What is FMP4 I want Xvid?
thermalzombie
Post by thermalzombie »
Hi I am having difficulty converting files to Xvid I end up with a file that does no work on my Playstation 3 console that support Xvid.
I am unsure if this is a recent problem as the last version of VSO video converter worked I dont no if it has anything to do with the codec ID: FMP4 as I did not check the files I converted with the last version so though I would ask.
Here is the Profile I created in VSO video converter version 1.5.0.10.
---- Output container informations ----
* Name: AVI (Audio Video Interleave)
* File extension: avi
---- VIDEO track informations ----
Video stream will be encoded using these settings:
* codec: mpeg4 <<<<<<<<< Is this meant to be Xvid? I did choose xvid from dropdown.
* framerate: Same as source (if compatible)
* width: 624
* height: 352
* aspect ratio: 16/9
* max bitrate: 1000Kb/s (1.00Mb/s)
---- AUDIO tracks informations ----
Audio streams will be encoded using these settings:
* codec: mp3
* channel count: 2
* bitrate by channel: 64Kb/s (total: 128Kb/s)
* samplerate: Same as source (if compatible)Hz
---- SUBTITLE tracks informations ----
Subtitle streams will be encoded using these settings:
* Embed in video stream
Resulting file after converting specifications from Mediainfo.
General
Complete name : C:\Downloads\File.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 347 MiB
Duration : 42mn 29s
Overall bit rate : 1 141 Kbps
Writing application : Lavf55.7.100
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : FMP4
Duration : 42mn 28s
Bit rate : 1 001 Kbps
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.190
Stream size : 304 MiB (88%)
Title : Main video
Writing library : Lavc55.12.100
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 42mn 29s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 38.9 MiB (11%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 24 ms
Title : Unspecified
Writing library : LAME €C˜Ó¦‘CÑP,8
Thanks for the reply.
Copnm
Re: What is FMP4 I want Xvid?
Post by Copnm »
Hello thermalzombie,
Can you please post your conversion log.
Thanks for reading,
Neil M
thermalzombie
Thanks for the reply can you tell me please where to find the logs? I am using windows 7 64bit.
I think the problem is related to codec ID's I found this program called AVI_FourCC_Code_Changer and I changed the codec ID's to XVID now the file works.
Sorry cannot post a link due to forum restrictions.
Here is the MediaInfo specs of the altered file that works.
General
Complete name : C:\File.avi
Format : AVI
File size : 347 MiB
Duration : 42mn 29s
Video
Codec ID : XVID <<<<<<<<<<<<<
Codec ID/Hint : XviD <<<<<<<<<<<<
Duration : 42mn 28s
Width : 624 pixels
Height : 352 pixels
Color space : YUV
Bit depth : 8 bits
Title : Main video
Audio
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 42mn 29s
Bit rate : 128 Kbps
Title : Unspecified
I was also asked by VSO support to try a Playstation profile so I tried Playstation 3 - Mpeg4 Profile and the resulting file does not work iether Playstation 3 says unsupported data. I also mentioned this forum thread in my email reply to support.
Thanks for the reply's
Copnm
Post by Copnm »
How to find your log: http://forums.vso-software.fr/where-do- ... 13680.html.
Thanks for reading,
Neil M
thermalzombie
Here is a Crashlog I deleted all the logs then converted a file so I would get new logs. There is also file called crash list.crashlist that I cannot open.
:crash_log='C:\ProgramData\VSO\VSO Video Converter\1\Log\VSO Video Converter 1_crashlog_.20141025.153005.919.log'
:library=false
:app_version=1.5.0.10
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
15:41:59.959 Info Total converted files size: 347 Mb.
15:31:05.424 Info No size limit. Use of quality factor: VSO default
15:31:05.424 Info Number of core(s) used for encoding : 3
15:31:05.423 Info Number of core(s) used for decoding : 3
15:31:05.423 Info [ ] Use 2 pass encoding
15:31:05.422 Info [ ] Use best video quality settings
15:31:05.422 Info [ ] Use hardware encoding (if possible)
15:31:05.421 Info [ ] Use hardware decoding (if possible)
15:31:05.421 Info Max simultaneous conversions: 1
15:31:05.421 Group Advanced encoding options
15:41:59.935 Info video #1 - Processed video frames: 61110 (61109 frames encoded, 1 frames dropped, 0 frames duplicated)
15:31:05.466 ------------ +--> [audio #2 - mp3 audio, 48000Hz, Stereo, 128000 bps [un]]
+-[audio ac3 main audio 6 Ch., 48000 Hz, 384 Kbps]
+--> [video #1 - mpeg4 video, 624x352, yuv420p, 16x9, 23.98Fps, 1000 Kbps [un]]
+-[video h264 1280x720 16:9 yuv420p, 23.98 fps, 0 Kbps]
Output file: C:\Downloads\File.avi (AVI (Audio Video Interleave))
Input file: C:\Downloads\File.mkv
Video filters used:
- DeInterlace filter: FFmpeg
- Scale filter: linear (vso). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
15:31:05.386 Group ******************** File -> File.avi ********************|GK_TITLESET|
15:31:05.357 Group Conversion to "Custom profiles xVid-mp3 624x352 1000x128" started at 3:31:05 PM: 1 sequence(s) to encode|GK_CONVERT_SESSION|
15:30:05.919 ------------ ************************vsoVideoConverter.exe:4796 Log session start 2014-10-25 at 15:30:05.850*************************
thermalzombie
After I closed the program the crash-log disappeared and this log was available.
:std_log='C:\ProgramData\VSO\VSO Video Converter\1\Log\VSO Video Converter 1_mainlog_.20141025.160419.030.log'
:library=false
:most_recent=first
:status=stopped
:group_indent=4
16:04:18.957 ------------ *************vsoVideoConverter.exe:4796 Log session stop after 11 minute(s) 54 second(s) 109 millisecond(s)*************
Video filters used:
I tested the two profiles for PS3 in 1.5.0.11
and I confirm that the profile "playstation 3 - mpeg4" doesnt work on our playstation 3
but "playstation 3 - h264"
does this help?
thermalzombie
Claire wrote:Hi,
does this help?
Thanks Claire for the reply.
Just out of curiosity I converted one of the files I wish to convert to Xvid using the profile Claire mentioned above.
VSO Video Converter Version - 1.5.0.10
Playstation 3 - H264
And here is the resulting file from mediainfo also noticed that this file has a Codec ID/Info line that was missing from the file I onverted previosly maybe that is why the xvid profile I made didnt work.
Hopes this helps the developer.
General
Complete name : C:\Users\rte\Desktop\File.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.20 GiB
Duration : 42mn 30s
Overall bit rate : 4 032 Kbps
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=4, N=12
Codec ID : avc1
Codec ID/Info : Advanced Video Coding <<<<<<<<<<<<<<<
Duration : 42mn 29s
Bit rate : 3 862 Kbps
Width : 1 280 pixels
Height : 720 pixels
Frame rate mode : Constant
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.175
Stream size : 1.15 GiB (96%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 42mn 30s
Bit rate mode : Variable
Bit rate : 165 Kbps
Maximum bit rate : 192 Kbps
Stream size : 50.2 MiB (4%)
The developer knows why the custom profile didn't work and it is fixed apparently fixed in an internal version here we have, but I don't know when it will be released as a beta version.
please try with the new latest beta version
http://forums.vso-software.fr/newconver ... 18405.html
