Delete or skip root menu
jmanwf
Post by jmanwf »
Hi guys is it possible to not have the root menu and not create the chapters i want to be able to just go back to the episode list and not the chapters when the episode has finished any help would be apprechated
SomeoneElse
Re: Delete or skip root menu
Post by SomeoneElse »
do you have the return to title menu option selected? I figured that would make it always go back to the title menu instead of chapter menu, but I haven't really tried anything with chapter menus in very often.
jmanwf
Post by jmanwf »
Yep this option isn't working i think it is a bug it awlays goes back to the chapters menu and not the title menu
SomeoneElse
Usually, I use the minimal menu where it has no title menu, but I wanted to start using a different menu, so I sure hope I don't run into this issue also. Hopefully they will respond and say if it's happening to them, where I don't waste a disc.
SomeoneElse
I think mine is working properly. Well, not totally properly.... it highlights the same title every time, but yes it does skip the root menu and go back to the title menu.
jmanwf wrote:Hi guys is it possible to not have the root menu and not create the chapters i want to be able to just go back to the episode list and not the chapters when the episode has finished any help would be apprechated
then use the templates
minimal no root
or cx2 style
or any menu but make sure to check " return to title menu after titleset playback" and also "skip root menu initially"
