Resize Filter options
todd12
Post by todd12 » Wed Dec 28, 2016 7:16 am
Using 2.0.0.51
After loading a file and clicking Advanced Edit button, the default is Linear. When I change it to a different one [Cubic for example] and select "Save and close" and then click the Advanced Edit button again, it has gone back to the default of Linear.
The only way I can save a different Resize Filter is to go to Settings / General Settings / Video resize, and then adjust it there. When I now click the Advanced Edit button, it now shows as Cubic [for my example]. As a test, if I try to change the Cubic to something else within the Advanced Edit button and save it, it still stays as Cubic. Thus the only way to change Resize Filter is through the Settings / General Settings / Video resize ?
Re: Resize Filter options
Post by Claire » Fri Dec 30, 2016 2:34 pm
Thanks for your very clear report, I confirm the problem. I've now reported it here http://bugs.vso-software.fr/view.php?id=12344 we will let you know when it is corrected.
Post by Claire » Tue Jan 17, 2017 3:54 pm
