Rename BWI BWS BWA BWT files
RodrigoHouse
Post by RodrigoHouse »
Hello, this is my first post. How do I rename the files with the extensions BWI BWS BWT BWA? For example, ISO files, just rename normally. BIN + CUE file is to rename the files normally, and edit the CUE file by notepad. But the BWA BWI BWS BWT files not work after simply rename the files. Thank you.
Re: Rename BWI BWS BWA BWT files
You don't rename them. Name them correctly when creating.
RodrigoHouse
The problem is already renamed and not remember the old name.
