v2.0.0.32: Settings in ADVANCED EDIT cannot be saved
mue.mat
Post by mue.mat » Fri Aug 26, 2016 7:17 pm
Hello
There is a bug in v2.0.0.32: When I use ADVANCED EDIT and set my preferred video settings (f.e. brightness and gamma correction) and I SAVE the settings, all my settings are lost (that means it is not possible to save the settings).
Please fix this bug.
And another bug: framerate is mostly "calculated" wrong.
Thanks and regards
mue.mat
Re: v2.0.0.32: Settings in ADVANCED EDIT cannot be saved
Post by cedric » Mon Aug 29, 2016 8:01 am
Fixed in last beta version...
Thank you for your feedback.
