Subtitle font size
Hasbro
Subtitle font size
Post by Hasbro »
Hi guys I need to know what font size you recommend to use for convert to dvd and watch it on tv led? because so far I get convert some dvds with perfect size but yesterday I just modify de font size and I can´t remember how was it?
I just install last release 6.0.90 and I can see on font that says 40 but in preview screen the subtitle appears some big maybe its me but I need to know
Thank you in advance
Re: Subtitle font size
In the top menu of the application if you go to Default Settings and in that new window in the bottom left hand corner you can press "Reset to VSO defaults" to go back to the original settings. This should go back to the original settings (before you changed the font)
