Re not,alike audio suggestion
reddwarf4ever
Post by reddwarf4ever » Fri Feb 03, 2017 1:15 pm
I don't want to normalise all my episode audio, as they are all the same, but the background audio for the title menu is often sourced elsewhere and as such the volume level,can be higher or lower, wonder if it's possible to,have an automatic volume adjustment of the title track to match the volume derived from one of the episode tracks, or an average...
Re: Re not,alike audio suggestion
Post by Claire » Fri Feb 03, 2017 1:39 pm
The best solution is to convert that one file like with ConvertXtoVideo, (open advanced editor) play the file and adjust the audio volume until it compares with one of your episodes loaded in ConvertXDVD. The preview of ConvertXtoVideo will reflect the volume level changes you are making. Convert in ConvertXtoVideo then load to be used for your menu in ConvertXtoDVD
reddwarf4ever
Post by reddwarf4ever » Fri Feb 03, 2017 1:49 pm
Hello
Yes that will work, it's just when listening to,one track then loading in the next, comparison becomes difficult, hoped there was a way of measuring each volume, or a tool to do that.
