Blindwrite 6 how to change Writing Mode ?
Starfox
Post by Starfox »
i have Blindwrite 6 at the moment the Trial Version.
Every Time i wan´t to write a CD Blindwrite selects TAO writing Mode but i want DAO PW.
How can i change it ?
I need the Twinpeak Method for Topology Writing but in TAO writing Mode there is an Error "Writing Mode not compatible"
Today i tested Blindwrite 7 same Problem.
Only in Version 5 the Topology writing works with correct writing Mode DAO PW.
Here the Log for BW 7:
Code: Select all
11:15:52.974  Error           Init Sector provider failed
11:15:52.974  Error           Topology to be reproduced with Twinpeak, but writing mode is not compatible. Write aborted.
11:15:52.973  Info            TAO writing mode selected
11:15:52.973  Info            Writing speed requested x24, effective x24
11:15:52.862  Info            Track 1 Prepared: LBA 0 - 325557
11:15:52.849  Info            TAO/SAO writing mode preferred
11:15:52.849  Info            Media ID : CMC-6
11:15:52.844  Info            Writing CD-ROM Disc [UNREAL2_PLAY] - Image Size 760,39 Mb.
11:15:52.844  Info            Dev. support DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
11:15:52.831  Info            Using : 0:2:0 - HL-DT-ST BD-RE  BH10LS30 1.02 [E] (Scsi)
11:15:52.810  Info            Imported file format - BwaBuilder (BWA) - Quality 100%
11:15:48.354  Info            Imported file format - CloneCD
11:15:11.889  Info            Launched with external parameters
11:15:11.874  Info            Using Advanced SPTI interface
11:15:11.558  Info            Total Physical Memory : 16318 Mb.
                              Available Physical Memory : 13949 Mb.
                              Memory Load  : 14%
                              Available Virtual Memory : 1861 Mb.
                              Total Memory : 18750 Mb.
                              Available Memory : 16103 Mb.
11:15:11.558  Info            Processor Intel(R) Core(TM) i5-9400F CPU @ 2.90GHz with 6 core(s) CPU
                              Pipeline(s): 6 - parallelize up to 6
                              Supported instruction set: MMX,sse,sse2 (slow),sse3,ssse3,sse41,sse42,avx,avx2,bmi1,bmi2,aes,Fma3
11:15:11.553  Info            OS : Windows 8 (64 bits), Build 9200, service pack 0.0
                              file name : D:\Programme\BlindWrite7\bw.exe
                              file version : 7.0.0.0
                              User language   : Deutsch (Deutschland)
                              System language : Deutsch (Deutschland)
Re: Blindwrite 6 how to change Writing Mode ?
sorry don't know answer but this is a very old product, last update was over 7 years ago when v 7.0.0.0 Released January 25th 2013
