hello all.
Why i keep getting this message "Write success at try #2" when i burn any dvd?
23:08:59.038 Info WRITE SUCCESS: Disc written
23:08:55.419 Info Disc name: "The.Revenant.2015.DVDScr.XviD.AC"
23:00:18.685 Info Burned folder: "C:\Users\ZERIFU\Documents\ConvertXtoDVD\The.Revenant.2015.DVDScr.XviD.AC3-ETRG", Min. media size 3.9 GB.
22:59:26.090 Info Disc name: "The.Revenant.2015.DVDScr.XviD.AC"
22:51:47.272 Info Burned folder: "C:\Users\ZERIFU\Documents\ConvertXtoDVD\The.Revenant.2015.DVDScr.XviD.AC3-ETRG", Min. media size 3.9 GB.
22:51:03.013 Info WRITE SUCCESS: Disc written
22:51:01.442 Info Disc name: "The.Revenant.2015.DVDScr.XviD.AC3-ETRG"
22:43:00.377 Info Burned folder: "C:\Users\ZERIFU\Documents\ConvertXtoDVD\The.Revenant.2015.DVDScr.XviD.AC3-ETRG", Min. media size 3.9 GB.
22:43:00.229 Info Conversion completed in 00:12:46
22:30:13.093 Info [ ] Loop playback
22:30:13.092 Info [ ] Play titles one after the other
22:30:13.091 Info [x] Don't create title menu for single video
22:30:13.090 Info [ ] Return to title menu after titleset playback
22:30:13.089 Info [ ] Skip root menu initially
22:30:13.089 Info [ ] Auto-start playback
22:30:13.088 Info Template: Metallic (open style), contains 4 page(s)
22:30:13.088 Group Opções de menu Vídeo DVD
22:30:13.087 Info Video DVD format: NTSC (30 Fps)
22:30:13.087 Info Output target size : DVD-5 (4300 MB)
22:30:13.086 Info Number of core(s) used for encoding : 4
22:30:13.085 Info Number of core(s) used for decoding : 4
22:30:13.085 Info [ ] Use 2 pass encoding
22:30:13.084 Info [ ] Use best video quality settings
22:30:13.083 Info [x] Use hardware decoding (if possible)
22:30:13.083 Info Max simultaneous conversions: 4
22:30:13.083 Group Opções de codificação avançada
22:42:59.589 ------------ ****************************************File encoded successfully: VTS_01_1.VOB*****************************************
22:42:59.587 Info "CONFIGURAÇÕES" menu built successfully
22:42:03.566 Info "CAPÍTULOS" menu built successfully
^^^Repeated 6 Times in 51 second(s) 56 millisecond(s)^^^
22:41:52.835 Info "PRINCIPAL" menu built successfully
22:41:47.320 Info Building PRINCIPAL, CAPÍTULOS & CONFIGURAÇÕES menus using template: Metallic (open style)
22:41:47.153 Info subtitle #4 - Encoded subtitles frames: 969
22:41:47.152 Info subtitle #3 - Encoded subtitles frames: 969
22:41:47.151 Info DVD sectors written - video: 1806653, audio: 186157, subtitle: 2520
22:41:47.151 Info video #1 - Processed video frames: 224927 (224928 frames encoded, 0 frames dropped, 1 frames duplicated)
22:30:13.337 ------------ +--> [subtitle #4 - dvd_subtitle subtitle, 720x576 ]
+-[subtitle #0 - srt subtitle]
+--> [subtitle #3 - dvd_subtitle subtitle, 720x576 (Default)]
+--> [audio #2 - RAW copy]
+-[audio ac3 áudio principal 6 Ch., 48000 Hz, 320 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 23.98Fps -> 29.97Fps, 3110 Kbps]
+-[video mpeg4 720x304 45:19 yuv420p, 23.98 fps, 926 Kbps]
Ficheiro de saída: C:\Users\ZERIFU\Documents\ConvertXtoDVD\The.Revenant.2015.DVDScr.XviD.AC3-ETRG\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Ficheiro de entrada: D:\Downloads\The.Revenant.2015.DVDScr.XviD.AC3-ETRG\The.Revenant.2015.DVDScr.XviD.AC3-ETRG.avi
Video filters used:
- DeInterlace filter: FFmpeg (used only if needed)
- Upscale filter: linear (vso), Downscale filter: linear (vso). Fit method: letterbox (Padding: top: 60, bottom: 60, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
22:30:13.336 Info Capítulos a gerar: 32
22:30:12.824 Info Added in conversion queue list...
