Skipping DVD Chapters Returns to Main Menu
mase310
Post by mase310 »
I added multiple mpg/mp4/mov/avi video files to current version of ConverXtoVideo to burn a DVD. During playback I use the chapter skip button to go to the next chapter, after playing the chapter the playback returns to the menu instead of continuing to play the next chapter. How can I make the DVD so that it will continue playing instead of going back to the main menu after forwarding to the next chapter or repeating the current chapter. I just want usual skip/repeat chapter functionality like a normal movie DVD. Thank you!
mase310
Re: Skipping DVD Chapters Returns to Main Menu After Playbac
Post by mase310 »
I figured out how to merge chapters under a title, so this problem no longer occurs.
Re: [Solved] Skipping DVD Chapters Returns to Main Menu
ok thanks for reporting back!
you can also check the option "play titles one after the other"
