[encoder][h264_nvenc]: Encoding error
joinwu
Post by joinwu »
It can't work with h264_nvenc when I update Nvidia driver ver.416.34(2018/10/11)
Now it could work with 2.0.0.93
:std_log='C:\ProgramData\VSO\ConvertXtoVideo Ultimate\2\Log\ConvertXtoVideo Ultimate 2_mainlog_.20181007.191344.522.log'
:library=false
:app_version=2.0.0.88
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=stopped
:group_indent=4
19:13:44.522 ------------ *************vsoVideoConverter.exe:216 Log session stop after 20 minute(s) 25 second(s) 837 millisecond(s)**************
18:19:35.274 Info Total converted files size: 96.1 Mb.
18:00:14.663 Info Description:
18:00:14.663 Info Template name: Custom profiles
18:00:14.663 Info Name: 1920*800
18:00:14.663 Info Output folder: D:\output
18:00:14.663 Info codec=h264
18:00:14.663 Info dar=12/5
18:00:14.663 Info max_width=1920
18:00:14.663 Info max_height=800
18:00:14.663 Info h264_profile=high
18:00:14.663 Info h264_level=4.2
18:00:14.663 Info loop=1
18:00:14.663 Info qmin=10
18:00:14.663 Info qmax=51
18:00:14.663 Info qdiff=4
18:00:14.663 Info me_method=umh
18:00:14.663 Info subq=8
18:00:14.663 Info me_range=16
18:00:14.663 Info refs=3
18:00:14.663 Info bf=2
18:00:14.663 Info coder=1
18:00:14.663 Info trellis=1
18:00:14.663 Info b_strategy=2
18:00:14.663 Info mixed_refs=1
18:00:14.663 Info dct8x8=1
18:00:14.663 Group H264, max width:1920, max height:800
18:00:14.663 Info codec=aac
18:00:14.663 Info ac=2
18:00:14.663 Info ab=128000
18:00:14.663 Info ar=44100
18:00:14.663 Info bsf=aac_adtstoasc
18:00:14.663 Group AAC, 44100Hz, 128Kb/s, 2 channels
18:00:14.663 Group Embed in video
18:00:14.663 Group Profile settings
18:00:14.663 Info No size limit. Use of quality factor: VSO default
18:00:14.663 Info Number of core(s) used for encoding : 8
18:00:14.663 Info Number of core(s) used for decoding : 8
18:00:14.663 Info [x] Use 2 pass encoding
18:00:14.663 Info [x] Use best video quality settings
18:00:14.663 Info [x] Use hardware encoding (if possible)
18:00:14.663 Info [x] Use hardware decoding (if possible)
18:00:14.663 Info Max simultaneous conversions: 8
18:00:14.663 Group Advanced encoding options
18:19:35.066 Info video #1 - Processed video frames: 150439 (0 frames encoded, 0 frames dropped, 0 frames duplicated)
18:00:15.834 Error [encoder][h264_nvenc]: Encoding error
^^^Repeated 150439 Times in 19 minute(s) 19 second(s) 25 millisecond(s)^^^
18:00:15.422 Info H264 settings for stream #1: width=1912,height=800,aspect=240/239,dar=12/5,b=3500000,user_b=3500000,b_factor=0,codec=h264_nvenc,max_width=1920,max_height=800,h264_profile=high,h264_level=4.2,loop=1,qmin=-1,qmax=-1,qdiff=4,me_method=umh,subq=8,me_range=16,refs=3,bf=2,coder=1,trellis=1,b_strategy=2,mixed_refs=1,dct8x8=1,flags=+loop+global_header,g=250,time_base=1/24,pixel_format=yuv420p,gpu_id=0,pass_number=1,preset=superfast,bitrate_control=multipass_vbr,threads=8
18:00:15.419 ------------ ╔══> [audio #2 - aac audio, 44100Hz, Stereo, 128000 bps [English]]
╚═[audio [eng] ac3 main audio 6 Ch. 48000Hz , 384 Kbps]
╔══> [video #1 - h264_nvenc video, 1912x800, , 12x5, 24.00Fps, 3500Kbps]
╚═[video dxva2 [eng] h264 1920x804 160:67 dxva2_vld, 24.00Fps, 0Kbps ]
Output file: D:\output\The.Darkest.Minds.2018.1080p.WEB-DL.DD5.1.H264-FGT\The.Darkest.Minds.2018.1080p.WEB-DL.DD5.1.H264-FGT.mp4 (MPEG-4)
Input file: D:\output\wb\The.Darkest.Minds.2018.1080p.WEB-DL.DD5.1.H264-FGT.mkv
Video filters used:
- DeInterlace filter: VSO
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: stretch (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
18:00:15.419 Info Chapters to generate: 24 (0h00m00s, 0h03m52s, 0h09m39s, 0h14m32s, 0h19m25s, 0h23m34s, 0h26m23s, 0h30m49s, 0h35m34s, 0h41m20s, 0h47m21s, 0h51m47s, 0h55m54s, 0h59m31s, 1h03m32s, 1h08m39s, 1h12m13s, 1h14m10s, 1h18m00s, 1h20m53s, 1h23m26s, 1h26m55s, 1h29m23s, 1h37m58s, )
18:00:15.419 Important Starting video encoding: [Memory load 49%] [Available virtual memory 3173 Mb.]
