Can't change Disc Label
Samuel
Post by Samuel » Thu Dec 01, 2016 10:45 pm
I initially named a project Two small videos but changed it to Two short Videos.
I have changed the name of The project as well as The title text in the menu but the Disc Label doesn't change.
The name of the videos in the menu is totally different from the two above mentioned names.
The General setting - Burning - Default project name (also used for disk Label) text field is empty.
How do I go about to change it?
Re: Can't change Disc Label
Post by Claire » Tue Dec 27, 2016 9:41 am
this is a bug to be fixed
http://bugs.vso-software.fr/view.php?id=12322
until it is expanded the first item in the treeview by clicking on the + (on the lefft) and click on "disc name" and edit there, you will have to make sure project name and disc name both are how you want them.
Post by Claire » Wed Feb 01, 2017 4:44 pm
