Hebrew subs problem
labadimdsi
Hebrew subs problem
Post by labadimdsi »
Hello guys,
I am not new to ConvertXtoDVD, but I now have a new registered version 6.0.0.90 and am having problem with Hebrew subs.
The last letter of a sentence in a subtitle appears as the first letter in the next subtitle, causing some chaos with the text.
I tried changing the encoding but despite choosing various Hebrew encoding types this problem persists.
I will be grateful if you offer me some help.
BTW - when I go into the subtitles test rendering settings menu, the code page does not open (it appears to open and immediately close again) - looks like a bug to me.
Best regards!!
labadimdsi
felicia
Re: Hebrew subs problem
Post by felicia »
Could you post the subtitle file?
Is the problem visible in the preview?
labadimdsi
Yes, the problem is visible in the preview as well.
I can't upload the file - I get an error message saying the extension srt is not allowed. I tried changing the extension ofr the upload but I get the same error message.
Thank you for your kind help.
felicia
Post by felicia »
labadimdsi wrote:Yes, the problem is visible in the preview as well.
Just change the extension or zip the file, this should do the trick
labadimdsi
Here is the zipped file of the Hebrew subs.
The nature of the problem: last character of a subtitle is forwarded to the beginning of the next subtitle shown.
I would appreciate your help with this.
Regards!!
Allied.2016.720p.BRRip.XviD.AC3-RARBG.zip
(23.76 KiB) Downloaded 374 times
felicia
Post by felicia »
Thank you very much, both issues have been confirmed.
We will post in this thread as soon as a fix is available.
labadimdsi
Great thanks. Looking forward to getting your next update.
Regards!
:roll:
labadimdsi
Any news?
Thanks a lot!
felicia
Post by felicia »
In order to fix your issue with Hebrew subtitles you have to pick a special code page.
In the Default settings menu, select "subtitles" then click on "Subtitle text rendering settings", then check "Show more code pages" and select "Macintosh Hebrew" from the drop down. Finally click OK.
This should set the correct code page for your subtitles.
Felicià
labadimdsi
Wonderful! that did the trick. It is OK now.
Many thanks for your attention to this issue and fast resolving it.
Regards and Shalom
labadimdsi
Well, there is still a small problem.
Sentences of Hebrew subtitles marked by <i> appear in gibberish.
your attention to this issue would be appreciated.
Many thanks again
Regards!
felicia
Post by felicia »
labadimdsi wrote:Well, there is still a small problem.
Many thanks again
Regards!
Sorry for the delay. I can't reproduce the issue with subtitle file you provided. can you send us another file showing the issue?
BR,
labadimdsi
Many thanks again
Regards!
BR,
Here is a zipped file. See for example lines 1-4, 88, 89, 97 that appear in gibberish (simple text in Hebrew, not in italic or bold, appears OK).
Thank you.
Lion.2016.720p.BRRip.XviD.AC3-RARBG.zip
(18.41 KiB) Downloaded 142 times
