QQ Music disorient Downloader
Djago
Post by Djago »
I'm using Downloader to download (or trying to download) some mp3 on QQ Music page. The problem is that sometimes I get an mp4, sometimes an mp3, sometimes BOTH, sometimes the title is ok, sometimes not. I couldn't figure why. I'm not talking about conversion, it is turned OFF. I'm specifically talking about downloading.
If I try to download a playlist it can download 3 or 4 mp3 and the rest mp4. The best result I could get is to play each file alone in the player. Most of the time I get both files so I delete the mp4 and keep the mp3.
Any clues?
Djago
Benjamin
Re: QQ Music disorient Downloader
Post by Benjamin »
from what site do you have this result, can you provide a full URL?
Djago
Post by Djago »
I'm getting a message:
"Your account does not have permission to post links or domain/page references."
The site is QQ Music (best Chinese streamer!) use google to find it
Benjamin
Post by Benjamin »
to post an url you need to have at least 1 post (antispam), so now you should be able to share one.
Djago
Post by Djago »
I still get: "Your account does not have permission to post links or domain/page references."
For example:
try in http y (dot) qq (dot) com (slash) #type (equal) album&mid (equal) 001nhTh22ILv9b&play (equal) 0
http://y.qq.com/#type=album&mid=001nhTh22ILv9b&play=0
Hit the play button at the top or place the cursor over any song and hit play on the icon on the right.
Djago
Post by Djago »
Did you saw the same problem as I did?
Benjamin
Post by Benjamin »
(I edited your URL)
the example you sent works fine on my side: detection, download, auto rename...
Djago
Post by Djago »
What browser do you recommend?
Benjamin
Post by Benjamin »
the detection is not dependent on the browser, for the test I used Chrome.
Djago
Post by Djago »
I've tried again. Tried individual songs. First was OK (I got an mp3 file, well renamed). Second file was an mp4. This is the log.
06 jul 09:24:16 | File downloaded in 00:00:37
06 jul 09:24:16 | Process finished
06 jul 09:23:38 | http (6 event(s))
06 jul 09:23:47 | part_4 (7 event(s))
06 jul 09:24:07 | Done: size OK
06 jul 09:23:47 | starting...
06 jul 09:23:47 | socket (0 event(s))
06 jul 09:23:47 | part_3 (7 event(s))
06 jul 09:24:08 | Done: size OK
06 jul 09:23:47 | part_2 (7 event(s))
06 jul 09:24:16 | Done: size OK
06 jul 09:23:47 | part_1 (7 event(s))
06 jul 09:24:10 | Done: size OK
06 jul 09:23:46 | header (9 event(s))
06 jul 09:23:47 | stop
06 jul 09:23:47 | HTTP/1.1 200 OK
Last-Modified: Mon, 16 Jun 2014 00:19:38 GMT
Cache-Control: max-age=1296000
Date: Mon, 29 Jun 2015 14:30:22 GMT
Server-fsize: 563397
Server-md5: f4bd97eef889d6468d52a9d4db92dd12
Content-Length: 563397
Accept-Ranges: bytes
Content-Type: audio/mp4
Powered-By-ChinaCache: MISS from CNC-HH-4-3WL.12
Switch: FSCS
Expires: Tue, 14 Jul 2015 14:30:22 GMT
Powered-By-ChinaCache: HIT from CNC-ZU-4-3WQ.12
Connection: close
Server-Check: 4633ac12cb68320a3859b8aa88a0fe07
Switch:FSCS
06 jul 09:23:47 | GET /C200000rQaER2o0iSg.m4a?vkey=F027A310E0D722F2D7297E81A2B883EDE9FB0501D8F4F2A82E6A2CC6CFDB52F7351977876408DB10D9B8E099E5411AFB4F622F57671AA238&guid=4364425586&fromtag=0 HTTP/1.1
Accept: */*
Referer: http://y.qq.com/
Accept-Language: es-AR,es;q=0.7,ja;q=0.3
User-Agent: Mozilla/5.0 (compatible; MSIE 10.0; Windows NT 6.3; WOW64; Trident/7.0)
Host: cc.stream.qqmusic.qq.com
Pragma: no-cache
Cookie: pgv_pvid=4364425586; pgv_info=ssid=s4241173696; qqmusic_uin=12345678; qqmusic_key=12345678; qqmusic_fromtag=30
06 jul 09:23:46 | starting...
06 jul 09:23:46 | socket (1 event(s))
06 jul 09:23:38 | accelerator (9 event(s))
06 jul 09:23:46 | Download acceleration supported
06 jul 09:23:46 | stop
06 jul 09:23:38 | starting...
06 jul 09:23:38 | Checking download acceleration settings...
06 jul 09:23:38 | socket (1 event(s))
06 jul 09:23:38 | URL: http://cc.stream.qqmusic.qq.com/C200000 ... &fromtag=0
06 jul 09:23:38 | conversion (1 event(s))
06 jul 09:23:38 | renamer (5 event(s))
06 jul 09:24:16 | Extension found from codec probe: mp4
06 jul 09:23:38 | referrer title (4 event(s))
06 jul 09:23:45 | Referrer Web page title: QQ音乐-音乐你的生活!
06 jul 09:23:38 | referrer: http://y.qq.com/
06 jul 09:23:38 | conversion (2 event(s))
06 jul 09:23:38 | temporary (0 event(s))
06 jul 09:23:38 | original (0 event(s))
06 jul 09:23:38 | download (3 event(s))
06 jul 09:23:38 | temporary (2 event(s))
06 jul 09:23:38 | File name changed: <unknown_file_name> replaced by <31785928909215>
06 jul 09:23:38 | Extension changed: <ext> replaced by <part>
06 jul 09:23:38 | original (3 event(s))
06 jul 09:23:45 | File name changed: <C200000rQaER2o0iSg> replaced by <QQ音乐-音乐你的生活!(2)>
06 jul 09:23:38 | File name changed: <unknown_file_name> replaced by <C200000rQaER2o0iSg>
06 jul 09:23:38 | Extension changed: <ext> replaced by <mp4>
Benjamin
Post by Benjamin »
as you can see in the log it is a mp4:
MP3 or MP4 are just some containers, any player can play both.
Djago
Post by Djago »
I've installed a clean Windows XP Virtual Machine on VirtualBox to test it.
Tried with the same disk with the playlist for the entire disk.
First file: mp3, well renamed.
Second file and later files, mp4 and not renamed.
Only way to make it work:
1) Close browser
2) Start browser in private/incognito/whatever and launch the url
3) play ONE song
Repeat for every file from step 1.
If I try with a playlist I get one mp3 and the rest mp4 (without rename). Also if you download the same file in different formats, the files are completely different in size (for example 772kb or 2,08mb).
Benjamin
Post by Benjamin »
this is the server side implementation, we cannot change it...
but once your MP4 downloaded you can convert it into MP3.
Djago
Post by Djago »
ok, thanks anyway!
qingyi
Post by qingyi »
I think you can ues QQmusic PC version download it,Can you try it with this way?