22:30:12.430 Group ******************** Conjunto de títulos #1 - ~156 min. Ficheiro: "The.Revenant.2015.DVDScr.XviD.AC3-ETRG" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
22:30:12.428 Info Encoding options: Medium Project (Automático)
22:30:12.428 Info Target size: 4.2 GB.
22:30:12.426 Info Menu fit: Text size reduced from 27.00 to 24.00 in style "Captions in title menu pages"
22:30:12.231 Info Não criar registos de eventos FFMpeg
22:30:12.230 ------------ ***************************************************Burn settings end****************************************************
22:30:12.230 Info Default speed selected: 4x
22:30:12.229 Info [ ] Delete vsomsl files after burn complete
22:30:12.229 Info [ ] Delete output folder after burn complete
22:30:12.228 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
22:30:12.228 Info SAO setting: Automatic
22:30:12.228 Info [x] Burn result to disk / as ISO file in working folder
22:30:12.227 ------------ **************************************************Burn settings begin***************************************************
22:30:12.227 Group Sessão de codificação iniciada em 22:30:12: 1 títulos(s) para codificar -> Completed in 00:12:46|GK_CONVERT_SESSION|
22:28:05.576 Info Added stream "0:0:0 - srt 720x576" in file "C:\Users\ZERIFU\AppData\Local\Temp\Rar$DRa0.504\The.Revenant.2015.DVDSCR.X264.AC3-EVO.srt" to titleset "The.Revenant.2015.DVDScr.XviD.AC3-ETRG"
22:28:02.228 Info Added stream "0:0:0 - srt 720x576" in file "C:\Users\ZERIFU\AppData\Local\Temp\Rar$DRa0.506\The.Revenant.2015.DVDSCR.X264.AC3-EVO.srt" to titleset "The.Revenant.2015.DVDScr.XviD.AC3-ETRG"
22:26:57.906 Info #1 mpeg4 720x304 45:19 yuv420p, 23.98 fps, 926 Kbps
22:26:57.906 Group Video streams
22:26:57.906 Info #2 ac3 áudio principal 6 Ch., 48000 Hz, 320 Kbps - Unspecified
22:26:57.906 Group Audio streams
22:26:57.906 Group Added file: D:\Downloads\The.Revenant.2015.DVDScr.XviD.AC3-ETRG\The.Revenant.2015.DVDScr.XviD.AC3-ETRG.avi
22:26:45.390 Info Menu templates loaded: 23
22:26:44.591 Info Memória física total : 8143 Mb.
Memória física disponível : 5701 Mb.
Memória Carregada : 29%
Memória virtual total : 4095 Mb.
Memória virtual disponível : 3771 Mb.
Memória virtual extendida disponível : 0 Mb.
Memória total : 16284 Mb.
Memória disponível : 13536 Mb.
22:26:44.590 Info Processador Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz com 4 núcleo(s) CPU
Pipeline(s): 4 - paralelizar até 4
Conjunto de instruções suportadas: MMX,sse,sse2,sse3,ssse3,sse41,sse42,avx,avx2,bmi1,bmi2,aes,Fma3
22:26:44.585 Info User OS: Windows 7 Professional, Microsoft Windows 7 (Build 7601: Service Pack 1)
nome do ficheiro : D:\Program Files (x86)\VSO\ConvertX\6\ConvertXtoDvd.exe
versão do ficheiro : 6.0.0.17
Idioma do utilizador : Português (Portugal)
Idioma do sistema : Português (Portugal)
22:26:42.867 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\6\templates"
22:26:42.867 ------------ **************************ConvertXtoDvd.exe:3312 Log session start 2016-01-18 at 22:26:42.512***************************
23:08:54.134 Info Burning process completed successfully.
