Bug in v2.0.0.37: Converting to BluRay --> freezing
mue.mat
Post by mue.mat » Sat Sep 24, 2016 3:08 pm
Hello
I have just tried out new version v2.0.0.37, trying to convert HD video files (1920x1080) into BluRay.
It doesn't matter whether I want to convert a single hd video file or multiple hd video files into BluRay, both hardware (Cuda) and software encoding fail.
Either ConvertXtoVideo keeps "freezing" after about 70% of conversion (without error message) or suddenly the message "out of memory" (but not in terms of my computer) appears or right at the beginning the software crashes.
So I rolled back and reinstalled v2.0.0.36: Every conversion (hardware and software encoding) works fine.
Thanks for keep an eye on this bug.
mue.mat
Re: Bug in v2.0.0.37: Converting to BluRay --> freezing
Post by cedric » Mon Sep 26, 2016 9:00 am
Like you should know, we need your log files...
Thank you.
mue.mat
Post by mue.mat » Mon Sep 26, 2016 5:01 pm
I know, but the problem was the «freezing» that as far as I could see was not logged.
Then I made a clean deinstallation and have installed now v2.0.0.36 to have no problems.
Maybe other people have the same problem and will mention.
Hope that new beta version will work properly again for me.
Otherwise I will inform you again.
mue.mat
