Convert DVD files to MP4 video file
dondd
Post by dondd »
Guy's, This is my first time on your fourm so bear with me. I have a dvd of a program I would like to edit out the commercials. My thinking is if I convert the dvd to an mp4 file, then load the file in a video editor, cut out what I don't want, and burn a dvd with the modified file, I should be good...no?
I did look at some posts, but didn't quite get the info I need...like a step by step procedure.
Appreciate any direction and/or help!
Thanks, dondd :?
Re: Convert DVD files to MP4 video file
You can load the DVD as is in our software click on the link to open the Advanced editor, click on the video stream in the time line in the lower portion of the window and then select the tab in the upper left with scissors and now edit to remove the commercials. Save the changes and close this window, back on the main interface select the profile you want to convert to (mp4) and press convert.
Here is a guide:
https://www.vso-software.fr/guides/how- ... format.php
dondd
Post by dondd »
Claire, Thanks for the response. I forgot to mention, my version of ConvertX is 4.19, and it looks different than the guide you linked. Can my version do a DVD to MP4 conversion? Appreciate your guidance!! Thanks! Don
You posted in the forum of our product ConvertXtoVideo.
If you have ConvertXtoDVD 4, your question/post should here
http://forums.vso-software.fr/convertxt ... x-f34.html
No big deal, but that is why I linked the guide of our product ConvertXtoVideo and that is why it looks so different to you .... not the same product at all.
As for converting to mp4, you cannot do that with ConvertXtoDVD (no matter what version). ConvertXtoDVD converts to DVD.
However if you use ConvertXtoVideo you can convert to mp4
https://www.vso-software.fr/products/vi ... -video.php
dondd
Post by dondd »
Claire,
Thanks for the clarification....mystery solved! I appreciate your input and will adjust accordingly.
dondd