23:08:54.129 Info Finalization Time 9s648ms - Total completion time 7m40s328ms
23:08:54.122 Info Finalise: Finalisation completed
23:08:54.117 Info Finalise: Flush device cache - Completed
23:08:44.486 Info Finalise: Flushing burner cache
23:08:44.481 Info Write finished in 7m30s681ms - Finalization start here. Avg. burn rate 6.71
23:08:44.474 Info Finalise: Start disc finalisation
23:01:46.083 Info Write success at try #2
22:58:51.496 Info Write success at try #2
22:58:51.476 Info Write success at try #2
22:58:51.468 Info Write success at try #2
22:58:39.358 Info Write success at try #2
22:58:39.345 Info Write success at try #2
22:58:39.325 Info Write success at try #2
22:58:39.320 Info Write success at try #2
22:58:27.209 Info Write success at try #2
22:58:27.200 Info Write success at try #2
22:58:27.181 Info Write success at try #2
22:58:27.176 Info Write success at try #2
22:57:59.001 Info Write success at try #2
22:57:58.991 Info Write success at try #2
22:57:58.965 Info Write success at try #2
22:56:02.678 Info Write success at try #2
22:53:23.167 Info WRITING: Lead-in burning time required 1m8s694ms
22:52:50.659 Info Write success at try #2
22:52:14.474 Info Write started 2044336 sectors to write
22:52:14.471 Info Init DVD-R DAO Success
22:52:05.368 Info Write speed set at x12.0 (16620 kB/s)
22:52:05.355 Info Available write speed: x16.0 (22160 kB/s) CAV *, x14.0 (19390 kB/s) CAV, x12.0 (16620 kB/s) CAV, x10.0 (13850 kB/s) CAV, x8.0 (11080 kB/s) CAV, x6.0 (8310 kB/s), x4.0 (5540 kB/s)
22:52:05.352 Info Media ID: MCC 03RG20
22:52:05.332 Info Scanned files #10, folder #2 - total size 4185683968 b. (3.9 GB.)
22:52:05.330 Info Inserted media type : dvd-r
22:52:05.327 Info Volume ID: The.Revenant.2015.DVDScr.XviD.AC
22:52:05.325 Info Folder: C:\Users\ZERIFU\Documents\ConvertXtoDVD\The.Revenant.2015.DVDScr.XviD.AC3-ETRG\
22:52:05.322 Info Write started
22:52:04.514 Info Processo de gravação de DVD Vídeo iniciado
22:51:49.288 Info Writable disc dvd-r inserted. Ready to write
^^^Repeated 2 Times in 12 second(s) 34 millisecond(s)^^^
22:50:59.475 Info Burning process completed successfully.
22:50:59.472 Info Finalization Time 9s668ms - Total completion time 7m39s866ms
22:50:59.466 Info Finalise: Finalisation completed
22:50:59.464 Info Finalise: Flush device cache - Completed
22:50:49.808 Info Finalise: Flushing burner cache
22:50:49.803 Info Write finished in 7m30s200ms - Finalization start here. Avg. burn rate 6.71
22:50:49.799 Info Finalise: Start disc finalisation
22:43:51.863 Info Write success at try #2
^^^Repeated 24 Times in 6 minute(s) 55 second(s) 725 millisecond(s)^^^
22:43:49.830 Info WRITING: Lead-in burning time required 30s228ms
22:43:43.719 Info Write success at try #2
^^^Repeated 4 Times in 6 second(s) 106 millisecond(s)^^^
22:43:19.603 Info Write started 2044336 sectors to write
22:43:19.600 Info Init DVD-R DAO Success
22:43:10.461 Info Write speed set at x8.0 (11080 kB/s)
22:43:10.447 Info Available write speed: x16.0 (22160 kB/s) CAV *, x14.0 (19390 kB/s) CAV, x12.0 (16620 kB/s) CAV, x10.0 (13850 kB/s) CAV, x8.0 (11080 kB/s) CAV, x6.0 (8310 kB/s), x4.0 (5540 kB/s)
22:43:10.445 Info Media ID: MCC 03RG20
22:43:10.425 Info Scanned files #10, folder #2 - total size 4185683968 b. (3.9 GB.)
22:43:10.423 Info Inserted media type : dvd-r
22:43:10.420 Info Volume ID: The.Revenant.2015.DVDScr.XviD.AC3-ETRG
22:43:10.418 Info Folder: C:\Users\ZERIFU\Documents\ConvertXtoDVD\The.Revenant.2015.DVDScr.XviD.AC3-ETRG\
22:43:10.416 Info Write started
22:43:09.515 Info Processo de gravação de DVD Vídeo iniciado
22:43:02.406 Info Writable disc dvd-r inserted. Ready to write
22:43:00.388 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
22:43:00.388 Info Drive has Serial ATA physical interface
22:43:00.388 Info New Drive selected : [E] ASUS DRW-24F1MT 1.00 (ATAPI)
22:26:42.865 Info 1 writer(s) found.
22:26:42.850 Group Eventos de gravação
Re: Write success at try #2
Maybe asking to write at x12 is a little too much ?23:08:44.481 Info Write finished in 7m30s681ms - Finalization start here. Avg. burn rate 6.71
Since your average write speed was x6.71
Maybe next time try x8 and see if this doesn't occur again !
hello.
still getting the same when im burning with 8x speed
I am having the same problem and write speed 3X
:std_log='C:\ProgramData\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_mainlog.20170712.135843.872.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=7.0.0.36
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=stopped
:group_indent=4
13:58:43.865 ------------ ***************ConvertXtoDvd.exe:8560 Log session stop after 36 minute(s) 23 second(s) 129 millisecond(s)***************
13:58:43.332 Important Closing editor
13:58:43.332 Group Menu Editor events
13:58:43.308 Important Closing editor
13:58:43.308 Group Menu Editor events
13:57:55.176 Info Disc name: "My DVD"
13:24:22.268 Info Burned folder: "C:\Users\ian\Documents\ConvertXToDVD\My DVD", Min. media size 5.02 GB.
