VSO CRASH
crashdawg
VSO CRASH
Post by crashdawg »
hello, can someone help me with a problem of VSO crashing and force closing after only a couple minute of use? This happens every time, not sometimes. and is very agrivating. i have sent a tech support report and they say the same thing. " You are not using recent version"
But i am. im using 4.0.0.19 any ideas? i have removed it and re installed several time. im running windows vista.thanks..CRASHDAWG
LouisM
Re: VSO CRASH
Post by LouisM »
please post the log file so we can investigate the issue.
You will find it in this location (pick the most recent one(s)):
C:\ProgramData\VSO\VSO Downloader\4\log
Any question about VSO Downloader? See the FAQ.
crashdawg
Re: VSO CRASH
Post by crashdawg »
[quote="LouisM"]Hello,
C:\ProgramData\VSO\VSO Downloader\4\log[/quote]
i unistalled vso, removed all folders. reinstalled and still force close. log file is empty?
LouisM
Re: VSO CRASH
Post by LouisM »
Use the support tool, it will send it automatically:
http://www.vso-software.fr/contactform. ... =technical
crashdawg
Re: VSO CRASH
Post by crashdawg »
[quote="LouisM"]Use the support tool, it will send it automatically:
http://www.vso-software.fr/contactform. ... =technical[/quote]
i just did this, and sent a log file. hopefully we can fix this. thanks,,
