Stretch out a video to fit a soundtrack
pevg
Post by pevg »
I have a video that is at 24 fps and is 10 mins 35s long, which I obtained by recording a live stream. I have the audio track separately, and this is 13 mins 12s long. I suppose the time difference is due to the recording process being at a lower frame rate than the actual streamed video. Is there a way to stretch the video so that it matches the length of the soundtrack?
Re: Stretch out a video to fit a soundtrack
There may be away but I do not know how to go about doing that.
pevg
Post by pevg »
Is there any way I can reduce the fps rate when converting a video?
You can change it, and to do so I suggest creating a custom profile.