13:22:26.377 Info Menu templates loaded: 20
13:22:25.593 Info Command line: 0 parameter(s)
Param #00: "C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDvd.exe"
13:22:25.592 Info Total Physical Memory : 8060 Mb.
Available Physical Memory : 5146 Mb.
Memory Load : 36%
Available Virtual Memory : 3733 Mb.
Total Memory : 8572 Mb.
Available Memory : 5321 Mb.
13:22:25.592 Info Processor Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz with 16/8 core(s) CPU
Supported instruction set: MMX,sse,sse2 (slow),sse3,ssse3,sse41,sse42,avx,avx2,bmi1,bmi2,aes,Fma3
13:22:25.585 Info User OS: Windows 10 Home, Microsoft Windows 10 Home Edition (Build 14393)
file name : C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDvd.exe
file version : 7.0.0.36
User language : English (United Kingdom)
System language : English (United Kingdom)
13:22:20.762 Info Loading templates from: "C:\Users\ian\Documents\ConvertXtoDVD_Resources\Templates\"
13:22:20.762 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\7\Templates\"
13:22:20.759 ------------ **************************ConvertXtoDvd.exe:8560 Log session start 2017-07-12 at 13:22:20.203***************************
13:57:52.907 Info WRITE SUCCESS: Disc written
13:57:52.640 Info Burning process completed successfully.
13:57:52.632 Info Finalization Time 00:09:53.088 - Total completion time 00:32:53.599
13:57:52.606 Info Finalize: Finalisation completed
13:57:52.590 Info Finalize: Close disc - Completed
13:48:02.675 Info Finalize: Start Close media
13:48:02.637 Info Finalize: Close track - Completed
13:48:00.094 Info Finalize: Start Close track
13:48:00.082 Info Finalize: Flush device cache - Completed
13:47:59.566 Info Finalize: Flushing burner cache
13:47:59.534 Info Write finished in 00:23:00.513 - Finalization start here. Avg. burn rate 2.82
13:47:59.519 Info Finalize: Start disc finalisation
13:25:07.012 Info Write success at try #2
^^^Repeated 45 Times in 22 minute(s) 23 second(s) 628 millisecond(s)^^^
13:25:06.734 Info WRITING: Lead-in burning time required 00:00:07.714
13:25:02.632 Info Write success at try #2
^^^Repeated 3 Times in 4 second(s) 89 millisecond(s)^^^
13:24:59.019 Info Write started 2631152 sectors to write
13:24:59.008 Info Init DVD+R Dual Layer: Success
13:24:58.102 Info Init DVD+R Dual Layer: Layer change set to LBA 1858000 (3.54 GB.)
13:24:30.694 Info Write speed set at x3.0 (4155 kB/s)
13:24:30.671 Info layer break set by filesystem builder at 1858000
13:24:30.667 Info Available write speed: x6.0 (8310 kB/s) *, x4.0 (5540 kB/s), x3.0 (4155 kB/s)
13:24:30.663 Info Media ID: UMEDISC-DL1-40
13:24:30.629 Info Layer break is proposed at Titleset #1, PGC #1, Cell #1, vobu #11876, sector #1858000, at time 01:35:00
13:24:30.433 Info Scanned files #12, folder #2 - total size 5387462656 b. (5.02 GB.)
13:24:30.427 Info Inserted media type : dvd+r dual layer
13:24:30.420 Info Volume ID: My DVD
13:24:30.409 Info Folder: C:\Users\ian\Documents\ConvertXToDVD\My DVD\
13:24:30.397 Info Write started
13:24:30.289 Info DVD Video burn process started
13:24:24.335 Info Writable disc dvd+r dual layer inserted. Ready to write
13:24:22.284 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
13:24:22.284 Info Drive has Serial ATA physical interface
13:24:22.283 Info New Drive selected : [E] Slimtype DVD A DA8AESH XA11 (SATA)
13:22:20.752 Info 1 writer(s) found.
13:22:20.586 Group Burn engine events
:library=false
:most_recent=first
:status=stopped
:group_indent=4
Memory Load : 36%
as long as the burn finishes with success then there is not "problem"
