Downloader beta 5.0.1.30
Download beta 5.0.1.30
http://download.vso-software.fr/archive ... 0.1.30.exe
- 0012759: [Bug] file downloads with error ("ERROR: Could not write header for output file #0 (incorrect codec parameters ?) (benjamin) - resolved.
- 0012780: [Information] improve speed of audio normalization (felicia) - resolved.
- 0012766: [Feature Request] Remember log form position & size (felicia) - resolved.
- languages update
ira
Re: Downloader beta 5.0.1.30
Post by ira »
Wish List Improvement for Downloader in general.
If you can figure a way to capture streams from http://abc.go.com/ trust me, you would do something that NO OTHER DOWNLOADER product has yet to succeed at doing. Did not work.
How do you make downloader capture video when it fails other ways? Thought you state it does that too? Never saw it happen or transition to it.
Ira
We have made note of your request and we will see what we can do. Thanks for posting.
phoenix
Post by phoenix »
A couple suggestions:
Have a way to clear all downloads from the list instead of one by one.
Also maybe keep "And delete files in output folder" unchecked as default.
Say you check to remove one file from the list and also choose to delete the file in the output folder. Then you go to remove a different file from the list but don't want to delete the already downloaded file. Well it remembers the decision from before and it is checked. Because you might delete the downloaded file in the output folder by mistake when you just want to remove it from the list.
