AMD VCE `(before renew license)
Cherryman
Post by Cherryman »
I need to renew my license, thats not a problem, but before I would like to know if and when AMD VCE is implemented. OpenCL doesn't work with the new AMD RXxxx cards and Crimson / ReLive.(The topic I had with cedric for a few months, only nothing more heard)
Would be nice to read it comes and when ;)
Best regards,
Cherryman
Cherryman
Re: AMD VCE `(before renew license)
Post by Cherryman »
In 10 days no answer? The support was also times better... :(
I'm sorry for the delay. I really have no idea, and was away on vacation. I've asked Cedric you're question but it maybe a few days before we get his reply.
Based on your previous exchanges with him on this subject
http://forums.vso-software.fr/feature-r ... 19341.html
I'm afraid there is no current solution we will see what Cedric says.
Support for this will most likely be added, we've just ordered the hardware to be able to work on the problem.
Cherryman
Post by Cherryman »
Hello Claire,
nice to hear. Many Thanks ;)
Hello Cherryman,
I don't understand why you're posting another thread about AMD hardware encoding?
Your last post in your previous thread says:
Problem solved. Thanks a lot, Cedric. VSO has the best support I know :)
We done a Teamviewer remote desktop session and I installed good OpenCL driver I think.
Do you have same problem as before?
Cherryman
Post by Cherryman »
cedric wrote:Hello Cherryman,
Hello Cedric,
Thats right, but in the last time or the latest AMD Driver works it no more.OpenCL does not work at all
You can look again with teamviewer, but not today because I have to work :)
Best regards,
Cherryman
