Fastest DVD conversion software?
Chakusin
Post by Chakusin »
Hello everyone,,
I've been using ConvertXtoDVD for a while now, and I have been getting OK results. However, I'm not sure if this program is the fastest one out there. I mainly convert MP4/MKV files to DVD, usually of movies. One of the things I like about this program is that it allows you to save the VIDEO_TS folder for later burning, which I do with ImgBurn. I'd like to have that option in any alternatives that you guys suggest. I convert at anywhere from 180 fps to 230 fps using ConvertXtoDVD, and it takes, on average, a little over 15 minutes to convert a full length film. My CPU is an i7-4710HQ. Any suggestions on programs that can do this task faster?
Re: Fastest DVD conversion software?
I wouldn't sacrifice quality for speed. Having said that, I strongly think that CX2DVD has both. Very good processing time at very good conversion quality.
