Raw Copy Fast Forward And Rewind Not Working
jmanwf
Post by jmanwf » Tue Sep 29, 2015 3:05 am
Hey just though you would like to know but when you do a raw copy eg to blu ray or avchd mod in custom setting you can fats forward or rewind properly it just locks up
Re: Raw Copy Fast Forward And Rewind Not Working
Post by cedric » Fri Sep 23, 2016 10:28 am
Can you post your log file?
What was your input file properties (single file, Blu-ray/AVCHD structure)?
Post by cedric » Fri Sep 23, 2016 5:11 pm
Can you try using the last beta version (2.0.0.37)?
We worked on this problem and it should now be fixed.
jmanwf
Post by jmanwf » Mon Jan 09, 2017 4:57 am
So this stil isnt working in stand alone blu ray players hope it gets fixed soon this would be such a handy feature if you guy can byrn a file yourself and test it you will see what i mean plays fine but just cant fast forward or rewind smoothly in a blu ray player
found my old post so though i would use this one again
