the option "Import file metadata when loading files". What you see appearing as title is extracted from the file metadata
Thanks Felicia. You beat me to the reply.
