Certain videos end quickly
Zero3K
Post by Zero3K »
When I open certain videos that have been downloaded in Media Player Classic - Home Cinema (MPC-HC), they start at the beginning but then quickly go to the end. Here's the video's info:
General
Complete name : C:\Users\Bryan\Documents\VSO Downloader\Streamate - Live Sex Web Cam Video Chat - Free Memberships, XXX Live Sex Girls(10).flv
Format : Flash Video
File size : 6.38 MiB
Duration : 1s 0ms
Overall bit rate : 53.5 Mbps
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : 7
Duration : 1s 0ms
Bit rate mode : Constant
Bit rate : 524 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate : 15.000 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.455
Stream size : 64.0 KiB (1%)
The Duration is wrong. It should be 3m 13s instead of 1s 0ms.
Zero3K
Re: Certain videos end quickly
Post by Zero3K »
Well?
Benjamin
Post by Benjamin »
this media is not correctly supported, will be added in our bug DB
Zero3K
Post by Zero3K »
When will it be fixed?
Zero3K
Post by Zero3K »
Here's another video's information:
General
Complete name : C:\Users\Bryan\Documents\VSO Downloader\HERMAPHRODITES58576931.flv
File size : 1.42 MiB
Duration : 2s 0ms
Overall bit rate : 5 947 Kbps
Video
Format : AVC
Format profile : Main@L3.1
Codec ID : 7
Duration : 2s 0ms
Bit rate : 5 704 Kbps
Width : 640 pixels
Height : 480 pixels
Frame rate : 10.000 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 1.857
Stream size : 1.36 MiB (96%)
So, the duration is completly wrong for those two files I posted the info of.
Benjamin
Post by Benjamin »
please send the download log
Zero3K
Post by Zero3K »
Here's the download log of a video that had this issue occur:
10:16:31 LOGINFO File name added: <unknown_file_name.f4v>
10:16:31 LOGINFO Extension added: <.f4v>
10:16:31 LOGDEBUG Referrer Web page: http://www.flirt4free.com
10:16:31 LOGDEBUG RTMP Download starting...
10:16:31 LOGINFO RTMP initialisation: rtmp://fms.020F.edgecastcdn.net/20020F/?key=2b66aed003e0e196c684a307f1512b363a804f431ea56c53f411abf6db4e5dd11f7a
10:16:31 LOGOK URL setup with success
10:16:31 LOGDEBUG Requesting buffer time of 40 Ms
10:16:31 LOGOK Connected...
10:16:32 LOGERROR Unable to connect to stream
10:16:32 LOGERROR Unable to check the connection: switching to live mode
10:16:32 LOGINFO RTMP initialisation: rtmp://fms.020F.edgecastcdn.net/20020F/?key=2b66aed003e0e196c684a307f1512b363a804f431ea56c53f411abf6db4e5dd11f7a
10:16:32 LOGOK URL setup with success
10:16:32 LOGDEBUG Requesting buffer time of 40 Ms
10:16:32 LOGOK Connected...
10:16:32 LOGOK Connected to stream...
10:16:32 LOGINFO Starting download
10:16:32 LOGDEBUG Referrer Web page title: Chat Free on Cam Live Sex Adult Webcams - Flirt4Free
10:16:32 LOGINFO File name changed: <unknown_file_name.f4v> replaced by <Chat Free on Cam Live Sex Adult Webcams - Flirt4Free.f4v>
10:19:32 LOGERROR Stop requested by user
10:19:32 LOGDEBUG Stopping RTMP thread
10:19:32 LOGDEBUG RTMP_READ_IGNORE
10:19:32 LOGOK Record stopped
10:19:32 LOGOK Download completed
10:19:32 LOGINFO File downloaded in 00:03:00
10:19:32 LOGINFO Temporary file successfully renamed
10:19:32 LOGOK Extension found from probe of the stream: flv
10:19:32 LOGOK File successfully renamed with new extension: Chat Free on Cam Live Sex Adult Webcams - Flirt4Free.flv
10:19:32 LOGDEBUG No conversion profile selected
10:19:32 LOGINFO Abort
Here's a link to the video:
http://temp-share.com/show/3YgF79rZx
Benjamin
Post by Benjamin »
try to not stop the recorder: let it stop itself
Zero3K
Post by Zero3K »
How about having it check the duration of the video when its stopped to see if its missing/incorrect and fix it?
are you proposing a solution to know if the video is complete or not? Can you develop your thoughts?
Zero3K
Post by Zero3K »
It should check if the duration value is in a FLV video and check it compared to how long the video has been downloading, if it doesn't exist or is wrong, then replace/add it with the correct one.
Zero3K
Post by Zero3K »
There are still some streams that are having this issue. Please check some of them on www.flirt4free.com and www.ifriends.net so the issue can be completely fixed.
Zero3K
Post by Zero3K »
Its still happening (especially on streams recorded from www.ifriends.net).
LouisM
Post by LouisM »
Videos downloaded from flirt4free play fine in VLC. We confirm that ifriends is not yet supported.
Any question about VSO Downloader? See the FAQ.
Zero3K
Post by Zero3K »
Its still happening to streams downloaded from Streamate.com. Please fix it soon. Thanks.
