Another Bug in v2.0.0.53: crashing while conv. > 5 files
mue.mat
Post by mue.mat » Wed Jan 18, 2017 10:32 am
New version still crashing while converting more than 5 video hd files (it doesn't matter hardware or software encoding).
Quite annoying.
mue.mat
Re: Another Bug in v2.0.0.53: crashing while conv. > 5 files
Post by Claire » Wed Jan 18, 2017 10:57 am
if you select a conversion profile such as avi (h264 +ac3) do you get this problem?
what if you set hardware decoding to 0?
mue.mat
Post by mue.mat » Wed Jan 18, 2017 11:20 am
No, if I select f.e. avi oder mkv, I don't get the problem.
Problem only appears while converting into BluRay (720p/1080p), even if I try custom profile with hardcoded subtitles f.ex.
Yes, problem remains, it doesn't matter whether I set hardware decoding to 8 or 0; even if I reduce bitrate to 10'000'000, problem remains.
So, since v2.0.0.47, converting multiple video hd files into BluRay is not stable and converting 5 or more video hd files at the same time software is mostly crashing right at the beginning.
mue.mat
Post by Claire » Wed Jan 18, 2017 11:22 am
Ok thanks for this info
please send me your custom profile, maybe with it I will be able to reproduce.
you will find it here C:\ProgramData\VSO\ConvertXtoVideo Ultimate\2\custom_profiles
mue.mat
Post by mue.mat » Wed Jan 18, 2017 12:11 pm
You got private message, Claire.
Bye the way, every time I'm starting v.2.0.0.53 there comes up a message window that I should update to v2.0.0.53. But actually I'm using this latest beta version.
Strange...
mue.mat
Post by Claire » Wed Jan 18, 2017 3:24 pm
we 've posted a new beta version 2.0.0.54 you can try with it, it might solve that problem
http://forums.vso-software.fr/convertxt ... 18977.html
Post by Claire » Wed Jan 18, 2017 3:51 pm
I can only reproduce when cuda is set to 5 instances (because I don't think it accepts greater than 4) and when I use software encoding, I do not have this problem. I also tested in version 4.0.0.47
mue.mat
Post by mue.mat » Wed Jan 18, 2017 9:34 pm
Up to v2.0.0.47 it is possible with my graphic card to convert up to 8 instances (cuda) at the same time. Right before I tried it out to convert 12 hd video files at the same time. Cuda was set to 8 instances, so there were first converted the first 8 files simultaneously, after that the remaining 4 files. It took me with version 2.0.0.47 only 75 min to convert the 12 hd files into bluray 720p.
Newer versions don't allow any more to convert so many files simultaneously. Software always crashes while trying to convert more than 5 hd video files. So, as for me, newer versions are not stable. I simply don't know why, but there must be a bug that «attacks» amount of instances to convert into bluray.
mue.mat
mue.mat
Post by mue.mat » Wed Jan 18, 2017 9:36 pm
No, v2.0.0.54 still crashing while converting more than 5 hd video files at the same time.
