ConvertXtoDVD - beta version 6.0.0.90
Latest official release: v6.0.0.90
https://www.vso-software.fr/products/convert_x_to_dvd/
Latest beta 6.0.0.90 ---> now version 7
http://forums.vso-software.fr/convertxt ... 19534.html
Please post problems related to this new build here in this thread, thanks for your help and feedback!
History
ConvertXtoDVD - 6.0.0.90
- 0012633: [Bug] Audio normalization - Disable remux when normalization is requested (felicia) - resolved.
- 0012593: [Bug] When both add chapters every X mins and use original chapter points are selected, both are added to video (felicia) - resolved.
- 0010952: [Information] navigate using arrows in global settings does not update display in left panel (felicia) - resolved.
- 0010949: [Bug] during chapter menu rendering always displays "0 fps" but conversion completes (cedric) - resolved.
ConvertXtoDVD - 6.0.0.89
- 0012627: [Bug] Audio normalization - Process may not start in some computers (felicia) - resolved.
- 0012542: [Bug] show log file if important warning like in case when no more than 99 titlesets can be added (felicia) - resolved.
ConvertXtoDVD - 6.0.0.88
- 0012618: [Bug] DVD Analyser - Titles wrongly named in filter mode (felicia) - resolved.
- 0012603: [Bug] changes made to chapter settings in default settings are not always imported to current project (felicia) - resolved.
- 0009250: [Information] treeview seems interactive but is not when converting (felicia) - resolved.
- 0009578: [Bug] updating wording to use the same as in default settings "Delete folder after successful burn" (felicia) - resolved.
- 0010345: [Feature Request] add hint also to drop down selection in subtitle editor (felicia) - resolved.
- 0010596: [Bug] finalize and finalise - wording consistency (felicia) - resolved.
- 0012607: [Suggestion] clean up about window (felicia) - resolved.
- 0012604: [Bug] unchecking "use source chapter if available " does not add chapters every 5 min even if that option is checked (felicia) - resolved.
- 0012608: [Bug] Audio normalization - If cancelled, won't be able to start again (felicia) - resolved.
ConvertXtoDVD - 6.0.0.87
- 0012354: [Bug] when some files merged audio video on 2nd video is not in sync (felicia) - resolved.
- 0012364: [Bug] Sync issue on output (felicia) - resolved.
- 0012592: [Bug] Remxed subtitles are black (felicia) - resolved.
- 0012597: [Bug] audio normalization not working (felicia) - resolved.
ConvertXtoDVD - 6.0.0.86 (Released 2017-02-07) [ View Issues ]
- 0012590: [Bug] Exception when closing output tab (felicia) - resolved.
- 0012587: [Bug] Display issues in preview when paused or stopped and layers are active (felicia) - resolved.
[2 issues]
ConvertXtoDVD - 6.0.0.85 (Released 2017-02-06) [ View Issues ]
- 0012569: [Bug] Issue with Smallville DVDs (felicia) - resolved.
- 0012574: [Bug] app hangs after a successful conversion/burn - must kill with task manager (felicia) - resolved.
ConvertXtoDVD - 6.0.0.83 (Released 2017-02-01) [ View Issues ]
- 0012559: [Bug] double clicking on project file does not load files in project (felicia) - resolved.
- 0012556: [Crash] app freezes when trying to load Blu ray (felicia) - resolved.
- 0012549: [Bug] not correctly identifying of the videos on the disk - being mislabled (felicia) - resolved.
ConvertXtoDVD - 6.0.0.82 (Released 2017-01-30) [ View Issues ]
- 0012341: [Bug] when several title menu pages, after playing the last of all titlesets cursor does not preselect 1st titleset on first menu page (wesson) - resolved.
- 0012473: [Feature Request] Add online registration (wesson) - resolved.
- 0012319: [Bug] old project name applied even if a new one has been set (felicia) - resolved.
- 0012534: [Bug] Access Violation error when trying to convert to convert over 100 titlesets (felicia) - resolved.
- 0012504: [Bug] conversion stops at around 90% during menu encoding (felicia) - resolved.
- 0012390: [Bug] message saying THIS IS A AVALUATION COPY ONLY AND NOT FOR PUBLIC DISTRUBUTION (wesson) - resolved.
- 0012325: [Bug] argument out of range when saving and exiting menu editor with "thriller" template (felicia) - resolved.
- 0012357: [Feature Request] Add option to cancel file parsing (felicia) - resolved.
- 0011079: [Bug] theme problem and progress bar (felicia) - resolved.
- 0011642: [Feature Request] special tool to help user select correct code page (felicia) - resolved.
- 0012320: [Bug] menu duration not saved in project if using an old template (felicia) - resolved.
