video stops when fast-forwarding
I have the problem with .mkv and.mp4, other containers I do not use. That's only with VSO Video Converter
I have that at 2.0.0.88 and .2.0.0.92. Whether it is with other versions before 2.0.0.88 I do not know.
Could you check that out? Program is great, only the point disturbs.
Many Thanks
Ludwig
Many Thanks
Ludwig
Re: video stops when fast-forwarding
Over 1 month no answer. Have the program changed, the new is to classy beeser than the old backward VSO, shame about the money, well, no matter
What is your question?
What do you mean with "video stops when fast-forwarding"?
If I pre-rewind (.mp4 and .mkv) the video stops a few seconds. This is only with VSO created videos like that. Thank you for your reply.
By the way:
why will not really even developed.? The program is absolutely outdated, at least not worth its money at the moment.
By the way:
Where does it stop?
Can you give more detailed description about the problem?
I have the same issue.
When trying to forward or rewind (scan and search) a disc, it just pauses, and will not progress. The disc will play, but not able to rewind or forward.
Is there a fix for this please?
