I seem to be having a problem with ConvertXToDVD's project name not changing after a conversion and overwriting the previous ISO.
Example:
I am creating a DVD which will burn an ISO, with the project name "Name1".
After the ISO has been created I change the title name to "Name2" and start the next conversion.
When burning the new ISO, the old title (Name1) is used instead of the “Name2” title I have given it.
This means the new ISO will overwrite the previous one, as they have the same name.
This is obviously a big problem when using VsoBatcher.
If I load 5 projects, when it is finished there will only be one ISO with the title name of the first project.
Any help would be greatly appreciated.
Harry
ConvertXToDVD is Overwriting the ISO from previous project
Re: ConvertXToDVD is Overwriting the ISO from previous proje
@ Harry,
What you can do for the moment, untill a member of the VSO team checks your peoblem. Rename the iso file manually. That way it will not be overwritten. Happy festive season to you.
PS.
I have just checked the bugs report and somthing very similar to what you discribe is in the list for future fixes.
PS.
That's great. Thank you very much.
Happy New Year!
Happy New Year!
There are similar bugs related but uncertain they are you exact case related to burning I have opened a bug report for the issue you've explained here
http://bugs.vso-software.fr/view.php?id=12322
should now be fixed in latest beta http://forums.vso-software.fr/convertxt ... 19342.html