- 0012317: [Bug] Preview starts with wrong stream if streams have been deleted (felicia) - resolved.
- 0012321: [Bug] preview of conversion does not display subtitles even if selected (felicia) - resolved.
- 0012322: [Bug] updated project name not used for burning and therefore burns the wrong folder (felicia) - resolved.
- 0012323: [Bug] reverting to vso default menu fonts cannot be done using "reset to vso defaults" button in default settings (felicia) - resolved.
- 0012532: [Bug] can't get audio to loop in menu (felicia) - resolved.
- 0012527: [Bug] encoder crash: Pro Res codec (felicia) - resolved.
- 0012514: [Bug] some Blu-ray's as ISO don't open (wesson) - resolved.
- 0012485: [Bug] cannot change duration of thumbnail in titlemenu to apply to all titlesets (felicia) - resolved.
- 0012479: [Bug] wrong number of audio channels sometimes displayed (felicia) - resolved.
- 0012472: [Crash] Particular cut in particular file causes program to lock (felicia) - resolved.
ConvertXtoDVD - 6.0.0.81 (Released 2016-12-16) [ View Issues ]
- 0012312: [Bug] DTS audio tracks are not remuxed even if I select "Automatic" and uncheck "Convert DTS to AC-3" in audio settings (cedric) - resolved.
[1 issue]
History
[2 issues]
[1 issue]
Re: ConvertXtoDVD - beta version 6.0.0.64
for the past few updates my movies have been bloke and lines around the people i just bought a 4k TV and i watch it in 1080p but i had no problems before with 1080p files transformed to dvdrip
- VSO Fanatic
Hi cedric
would you please explain how "Use Best Video Quality" improve output quality?
how it effect the quality? does it improve sharpness?
Getting a 0FPS frame rate on build .64 during title settings / chapter generation. Timing's also "off". 1 second takes like 15sec, but the "processing %" does progress
Desktop: Project Phoenix
- VSO Fanatic
Re: ConvertXtoDVD - beta version 6.0.0.65
File name is vsoConvertXtoDVD6_setup_6.0.0.64b.exe, is it's name wrong?
its coming, slight delay, started to update post but realized something is still missing before publishing
Or you can just do what i did and copy the download url and change the 4 into a 5, done.
Except Claire said that "something was missing," and we have no idea if that has been fixed in the copy you just downloaded. I'm betting it hasn't been fixed, or the link would have been put up.Ch3vr0n wrote:Or you can just do what i did and copy the download url and change the 4 into a 5, done.
updated, new 6.0.0.65 uploaded
Installing 6.0.0.65 required me to register again and would not accept key code. Reinstalled 6.0.0.64 and all was fine again.
Thanks for reporting that major problem! It has now been fixed, we just reuploaded the beta version again with the correction.
I'd say try with the same disks with ImgBurn (freeware) and see what happens
http://forums.vso-software.fr/use-imgbu ... t9776.html
Just re-downloaded and installed again with the same issue. Going back to 6.0.0.64 fixed the problem.Claire wrote:Thanks for reporting that major problem! It has now been fixed, we just reuploaded the beta version again with the correction.
Bye, don't let the door hit you on the way out!
It's just like saying; "I'm swaping my car for bicycle because all I want is to go round the corner " But if you're happy ......... Cheers mate !jp2017 wrote:I try Aiseesoft DVD Creator and works like a charm. Goodbye ConvertXtoDVD.
Seems to be fine with the new 6.0.0.66 beta. Thanks!JasonSGN wrote:Just re-downloaded and installed again with the same issue. Going back to 6.0.0.64 fixed the problem.Claire wrote:Thanks for reporting that major problem! It has now been fixed, we just reuploaded the beta version again with the correction.
Re: ConvertXtoDVD - beta version 6.0.0.66
Can add an option that when you change video thumbnail duration in a DVD Menu for one thumpnail, change to the same duration FOR ALL the thumpnail videos in the DVD menu? Now it has to be change one by one.
- VSO Fanatic
CXD 6.0.0.66 detect some 5.1 Dolby Audio as 2 channels
I confirm that it also happens on some 7.1 audio tracks too.deadlyshadow wrote:CXD 6.0.0.66 detect some 5.1 Dolby Audio as 2 channels
Also, it's unable to load it's own project file saves.
When I try to load project file saves, I get this:
Note that the project file saves of v6.0.0.66, they load just fine on v6.0.0.64.
I'm using 6.0.0.63 and CXD has detected an AC3 5.1 audio channel as 3 channel.deadlyshadow wrote:CXD 6.0.0.66 detect some 5.1 Dolby Audio as 2 channels
Handbrake detects it as AC3 5.1