18:00:15.361 Info Hardware decoding: H.264 variable-length decoder, no film grain technology using Adapter #0 - NVIDIA GeForce GTX 950M, converting h264 to yuv420p
18:00:14.586 Group ******************** The.Darkest.Minds.2018.1080p.WEB-DL.DD5.1.H264-FGT.mkv (1h:44m:34s) -> The.Darkest.Minds.2018.1080p.WEB-DL.DD5.1.H264-FGT.mp4 - MPEG-4 ********************|GK_TITLESET|
It can work with Intel Qsync.
:std_log='C:\ProgramData\VSO\ConvertXtoVideo Ultimate\2\Log\ConvertXtoVideo Ultimate 2_mainlog_.20181007.164416.507.log'
:library=false
:app_name=vsovideoconverter.exe
:most_recent=first
:status=stopped
:group_indent=4
16:44:16.507 ------------ ********vsovideoconverter.exe:7188 Log session stop after 2 hour(s) 53 minute(s) 9 second(s) 827 millisecond(s)*********
16:42:14.531 Info Total converted files size: 2.03 GB.
13:50:25.060 Info Description:
13:50:25.060 Info Template name: Custom profiles
13:50:25.060 Info Name: 1920*1080
13:50:25.060 Info Output folder: C:\bt
13:50:25.060 Info codec=h264
13:50:25.060 Info h264_profile=high
13:50:25.060 Info h264_level=4.2
13:50:25.060 Info loop=1
13:50:25.060 Info qmin=10
13:50:25.060 Info qmax=51
13:50:25.060 Info qdiff=4
13:50:25.060 Info me_method=umh
13:50:25.060 Info subq=8
13:50:25.060 Info me_range=16
13:50:25.060 Info refs=3
13:50:25.060 Info bf=2
13:50:25.060 Info coder=1
13:50:25.060 Info trellis=1
13:50:25.060 Info b_strategy=2
13:50:25.060 Info mixed_refs=1
13:50:25.060 Info dct8x8=1
13:50:25.060 Group H264
13:50:25.060 Info codec=aac
13:50:25.060 Info ac=2
13:50:25.060 Info ab=96000
13:50:25.060 Info ar=44100
13:50:25.060 Info bsf=aac_adtstoasc
13:50:25.060 Group AAC, 44100Hz, 96Kb/s, 2 channels
13:50:25.060 Group Embed in video
13:50:25.060 Group Profile settings
13:50:25.060 Info No size limit. Use of quality factor: VSO default
13:50:25.060 Info Number of core(s) used for encoding : 8
13:50:25.060 Info Number of core(s) used for decoding : 8
13:50:25.060 Info [x] Use 2 pass encoding
13:50:25.060 Info [x] Use best video quality settings
13:50:25.060 Info [x] Use hardware encoding (if possible)
13:50:25.060 Info [x] Use hardware decoding (if possible)
13:50:25.060 Info Max simultaneous conversions: 8
13:50:25.060 Group Advanced encoding options
16:42:14.379 Info video #1 - Processed video frames: 123047 (123047 frames encoded, 0 frames dropped, 0 frames duplicated)
13:50:25.223 Info H264 settings for stream #1: width=1920,height=1040,aspect=255/254,dar=960/517,b=3500000,user_b=3500000,b_factor=0,codec=h264_qsync_hw,h264_profile=high,h264_level=4.2,loop=1,qmin=10,qmax=51,qdiff=4,me_method=umh,subq=8,me_range=16,refs=3,bf=2,coder=1,trellis=1,b_strategy=2,mixed_refs=1,dct8x8=1,flags=+loop+global_header,g=250,time_base=1001/24000,pixel_format=yuv420p,gpu_id=0,pass_number=1,preset=superfast,threads=8
13:50:25.222 ------------ ╔══> [audio #2 - aac audio, 44100Hz, Stereo, 96000 bps [French]]
╚═[audio [fre] ac3 main audio 6 Ch. 48000Hz , 448 Kbps]
╔══> [video #1 - h264_qsync_hw video, 1920x1040, , 13x7, 23.98Fps, 3500Kbps]
╠═[video dxva2 h264 1920x1040 13:7 dxva2_vld, 23.98Fps, 0Kbps ]
╚═[subtitle srt 1920x576]
Output file: C:\bt\test\test.mp4 (MPEG-4)
Input file: D:\output\wb\test.mkv
Video filters used:
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 2, bottom: 2, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
13:50:25.222 Info Chapters to generate: 12 (0h00m00s, 0h06m32s, 0h14m46s, 0h21m47s, 0h31m10s, 0h40m24s, 0h46m53s, 0h53m48s, 1h00m06s, 1h09m39s, 1h15m05s, 1h22m17s, )
13:50:25.222 Important Starting video encoding: [Memory load 53%] [Available virtual memory 3174 Mb.]
13:50:25.157 Info Hardware decoding: H.264 variable-length decoder, no film grain technology using Adapter #0 - NVIDIA GeForce GTX 950M, converting h264 to yuv420p
13:50:25.023 Group ******************** test.mkv (1h:25m:32s) -> test.mp4 - MPEG-4 ********************|GK_TITLESET|
