Success at burning DVD, but tons of "Write Sucess at #2 try"
Valkur
Post by Valkur » Thu Mar 16, 2017 8:40 pm
I have been burning DVD for like 4 weeks, but I have bought a new ASUS dvdburner since yesterday. Didn't have any problem in the first 2 burns, but after that I keep geting lots of these "Write Sucess at #2 Try", and it freaks the hell out of me, as the DVD is correctly burned (I have watched an enterly DVD and haven't noticed any flaws). Anyway, I was wondering if this problem can effectively affect the quality of the dvd-write, and if there's something I can do to fix this.
As additional information, I have changed SATA and power cables several times, switching the ones in my HDDs back and forth. Also, I'm burning several types of videos, MKV, AVI, MP4 and others, and I have the same problem with all of them. I was using an external DVD-Writer and didn't have this problem. Thank you for reading.
":ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
16:17:23.859 Info Total size 4048 Mb., Target size DVD5 4300 Mb., Occupation 94.14%
16:29:01.119 Info Disc name: "Microbe.et.Gasoil.2015.720p.BRRip.x264.AC3.HORiZON-ArtSubs"
16:17:24.275 Info Burned folder: "C:\Users\valra\Documents\ConvertXtoDVD\Microbe.et.Gasoil.2015.720p.BRRip.x264.AC3.HORiZON-ArtSubs", Min. media size 3,95 Gb.
16:17:23.854 Info Conversion completed in 00:48:50
15:28:34.804 Info Writable disc dvd-r inserted. Ready to write
15:28:33.136 Info [ ] Loop playback
15:28:33.134 Info [x] Play titles one after the other
15:28:33.133 Info [ ] Return to title menu after titleset playback
15:28:33.131 Info [x] Skip root menu initially
15:28:33.130 Info [x] Auto-start playback
15:28:33.129 Info No menu generated
15:28:33.129 Group Video DVD menu options
15:28:33.128 Info Output target size : DVD-5 (4300 MB)
15:28:33.126 Info Number of core(s) used for encoding : 4
15:28:33.125 Info Number of core(s) used for decoding : 4
15:28:33.124 Info [ ] Use 2 pass encoding
15:28:33.123 Info [x] Use best video quality settings
15:28:33.122 Info [ ] Use hardware decoding (if possible)
15:28:33.121 Info Max simultaneous conversions: 4
15:28:33.121 Group Advanced encoding options
16:17:23.692 ------------ ****************************************File encoded successfully: VTS_01_1.VOB*****************************************
16:17:23.690 Info subtitle #3 - Encoded subtitles frames: 1417
16:17:23.687 Info DVD sectors written - video: 1984356, audio: 74002, subtitle: 1674
16:17:23.684 Info video #1 - Processed video frames: 149157 (186277 frames encoded, 0 frames dropped, 37120 frames duplicated)
15:28:33.212 Info Chapters to generate: 12
15:28:33.115 Info Added in conversion queue list...
15:28:33.098 Group ******************** Titleset #1 - ~103 min. File: "Microbe.et.Gasoil.2015.720p.BRRip.x264.AC3.HORiZON-ArtSubs" -> VTS_01_1.VOB - DVD NTSC Video structure ********************|GK_TITLESET|
15:28:33.097 Info Encoding options: Short Projects
15:28:33.096 Info Target size: 4,20 Gb.
15:28:32.959 Info Don't log FFMpeg log events
15:28:32.957 ------------ ***************************************************Burn settings end****************************************************
15:28:32.956 Info Default speed selected: 8x
15:28:32.955 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1)
15:28:32.954 Info Drive has Serial ATA physical interface
15:28:32.954 Info New Drive selected : 1 - ASUS DRW-24F1ST c 1.01 [E:]
15:28:32.953 Info [ ] Delete vsomsl files after burn complete
15:28:32.952 Info [ ] Delete output folder after burn complete
15:28:32.951 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
15:28:32.950 Info SAO setting: Automatic
15:28:32.949 Info [x] Burn result to disk / as ISO file in working folder
15:28:32.949 ------------ **************************************************Burn settings begin***************************************************
15:28:32.949 Group Conversion to "Encoding session started at 3:28:32 p. m.: 1 titleset(s) to encode" started at 3:28:33 p. m.: 1 sequence(s) to encode -> Completed in 00:48:50|GK_CONVERT_SESSION|
15:28:12.028 Info Added stream "Subtitle: srt" in file "C:\Users\valra\Desktop\DVDS QUEMAR\Bajados\Microbe et Gasoil\Microbe.Et.Gasoil.2015.FRENCH.BRRiP.XviD-Slay3R.srt" to titleset "Microbe.et.Gasoil.2015.720p.BRRip.x264.AC3.HORiZON-ArtSubs"
15:28:07.408 Hint File "file://C:\Users\valra\Desktop\DVDS QUEMAR\Bajados\Microbe et Gasoil\Microbe.Et.Gasoil.2015.FRENCH.BRRiP.XviD-Slay3R.srt" ignored. Ancillary files will eventually be loaded later.
