a new version is available in the download section of the main web site
please report in that thread the problem you may encounter. I hope that version could be a fresh start to collect remaining issues. At least from the sales point of view, the v3 confirms it works much better than version 2.
here is the history of changes :
PhotoDVD - 3.0.9.6 - released 10 Oct 2009
- User informed if double layer DVD will be requested (regarding slideshow duration *AND* DVD menu size if used)
- Chapter image not visible in DVD menu when transition time is set to 0
- Incorrect number of automatic chapters displayed in log
- 0002975: [Information] setting name problem (perhaps in translation) (annelise) - resolved.
- 0002972: [Feature Request] Map items of menu bar. (cedric) - resolved.
- 0002945: [Bug] reorder photos, double click on one to edit, edit slide window does not display photo that was double clicked on (cedric) - resolved.
- 0002946: [Bug] using slider to make thumbnail bigger makes images go back to original order (cedric) - resolved.
- 0002934: [Bug] saved projects to not keep correct position of photo in list (cedric) - resolved.
- Chapter thumbnail with Black mirror template bug fixed
PhotoDVD - 3.0.9.1
- various fixes
- compiled with Delphi 2010
- ask setup script added
- new vso_hwe.dll 4.0.5
PhotoDVD - 3.0.8.4
- 0002921: [Bug] Can't move picture in image tree view using mouse (cedric) - resolved.
- 0002920: [Bug] Chapter name not properly displayed in DVD menu (cedric) - resolved.
PhotoDVD - 3.0.8.3
- PhotoDVD burn engine major update (saying write started... but nothing happen)
PhotoDVD - 3.0.8.2
- 0002916: [Bug] 3.0.8.0: Only Default template available from Settings, DVD menu. Other 3 templates missing (cedric) - resolved.
- Arabic &
new photodvd 3.0.9.6 is available
