Device capture doesn't work with Webcam or internal Mic.
U2Desire
Post by U2Desire »
This is what is shown.
Not sure who makes the webcam in my ASUS ROG STRIX GL702VM but the webcam does not work. The ability to select audio capture shows nothing in the list. The sound chip is Realtek HD Audio.
Sytems specs are
Intel i7-6700HQ
16 Gigs DDR4
Nvidia 1060 GPU w/6 Gigs DDR5 Vram
Windows 10 Pro.
Re: Device capture doesn't work with Webcam or internal Mic.
I have no idea, I'll see if someone else on our team can get back to you on this.
jairo85
Post by jairo85 »
It does not work on my webcam either
jairo85 wrote:It does not work on my webcam either
This feature never worked as it should. VSO should have scraped the capture feature ages ago. I remember discussing this with Cedric.