15:28:07.408 Group Ignored file(s)
15:28:07.273 Info #1 Video: h264 (High), yuv420p, 1200x720 [PAR 1:1 DAR 5:3]
15:28:07.272 Group Video streams
15:28:07.272 Info #2 Audio: ac3, 48000 Hz, 6 channels, fltp, 640 kb/s - French
15:28:07.272 Group Audio streams
15:28:07.272 Group Added file: C:\Users\valra\Desktop\DVDS QUEMAR\Bajados\Microbe et Gasoil\Microbe.et.Gasoil.2015.720p.BRRip.x264.AC3.HORiZON-ArtSubs.mkv
15:27:58.205 Info Menu templates loaded: 37
15:27:56.081 Info Total Physical Memory : 6108 Mb.
Available Physical Memory : 4572 Mb.
Memory Load : 25%
Available Virtual Memory : 1744 Mb.
Total Memory : 7132 Mb.
Available Memory : 5657 Mb.
15:27:56.078 Info Processor Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz with 4 core(s) CPU
Supported instruction set: MMX,sse,sse2,sse3,ssse3,sse41,sse42,avx
15:27:56.066 Info OS : Windows 8 (64 bits), Build 0, service pack 0.0
file name : C:\Program Files (x86)\VSO\ConvertX\5\ConvertXtoDvd.exe
file version : 5.2.0.7
User language : Español (Bolivia)
System language : Español (Bolivia)
15:27:52.604 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\5\templates"
15:27:52.602 ------------ **************************ConvertXtoDvd.exe:6612 Log session start 2017-03-16 at 15:27:52.255***************************
16:28:58.460 Info Disc ejected by user.
16:28:51.917 Info Burning process completed successfully.
16:28:51.899 Info WRITE SUCCESS: Disc written
16:28:51.879 Info Finalization Time 0:11 - Total completion time 10:46
16:28:50.770 Info Finalise: Finalisation completed
16:28:50.751 Info Finalise: Flush device cache - Completed
16:28:39.133 Info Finalise: Flushing burner cache
16:28:39.047 Info Write finished in 10:34 - Finalization start here. Avg. burn rate 4.83
16:28:39.030 Info Finalise: Start disc finalisation
16:18:30.687 Info Write success at try #2
^^^Repeated 332 Times in 10 minute(s) 7 second(s) 951 millisecond(s)^^^
16:18:28.652 Info WRITING: Lead-in burning time required 0:24.366
16:18:22.521 Info Write success at try #2
^^^Repeated 4 Times in 6 second(s) 124 millisecond(s)^^^
16:18:04.298 Info Write started 2073136 sectors to write
16:18:04.281 Info Init DVD-R DAO Success
16:17:38.698 Info Write speed set at x6,0 (8310 kB/s)
16:17:38.627 Info Available write speed: x8,0 (11080 kB/s) *, x6,0 (8310 kB/s)
16:17:38.618 Info Media ID: GSC003
16:17:38.496 Info Scanned files #10, folder #2 - total size 4244670464 b. (3,95 Gb.)
16:17:38.488 Info Inserted media type : dvd-r
16:17:38.453 Info Volume ID: Microbe.et.Gasoil.2015.720p.BRRip.x264.AC3.HORiZON-ArtSubs
16:17:38.433 Info Folder: C:\Users\valra\Documents\ConvertXtoDVD\Microbe.et.Gasoil.2015.720p.BRRip.x264.AC3.HORiZON-ArtSubs\
16:17:38.418 Info Write started
16:17:26.390 Info Writable disc dvd-r inserted. Ready to write
16:17:26.322 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1)
16:17:26.314 Info Drive has Serial ATA physical interface
16:17:26.308 Info New Drive selected : 1 - ASUS DRW-24F1ST c 1.01 [E:]
16:17:24.294 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1)
16:17:24.294 Info Drive has Serial ATA physical interface
16:17:24.293 Info New Drive selected : 1 - ASUS DRW-24F1ST c 1.01 [E:]
15:28:14.699 Info Writable disc dvd-r inserted. Ready to write
15:27:58.557 Info Parsing disc ...
15:27:52.598 Info 1 writer(s) found.
15:27:52.594 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1)
15:27:52.591 Info Drive has Serial ATA physical interface
15:27:52.589 Info New Drive selected : 1 - ASUS DRW-24F1ST c 1.01 [E:]
15:27:52.550 Group Burn engine events"
ROBERT46055
Re: Success at burning DVD, but tons of "Write Sucess at #2
Post by ROBERT46055 » Fri Mar 17, 2017 2:45 am
your having SAME PROBLEM AS ME! write success at try 2# i have a Samsung DVD writer that i bought of of retail bran new owe well :oops:
