How to merge MP4's into one file with chapters?
Post by 877 » Mon Feb 06, 2017 6:08 pm
As per title, I would like to merge aprox ten MP4's into one file with chapters. It's footage from my gopro.
File info is:
Complete name : D:\temp GoPro working\Oct-12.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp41/isom)
File size : 255 MiB
Duration : 1 min 23 s
Overall bit rate : 25.7 Mb/s
Encoded date : UTC 2017-02-05 13:58:49
Tagged date : UTC 2017-02-05 13:58:49
Video
Format : AVC
Format profile : Baseline@L4.2
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=50
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 25.6 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 50.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.246
Stream size : 253 MiB (100%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 spf)
Compression mode : Lossy
Stream size : 1.22 MiB (0%)
mdhd_Duration : 83157
Re: How to merge MP4's into one file with chapters?
Post by Claire » Wed Feb 15, 2017 1:53 pm
Here are the two ways to merge files,
1)
2) load all files, select them all, then right click and select merge
Chapters can only be create when converting to some formats which include: MKV, DVD, Blu-Ray and AVCHD
See how to make chapters:
