Trial or Buy
peter7769
Trial or Buy
Post by peter7769 »
i have just installed this and wondered what the limitations are on the Trial Version? as you cant purchase it yet.
Pete
renits
Re: Trial or Buy
Post by renits »
Pete
Yes you can purchase it,there is a link in the original post.
Cheers
Renits
peter7769
Re: Trial or Buy
Post by peter7769 »
Ooops, didn't see thanks, i was trying to purchase in app, so what is the difference between trial and purchase, a watermark?
Pete
LouisM
Re: Trial or Buy
Post by LouisM »
Yes, there is a watermark in the trial version.
Any question about VSO Downloader? See the FAQ.
peter7769
Re: Trial or Buy
Post by peter7769 »
Thanks, I must say it's a bit of a disappointment to have to pay money to try an Alpha product,
I'm not sure about spending out a lot of money on something that may not work properly.
I think there should be some sort of discount for existing ConvertX customers?
Pete
Re: Trial or Buy
Yes there is a coupon for exisiting customers. This info will be sent to you by PM
hi5kba
Re: Trial or Buy
Post by hi5kba »
Claire wrote:Yes there is a coupon for exisiting customers. This info will be sent to you by PM
theres a coupon?
is it just for gold members? I only bought convertxtoDVD.
Does that matter?
thanks
Re: Trial or Buy
if you purchased a any VSO product you are entitled to a coupon,
login here
http://www.vso-software.fr/upgrade.php
and look on the right side of the page
Exfso
Re: Trial or Buy
Post by Exfso »
I have just downloaded the Beta version. When I click on the page to buy, there is no link to ConvertXtoHD, so how does one purchase it, no idea of the cost either!!!
Re: Trial or Buy
you will find the buy link at the bottom of the 1st post on this page
http://forums.vso-software.fr/convertxt ... 18184.html
